T-WING® HEAT SPREADERS
Thin Heat Spreaders
Parker Chomerics’ family of thin heat spreaders provides a
low-cost, effective means of cooling IC devices in restricted
spaces where conventional heat sinks are inappropriate.
FEATURES/BENEFITS
TYPICAL APPLICATIONS
DESIGN DETAILS
TESTING SUMMARY
Microprocessors
Memory modules
• Laptop PCs and other high
density, handheld portable
electronics
• High speed disk drives
Low profile (0.33 mm/0.013 in)
allows use in limited space
environments
Easy peel and stick adhesion to all
surfaces, including packages with
residual silicone mold release
Offers low cost cooling for many
package types
Low application force
(80 days, no failure
P.S.T.C. No. 7
2
Environmental Stress Thermal Performance
Environment
Before
After
Rj-a, °C/W Restricted Convection
20.3
20.6
Rj-a, °C/W 100 LFM
12.7
13.1
Environmental Stress Adhesive Performance
Environment
Heat Aging
High Temperature/Humidity
90° Peel Strength
oz/in
gm/cm
Control
36
393
Heat Aging
36
393
46
514
21.4
21.4
Temperature Shock
38
424
Rj-a, °C/W 100 LFM
14.1
14
Temperature Cycling
30
335
Temperature Cycling
Note: Average of three samples tested per ASTM B571/D2861.
21.4
21.7
Rj-a, °C/W 100 LFM
14.1
13.9
Note: Tested with a 1” x 4” (25.4 x 101.6 mm) T-WING.
Phone +1 781-935-4850 www.parker.com/chomerics
4
Ordering Information
T-WING® Heat Spreaders
Standard Parts: Refer to table below for part numbers and sizes. T-WING
heat spreaders are available in standard packages of 100 parts/pkg.
Custom Parts: Custom configured T-WING parts are also available. Contact
Parker Chomerics’ Applications Engineering Department for details.
Available in standard sizes 1,000 parts per plastic tray. Also available die-cut
on continuous rolls.
A
B
C
Folding Scores
0.0015 in. Black PET
0.007 in. RA Copper
Release Liner
0.002 in. Thermattach PSA
Part Numbers
Size (inches/mm)
A: Length, inches (mm)
B: Width, inches (mm)
C: Adhesive Width, inches (mm)
60-12-20264-TW10
2.0 (50.8)
0.50 (12.7)
0.50 (12.7)
60-12-20265-TW10
3.0 (76.2)
0.50 (12.7)
0.50 (12.7)
60-12-20266-TW10
3.0 (76.2)
0.75 (19.1)
0.75 (19.1)
60-12-20267-TW10
3.0 (76.2)
1.00 (25.4)
1.00 (25.4)
60-12-20268-TW10
4.0 (101.6)
1.00 (25.4)
1.00 (25.4)
60-12-20269-TW10
4.0 (101.6)
1.50 (38.1)
1.50 (38.1)
5
很抱歉,暂时无法提供与“60-12-20264-TW10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+43.534051+5.64851
- 10+38.4964610+4.99489
- 25+36.6696325+4.75786
- 50+35.3468850+4.58623
- 100+34.06889100+4.42041
- 250+32.44833250+4.21015
- 500+31.77728500+4.12308
