82-121-74011-G8704
82-121-74011-G8704
    PARKERCHOMERICS
    Gasket, EMI Shielding, Nylon Ripstop Fabric over Foam, 1 m, 9.5 mm x 6.4 mm, 90 dB
82-121-74011-G8704 数据手册
• • • • • Seals TECHNICAL BULLETIN Conductive elastomers • Knitted wire mesh Conductive coatings, sealants, adhesives Cable shielding products • EMI/ESD shielding laminates Shielded vents and windows Commercial and military EMI testing 172 LEADER IN EMI SHIELDING INNOVATION, DESIGN, AND TEST TECHNOLOGY SOFT-SHIELD® 5000 Series Conductive Jacket over Foam EMI Gaskets SOFT-SHIELD 5000 Standard Product vs. UL 94V-0 Version Attenuation (dB) 120 100 80 Part No. 82-122-74012-09600 (UL 94V-0 rated) 60 Part No. 82-121-74012-09600 40 Test Procedure TP-08 Dynamic Test Range Limitation 20 0 10 100 1000 10000 Frequency (MHz) DESCRIPTION SOFT-SHIELD 5000 Series EMI gaskets are designed to meet the stringent shielding and mechanical performance requirements of today’s commercial electronic enclosures, medical electronics, factory automation equipment, reprographics and grounding applications. SOFT-SHIELD 5000 Series EMI gaskets consist of an electrically conductive fabric jacket over a highly compressible foam core. The nickel-plated-silver woven nylon rip-stop jacket is self-terminating when cut. Chosen for its exceptional compressibility, the foam core typically requires less than 1 lb/in (0.175 N/mm) closure force, making it especially useful for thin-walled plastic enclosures. Property Test Method Typical Values Shielding Effectiveness CHO-TM-TP08 See graph above Compression Set ASTM D3574 (mod.)
82-121-74011-G8704 价格&库存
很抱歉,暂时无法提供与“82-121-74011-G8704”相匹配的价格&库存,您可以联系我们找货
