666058FULL-0098X
666058FULL-0098X
    EATON(伊顿)
    FULLEON - 666058FULL-0098X - Sounder, Squashni G3, 8 Tone, 90dBA, 28V, 5mA, 114mm, IP21C
666058FULL-0098X 数据手册
Squashni G3 - Platform Sounder Safety The third generation Squashni G3 amalgamates the best features from the previous Squashni and Squashni Micro versions. The large flat surface allows the mounting of a large range of European detectors, while the high efficiency and low operating current permit compatibility with many systems. Technical Specification 18 - 28Vdc Current 4/5mA Sound Output 90dB(A) Tones 8 Volume Control 10dB Monitoring Temperature Reverse polarity - 10ºC to + 55ºC Protection IP21C Construction ABS Weight 0.16Kg Colours White 35mm Voltage Ø 114mm Features Benefits  Universal detector platform  Fits the majority of detectors for increased flexibility  First fix base  Speeds up installation  Low current consumption  Maximises the number of devices on a system  Tamper proof cap option  For use without a detector Reference Catalogue No. Description SQG3/W 666058FULL-0098X Squashni G3 Sounder white 9
666058FULL-0098X 价格&库存
很抱歉,暂时无法提供与“666058FULL-0098X”相匹配的价格&库存,您可以联系我们找货
