CHO-FAB
Electrically Conductive Fabric Tape
Customer Value Proposition
Parker Chomerics CHO-FAB™ Electrically
Conductive Fabric Tape is ideal for
applications requiring lighter weight and a
more flexible electrically conductive tape
than metal foil tapes provide. CHO-FAB
tape provides excellent EMI shielding and
good corrosion resistance. In the case of
shielded cables, CHO-FAB tape is very
conformable, strong, lightweight, and
doesn’t have sharp edges that are present
on metal foil tapes.
CHO-FAB tape provides an economical
solution to applications requiring excellent
electrical conductivity across substrates
and offers a low-impedance connection
between a braided cable shield
and the metal connector back shell in
molded cables.
Seams of EMI shielded rooms and
other shielded test enclosure setups are
more easily sealed with CHO-FAB tape
than metal foil tape to provide electrical
continuity and thus higher shielding
effectiveness.
Contact Information
Parker Hannifin Corporation
Chomerics Division
77 Dragon Court
Woburn, MA 01801
phone 781 935 4850
fax 781 933 4318
chomailbox@parker.com
www.parker.com/chomerics
Features and Benefits
• Made of fabric tape constructed
from a nickel-plated silver
conductive material
• Available with single-sided acrylic
electrically conductive pressure
sensitive adhesive (PSA)
• Lightweight and more flexible
• Excellent shielding and good
corrosion resistance performance
• Lacks sharp edges that are
present on foil tapes
• Very conformable while
maintaining strength
• Available as rotary kiss cut parts
on rolls, die-cut parts, or in slit roll
widths from 0.5 in (12.7 mm) to
24 in (609.6 mm)
• Bulk roll lengths are 18 yards
(16.5 m) or 36 yards (33 m)
Typical Applications
• Enclosure shielding
• Braided cables/wires
• Mating flanges
• Grounding
CHO-FAB™ – Product Information
Table 1 - Typical Properties
Typical Values
Test Method
Foil Option
Typical Properties
Nickel-Plated Silver
Fabric Type
Polyester Taffeta
5 (0.127)
Electrically Conductive,
Pressure-Sensitive Acrylic
Adhesive Thickness, mils (mm)
1.5 (0.0381)
Total Thickness, mils (mm)
6.5 (0.165)
Temperature Range, ˚F (˚C)
-40 to 250
(-40 to 121)
很抱歉,暂时无法提供与“CFT-18-101-0100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6584.760521+855.32699
