666156FULL-1101X
666156FULL-1101X
    EATON(伊顿)
    FULLEON - 666156FULL-1101X - Beacon / Sounder, White, Flashing, Multiple Tones, 90dBA, 114mm, 35V, I...
666156FULL-1101X 数据手册
Eaton Product Datasheet Sounder Beacons SQG3-VID sounder beacon The SQG3 visual indicator device (VID) is a combined audible and visual indicator base unit. The mounting surface is suitable for the majority of European detectors. Certified to EN54-3 and suitable as a visual indicating device, it ensures compliance to the latest European Legislation and provides a versatile notification and detection solution. Features • Certified to EN 54-3 • First fix base • Fixing platform for most popular detectors • Tamper-proof cap for standalone use (supplied separately) • Red flash visual indicator Technical specification Voltage Current Sound Output Tones Volume Control Flash Rate Monitoring Temperature Protection Construction Weight Colours Flash Colour 18 - 35Vdc 8.7 - 11mA High Volume - 90 +/- 3dB(A) 3 10dB 0.5Hz Reverse polarity - 10ºC to + 55ºC IP21C ABS, PC lens 0.175kg White Red Dimensions Benefits • Suitable for use in fire systems throughout Europe • Quick, simple installation • Notification and detection in one unit saves on installation costs Ø114mm 30mm Catalogue numbers Reference Cat no. Description SQG3-23/W1/WF 666140FULL-1079X SQG3-23 base sounder VAD, white body, white flash SQG3-VID/W1/RF 666156FULL-1101X SQG3 base sounder VID, white body, red flash Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2018 Eaton All Rights Reserved Publication No TD-EN-450-052018 / CSSC-1248 May 2018 Eaton is a registered trademark. All other trademarks are property of their respective owners.
666156FULL-1101X 价格&库存
很抱歉,暂时无法提供与“666156FULL-1101X”相匹配的价格&库存,您可以联系我们找货
