CHO-MASK II
Conductive Foil Tape with Peel-Off Mask
for Painting Operations
Customer Value Proposition
Parker Chomerics CHO-MASK® II
Conductive Foil Tape is available in
Standard Tack (ST) and High Tack
(HT) versions, providing an electrically
conductive, non-corroding surface on
painted metal electronic enclosures.
CHO-MASK II tapes consist of recessed
polyester paint masking film covering a
layer of either 1 oz (28.4 g) or 2 oz (56.7 g)
tin-plated copper foil. The back of the foil
features a conductive pressure sensitive
adhesive (PSA). CHO-MASK II tape is
applied to clean metal frame, door and
panel surfaces where electrical continuity
is required.
After painting, the peel-off mask is easily
removed, allowing the paint to seal both
edges of the foil layer. The foil imparts a
clean, electrically conductive path from
the panel, through an EMI gasket, to the
cabinet frame. It also provides grounding
points within the enclosure.
Product Features
• More cost-effective and
environmentally friendly than
plating and coating methods
• Peel-off mask is removed easily
any time, at any temperature
• Mask is recessed from edges
for paint overlap and corrosion
protection
Contact Information
Parker Hannifin Corporation
Chomerics Division
77 Dragon Court
Woburn, MA 01801
phone 781 935 4850
fax 781 933 4318
chomailbox@parker.com
www.parker.com/chomerics
• Solvent/chemical resistant
• Maintains performance after
10,000 door closure cycles
• Passes MIL-STD-810
Salt Fog testing
• Foil tape meets MIL-T-47012
• Tin-plated on foil meets
MIL-T-10727
• Pressure sensitive adhesive contains
highly stable, conductive particles
for long-term reliability
• Provides effective EMI shielding
performance when used in
conjunction with Parker Chomerics
EMI gaskets
Typical Applications
• Enclosure enclosures
• Painted cabinets and boxes
• Doors and flanges or other
mating seams
CHO-MASK® II – Product Information
Table 1 - Technical Data
Typical Properties
CHO-MASK II ST (Standard Tack)
CHO-MASK II HT (High Tack)
Test Method
1 oz Tin-Plated Copper Foil
2 oz Tin-Plated Copper Foil
Visual
1 oz = 1.4 mils (0.04 mm)
2 oz = 2.8 mils (0.07 mm)
Visual
Masking Film
Polyester
Chomerics
Adhesive Type
Electrically Conductive, Pressure-Sensitive Acrylic
Visual
Foil Options
Foil/Fabric Thickness, mils (mm)
Adhesive Thickness, mils (mm)
Total Thickness1, mils (mm)
1.8 (0.05)
2.0 (0.05)
Visual
1 oz = 3.2 (0.08)
2 oz = 4.6 (0.12)
1 oz = 3.0 (0.08)
2 oz = 4.8 (0.12)
ASTM-D1000
Temperature Range, ˚F (˚C)
-40 to 180 (-40 to 82)
Chomerics
Electrical Resistance2, milliohms
很抱歉,暂时无法提供与“CMT-HT-108-0500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8331.629181+1077.39521
- 10+7458.5481710+964.49373
