CCK-18-101-0200
CCK-18-101-0200
    PARKERCHOMERICS
CCK-18-101-0200 数据手册
CHO-FOIL®and CHO-FABTM EMI Shielding Foil and Fabric Tape with Conductive Adhesive Customer Value Proposition: Parker Chomerics CHO-FOIL® metal foil tapes provide an economical solution to applications requiring excellent electrical conductivity across substrates. These foil tapes can provide a low impedance connection between a braided cable shield and the metal connector backshell in molded cables. Due to the highly conductive pressure sensitive acrylic adhesive (PSA), the tape can provide an effective shielded cable assembly without the need for soldering the tape to the braid. The uniform dispersion of unique, oxidation-resistant conductive particles in the acrylic PSA produce a very low resistance through the tape. Thus, wrapping a cable assembly with the foil tape, using a slight overlap, can provide an effective prototype cable shielding system. Seams of EMI shielded rooms and other shielded test enclosure setups are more easily sealed with CHO-FOIL tape so as to provide electrical continuity and thus higher shielding effectiveness. Double-sided conductive adhesive is available to ensure leak free seams. The use of CHO-FOIL tape can ensure good electrically conductive mating flanges and corrosion resistant grounding areas. For applications requiring lighter weight and a more flexible electrically conductive tape, the electrically conductive fabric tape, CHO-FABTM, will provide excellent shielding and good corrosion resistant performance. In the case of shielded cables, CHO-FAB is very conformable, strong, lightweight, and doesn’t have sharp edges that are present on metal foil tapes. Contact Information: Parker Hannifin Corporation Chomerics Division 77 Dragon Court Woburn, MA 01801 phone 781 935 4850 fax 781 933 4318 chomailbox@parker.com www.parker.com/chomerics Product Features: • Available in copper, aluminum, and tin-plated copper foils, or nickel-plated silver fabric. • Embossment available on Copper (CCE) and Tinned-Copper (CCKE) CHO-FOIL; max roll width of 12”, lengths of 18 or 36 yards. • Foil tapes are available with single or double-sided, electrically conductive, pressure sensitive acrylic adhesive (PSA) • Optionally, CHO-FOIL tapes are available with electrically non-conductive PSA • Available as rotary kiss cut parts on rolls, die-cut parts, or in slit roll widths from .500”. Roll lengths are 18 or 36 yards. CHO-FOIL® and CHO-FAB® - Product Information CHO-FOIL® and CHO-FAB® - Product Information Table 1 NOTE: The following table represents actual experimental test data taken according to Parker Chomerics internal test procedures. This data differs from Table 1 due to differences in test methods. PROPERTIES Typical Values Property Test Method Part Number Prefix - CCH CCE CCJ CCK CCD CAD CFT Foil/Fabric Type - 1 oz. RA Copper 1 oz. Embossed RA Copper Aluminum 1 oz. Tin-Plated Copper 1 oz. RA Copper Aluminum Nickel-Plated Silver Foil/Fabric Thickness, mils (mm) - 1.4 (0.0356) 1.4 (0.0356) 2 (0.0508) 1.6 (0.0406) 1.4 (0.0356) 2 (0.0508) 5 (0.127) Adhesive Type - Adhesive Thickness, mils (mm) - Total Thickness, mils (mm) - CHO-FOIL CHO-FAB 2 sides: 1.5 each (0.0381 each) 1.5 (0.0381) 2.9 (0.0737) 4* (0.1102) 3.5 (0.0889) 3.1 (0.0787) 4.4 (0.11180 5 (0.127) -40 to 400 (-40 to 205) TEST DATA 1.5 (0.0381)
CCK-18-101-0200 价格&库存
很抱歉,暂时无法提供与“CCK-18-101-0200”相匹配的价格&库存,您可以联系我们找货
