65-00-GEL30-0010
65-00-GEL30-0010
    PARKERCHOMERICS
    热敏式 硅树脂凝胶 10cc 注射器
65-00-GEL30-0010 数据手册
THERM-A-GAP™ Gels Dispensable, Very Low Compression Force, Thermal Gap Fillers THERM-A-GAP™ Gels are highly conformable, pre-cured, single-component compounds. The cross-linked gel structure provides superior long term thermal stability and reliable performance. FEATURES / BENEFITS • • • • • • • • • • • • Automotive electronic control units (ECUs) - Engine control - Transmission control - Braking/traction control Power conversion equipment Power supplies and uninterruptible power supplies Power semiconductors MOSFET arrays with common heat sinks Televisions and consumer electronics PERFORMANCE GUIDE 8.0 Gel 75 7.0 6.0 5.0 Thermal Conductivity (W/m-K) TYPICAL APPLICATIONS TC 50 Gel 45 4.0 Gel 30 Gel 37 Gel 8010 3.0 2.0 T636 Gel 25NS T635 1.0 Consult Applications Engineering for automated dispensing equipment recommendations. Dispensable Fully cured Highly conformable at low pressures No refrigeration, mixing or filler settling issues in storage Single dispensable TIM can eliminate multiple pad part sizes/numbers Reworkable T630 10 20 30 40 50 60 Flow Rate (grams/min) Phone +1 781-935-4850 www.parker.com/chomerics 1 THERM-A-GAP™ Thermally Conductive Gels Physical Typical Properties† T630 T635 T636 Test Method Color White White Yellow Visual Binder Silicone Silicone Silicone -- 10* 8 8 Chomerics Flow Rate, grams/min - 30 cc taper tip, 0.130" orifice*, 90 psi (621 kPa) 2.0 1.5 1.2 ASTM D792 0.004 (0.10) 0.015 (0.38) 0.015 (0.38) -- 0.7 1.7 2.4 ASTM D5470 Specific Gravity Typical Minimum Bondline Thickness, in (mm) Electrical Thermal Thermal Conductivity, W/m-K Heat Capacity, J/g-K 1.1 0.9 0.9 ASTM E1269 Coefficient of Thermal Expansion, ppm/K 350 400 400 ASTM E831 Operating Temperature Range, °F (°C) -67 to 392 (-55 to 200) -67 to 392 (-55 to 200) -67 to 392 (-55 to 200) -- Dielectric Strength, Vac/mil (kVac/mm) 200 (8) 200 (8) 200 (8) ASTM D149 1014 1014 1014 ASTM D257 Regulatory Volume Resistivity, ohm-cm Dielectric Constant @ 1,000 kHz 5.5 4.0 4.0 ASTM D150 Dissipation Factor @ 1,000 kHz 0.010 0.003 0.003 Chomerics Flammability Rating (See UL File E140244 for details) V-0 Not Tested V-0 UL 94 RoHS Compliant Yes Yes Yes Chomerics Certification 0.55 (0.14) Not Tested 0.49 (0.18) ASTM E595 18 18 18 Chomerics 50 to 90 (10 to 32) 50 to 90 (10 to 32) 50 to 90 (10 to 32) Chomerics Outgassing, % TML (% CVCM) Shelf Life, months from date of manufacture Storage Conditions, °F (°C) @ 50% Relative Humidity † Typical properties: these are not to be construed as specifications. * THERM-A-GAP T630 flow rate is measured in a 0.100" orifice. COMPRESSION DEFLECTION 7 T630 Force (psi) 6 5 Gel 75 4 3 Gel 37 2 1 0 0 10 20 30 40 50 60 70 80 Strain (%) Test method: • ASTM C165 Modified • Dispensed material and brought 0.50” diameter probe down to 0.100” height  • Strain rate 0.025 in/min Phone +1 781-935-4850 www.parker.com/chomerics 2 THERM-A-GAP™ Thermally Conductive Gels Physical Typical Properties† GEL 25NS GEL 8010 GEL 30 GEL 37 Test Method Color Yellow White Pink Blue Visual Binder Urethane Silicone Silicone Silicone -- Flow Rate, grams/min - 30 cc syringe with no tip attachment, 0.100” orifice, 90 psi (621 kPa) 15 60 20 30 Chomerics Specific Gravity 2.6 2.7 3.1 3.1 ASTM D792 0.004 (0.11) 0.002 (0.05) 0.004 (0.10) 0.004 (0.10) Chomerics 2.5 3.0 3.5 3.7 ASTM D5470 Typical Minimum Bondline Thickness, in (mm) Thermal Thermal Conductivity, W/m-K Heat Capacity, J/g-K Coefficient of Thermal Expansion, ppm/K Regulatory Electrical Operating Temperature Range, °F (°C) Dielectric Strength, Vac/mil (kVac/mm) Volume Resistivity, ohm-cm 1 1 1 ASTM E1269 150 150 150 ASTM E831 -58 to 257 (-50 to 125) -67 to 392 (-55 to 200) -67 to 392 (-55 to 200) -67 to 392 (-55 to 200) Chomerics 200 (8) 200 (8) 200 (8) 180 (7.0) ASTM D149 1014 1014 1014 1014 ASTM D257 Dielectric Constant @ 1000 kHz 6.7 6.3 7.0 5.9 ASTM D150 Dissipation Factor @ 1000 kHz 0.018 0.002 0.002 0.012 Chomerics Flammability Rating V-0 V-0 V-0 V-0 UL 94 RoHS Compliant Yes Yes Yes Yes Chomerics Certification 0.23 (0.04) 1.33 (0.34) 0.15 (0.05) 0.18 (0.07) ASTM E595 12 18 18 18 Chomerics 50 to 90 (10 to 32) 50 to 90 (10 to 32) 50 to 90 (10 to 32) 50 to 90 (10 to 32) Chomerics Outgassing, % TML (% CVCM) Shelf Life, months from date of manufacture Storage Conditions, °F (°C) @ 50% Relative Humidity † 0.96 < 300 Typical properties: these are not to be construed as specifications. Phone +1 781-935-4850 www.parker.com/chomerics 3 THERM-A-GAP™ Thermally Conductive Gels Physical Typical Properties† GEL 45 TC50 GEL 75 Test Method Color Black Gray White Visual Binder Silicone Silicone Silicone -- Flow Rate, grams/min - 30 cc syringe with no tip attachment, 0.100” orifice, 90 psi (621 kPa) 55 10 30 Chomerics Specific Gravity 3.1 3.25 3.4 ASTM D792 0.0035 (0.0889) 0.006 (0.15) 0.008 (0.20) Chomerics 4.5 5.0 7.5 ASTM D5470 Typical Minimum Bondline Thickness, in (mm) Thermal Thermal Conductivity, W/m-K Heat Capacity, J/g-K Coefficient of Thermal Expansion, ppm/K Regulatory Electrical Operating Temperature Range, °F (°C) Dielectric Strength, Vac/mil (kVac/mm) Volume Resistivity, ohm-cm 1 1 ASTM E1269 150 150 ASTM E831 -67 to 392 (-55 to 200) -67 to 392 (-55 to 200) -67 to 392 (-55 to 200) Chomerics 200 (8) 200 (8) 220 (8.7) ASTM D149 1014 1014 1014 ASTM D257 Dielectric Constant @ 1000 kHz 7.0 6.8 7.2 ASTM D150 Dissipation Factor @ 1000 kHz 0.002 0.022 0.023 Chomerics Flammability Rating V-0 V-0 V-0 UL 94 RoHS Compliant Yes Yes Yes Chomerics Certification 0.15 (0.05) 0.07 (0.01) 0.18 (0.05) ASTM E595 18 18 9 Chomerics 50 to 90 (10 to 32) 50 to 90 (10 to 32) 50 to 90 (10 to 32) Chomerics Outgassing, % TML (% CVCM) Shelf Life, months from date of manufacture Storage Conditions, °F (°C) @ 50% Relative Humidity † 1 150 Typical properties: these are not to be construed as specifications. Phone +1 781-935-4850 www.parker.com/chomerics 4 Ordering Information THERM-A-GAP™ Thermally Conductive Gels These materials are available in the following formats. PA R T N U M B E R : 65 XX ZZZZ YYYYY Cartridge Type 00 Material Type T630 T635 T636 GEL25NS GEL8010 GEL30 GEL37 GEL45 TC50 GEL75 01 = Semco Cartridge 02 = Nordson EFD Vessel Size 0010 = 10 cc Luer-Lok™ Syringe 0300 = 300 cc Aluminum Cartridge (Caulking Style) 0180 = 180 cc 0240 = 240 cc 0600 = 600 cc 0960 = 960 cc 0030 = 30 cc 0180 = 180 cc 1P = 1 U.S. Gallon 2500 = 1 U.S. Gal. Pail 5P = 5 U.S. Gallon XXXX = 5 U.S. Gal. Pail (XXXX = Fill Volume. dependent on material, ~25 kg) Ordering Information: Custom Configurations Larger custom cartridges and pails available. Please contact Parker Chomerics for a pre-assigned part number for custom part sizes.  Dispensing Equipment Options Optional Supplier Description Hand-Gun Pneumatic Dispensing 300 cc cartridges Bergdahl Associates SEMCO® Model 550 Hand-Gun Pneumatic Dispensing 180 cc (6 oz) cartridges  Bergdahl Associates Model 250A-6 oz Sealant Gun www.bergdahl.com Ultra 2400 Series Pneumatic Shot Size Controllers 30 cc, 180 cc and 300 cc shot size dispensing equipment EFD Ultra 1400 Series Ultra 870 Series 30 cc/55 cc Adapter Assembly Dispensing Sleeve to support 6 oz (180 cc) SEMCO tubes ® EFD 10000D5152 EFD 5192-6 www.efd-inc.com SEMCO is a registered trademark of PPG Aerospace Phone +1 781-935-4850 www.parker.com/chomerics 5
65-00-GEL30-0010 价格&库存
很抱歉,暂时无法提供与“65-00-GEL30-0010”相匹配的价格&库存,您可以联系我们找货
