65-02-GEL75-0030
65-02-GEL75-0030
    PARKERCHOMERICS
    THERM-A-GAP GEL 75 7.5 W/M-K DIS
65-02-GEL75-0030 数据手册
THERM-A-GAPTM GEL 75 High Performance Fully Cured Dispensable GEL Customer Value Proposition: Parker Chomerics THERM-A-GAP GEL 75 is a high performance, one component, dispensable thermal interface material with 7.5 W/m-K thermal conductivity developed to conduct heat from electronics to a heat sink or enclosure. The material’s heavy paste-like consistency enables controlled dispensing, applied in variable thicknesses to suit application needs. THERM-A-GAP GEL 75 requires low compressive force to deform under assembly pressure subjecting components, solder joints and leads to minimal stresses. It is formulated to accommodate today’s high performance electronics and is ideal for automated dispensing machines, rework and field repair situations. Contact Information: Parker Hannifin Corporation Chomerics Division 77 Dragon Court Woburn, MA 01801 phone 781 935 4850 fax 781 933 4318 chomailbox@parker.com www.parker.com/chomerics Features and Benefits: Typical Applications: • • • • • • Thermal conductivity: 7.5 W/m-K Easily dispensed No secondary curing required Low thermal impedance Ultra-low compression force Reworkable Packaging and Handling: • • • • • Telecom base stations Power supplies and semiconductors Memory and power modules Microprocessors Central processing units (CPUs) Material may be packaged in syringes, cartridges or bulk packaged in pails. Product Information THERM-A-GAP GEL 75 Typical Properties* GEL 75 Test Methods White Visual Flow Rate, g/min - 30cc syringe with no tip, 0.100” orifice, 90psi (621 kPa) 30 Chomerics Specific Gravity 3.4 ASTM D792 0.008 (0.20) Chomerics Thermal Conductivity, W/m-K 7.5 ASTM D5470 Heat Capacity, J/g-K 1.0 ASTM E1269 (25°C ± 2°C - DSC) Coefficient of Thermal Expansion, ppm/K 150 ASTM E831 -67 to 392 (-55 to 200) Chomerics 220 (8.7) Chomerics Volume Resistivity, ohm-cm 10 ASTM D257 Dielectric Constant @ 1000 kHz 7.2 ASTM D150 Dissipation Factor @ 1000 kHz 0.023 Chomerics Flammability Rating V-0 Chomerics RoHS Compliant Yes Chomerics 0.18 (0.05) ASTM E595 9 Chomerics Physical Color Thermal Typical minimum bondline thickness, in (mm) Operating Temperature Range °F (°C) Regulatory Electrical Dielectric Strength, Vac / mil (kVac/mm) 14 Outgassing, % TML (% CVCM) Shelf Life, months from date of manufacture * Typical properties: these are not to be construed as specifications. Part Number Standard Fill Volume (cc) Standard Fill Mass (grams) Description 65-00-GEL75-0010 10 33 Luer-LokTM Syringe 65-02-GEL75-0030 27 89.1 Nordson EFD Syringe 65-02-GEL75-0180 150 495 Nordson EFD Syringe 65-00-GEL75-0300 300 990 Aluminum Cartridge 65-1P-GEL75-2500 2500 8250 1 US gal. pail 65-5P-GEL75-7350 7500 24,990 5 US gal. pail www.parker.com/chomerics CHOMERICS a registered trademark of Parker Hannifin Corporation. ® 2021 Parker Chomerics THERM-A-GAP GEL 75 May 2021
65-02-GEL75-0030 价格&库存
很抱歉,暂时无法提供与“65-02-GEL75-0030”相匹配的价格&库存,您可以联系我们找货
65-02-GEL75-0030
  • 1+827.156581+107.00533
