50-30-0584-0029
50-30-0584-0029
    PARKERCHOMERICS
    SILER EPOXY 10 3G EA SYRINGE KIT
50-30-0584-0029 数据手册
CHO-BOND® 584-29 TWO COMPONENT SILVER EPOXY ADHESIVE Customer Value Proposition: Parker Chomerics CHO-BOND 584-29 is a twocomponent, silver filled conductive epoxy adhesive system designed for applications where a strong, highly conductive electrical bond must be achieved. CHO-BOND 584-29 is recommended for relatively small bond lines (less than 0.010 inches (0.25mm)), but can be used for larger bond lines in applications where vibration or potential for cracking is not an issue. The fine silver filler of CHO-BOND 584-29 make it a good material choice for precise application in and around tight spaces and electrical components. CHO-BOND 584-29 comes in a variety of sizes and packaging so customers can choose a package and material size which is right for their application, minimizing material scrap and mixing issues. Curing of CHO-BOND 584-29 can be achieved in as little as 15 minutes with heat to minimize equipment downtime and increase manufacturing throughput. Typical applications include bonding and grounding of electrical components, cold soldering, and bonding and sealing machined enclosures. Contact Information: Parker Hannifin Corporation Chomerics Division 77 Dragon Court Woburn, MA 01801 phone 781 935 4850 fax 781 933 4318 chomailbox@parker.com www.parker.com/chomerics Features and Benefits: • Two component • Fast heat cure, increases throughput, minimizes equipment downtime. • Silver filler • Excellent conductivity 0.002 ohm-cm • Epoxy • 30 minute working life, works well over wide temperature range, good chemical resistance >1200 psi lap shear, good for permanently bonding surfaces. • Multiple packaging options • No weighing required, mix and dispense in same package, minimizes process scrap. • Thin paste • May be dispensed out of very small needles, fill small cracks and voids. • Low VOCs • Minimal shrinkage CHO-BOND 584-29 - Product Information Table 1 Typical Properties Typical Properties Typical Values Test Method Polymer Epoxy N/A Filler Silver N/A 100 : 6.3 N/A Silver N/A (Q) Consistency Very Thin Paste N/A (Q) Maximum DC Volume Resistivity (Cure Cycle 1) 0.002 ohm-cm CHO-95-40-5101* (Q/C) 1200 psi (8274 kPa) CHO-95-40-5300* (Q/C) 2.5 ASTM D792 (Q/C) 80 Shore D ASTM-D2240 (Q) - 55°C to 125°C (-67°F to 257°F) N/A (Q) Cure Cycle Option 1: 0.25 hour @ 113°C (235°F) Cure Cycle Option 2: 2.0 hours @ 65°C (150°F) N/A Room Temperature Cure 24 hours N/A (Q) Working Life 0.5 hours N/A (Q) 12 months @ 25°C (77°F) N/A (Q) Minimum thickness recommended 0.001 in (0.03 mm) N/A Maximum thickness recommended None N/A Mix Ratio, A : B (by weight) Color Minimum Lap Shear Strength (Cure Cycle 1) Specific Gravity (Room Temp Cure) Hardness (Cure Cycle 1) Continuous Use Temperature Elevated Temperature Cure Cycle Shelf Life, unopened Volatile Organic Content (VOC) 0 g/l Typical Coverage Area at 0.001” Thick per Pound (454 grams) Calculated 11,000 in (70,968 cm ) 2 2 N/A Note: N/A – Not Applicable, (Q/C) - Qualification and Conformance Test, (Q) - Qualification Test * This test Method is available from Parker Chomerics. Table 2 Ordering Information Product CHO-BOND 584-29 Weight (grams) Packaging Part Number Primer Included 1.0 2 component, premeasured CHO-PAK 50-10-0584-0029 Not required 2.5 2 component, premeasured CHO-PAK 50-02-0584-0029 Not required 10 x 3 2 component, premeasured, 10 x 3 gram syringe kits 50-30-0584-0029 Not required 10 2 component, premeasured CHO-PAK 50-03-0584-0029 Not required 85 2 component, 4 fluid ounce polypropylene kit 50-00-0584-0029 Not required 454 2 component, 8 fluid ounce polypropylene kit 50-01-0584-0029 Not required Please refer to Parker Chomerics Surface Preparation and CHO-BOND Application documents for information regarding the proper surface preparation, primer application (if required), and use of these compounds. www.chomerics.com www.parker.com/chomerics CHOMERICS and CHO-BOND is a registered trademark of Parker Hannifin Corporation. ® 2021 TB 1002 EN March 2021
50-30-0584-0029 价格&库存
很抱歉,暂时无法提供与“50-30-0584-0029”相匹配的价格&库存,您可以联系我们找货
