65-00-GEL25NS-0030-M
    PARKERCHOMERICS
    CHOMERICS - 65-00-GEL25NS-0030-M - Thermally Conductive Material, Dispensable Gel, Urethane2.5W/m.K
65-00-GEL25NS-0030-M 数据手册
THERM-A-GAPTM GEL 25NS High Performance Fully Cured Dispensable GEL Customer Value Proposition: Parker Chomerics THERM-A-GAP GEL 25NS is a one component, dispensable thermal interface material with 2.5 W/m-K thermal conductivity developed to conduct heat from electronics to a heat sink or enclosure. This non-silicone thermal gel, hence the “NS” moniker, is ideal for applications where silicone contamination is an issue and requires no mixing or curing. THERM-A-GAP GEL 25NS requires low compressive force to deform under assembly pressure subjecting components, solder joints and leads to minimal stresses. It is formulated to accommodate today’s high performance electronics and is ideal for automated dispensing machines, rework and field repair situations. Contact Information: Parker Hannifin Corporation Chomerics Division 77 Dragon Court Woburn, MA 01801 phone 781 935 4850 fax 781 933 4318 chomailbox@parker.com www.parker.com/chomerics Features and Benefits: Typical Applications: • • • • • • • Thermal conductivity: 2.5 W/m-K Easily dispensed No secondary curing required Low thermal impedance Ultra-low compression force Reworkable Non-silicone Packaging and Handling: • • • • • Telecom base stations Power supplies and semiconductors Memory and power modules Microprocessors Central processing units (CPUs) Material may be packaged in syringes, cartridges or bulk packaged in pails. Product Information THERM-A-GAP GEL 25NS Typical Properties* GEL 25NS Test Methods Yellow Visual Flow Rate, g/min - 30cc syringe with no tip, 0.100” orifice, 90psi (621 kPa) 15 Chomerics Specific Gravity 2.6 ASTM D792 0.004 (0.11) Chomerics Thermal Conductivity, W/m-K 2.5 ASTM D5470 Heat Capacity, J/g-K 0.96 ASTM E1269 Coefficient of Thermal Expansion, ppm/K < 300 ASTM E831 -58 to 257 (-55 to 125) Chomerics 200 (8.0) Chomerics Volume Resistivity, ohm-cm 14 10 ASTM D257 Dielectric Constant @ 100 kHz 6.7 ASTM D150 Dissipation Factor @ 100 kHz 0.018 Chomerics Flammability Rating V-0 UL 94 RoHS Compliant Yes Chomerics Certification 0.23, 0.04 ASTM E595 12 Chomerics Physical Color Thermal Typical minimum bondline thickness, in (mm) Operating Temperature Range °F (°C) Regulatory Electrical Dielectric Strength, Vac / mil (kVac/mm) Outgassing, % TML, % CVCM Shelf Life, months from date of manufacture * Typical properties: these are not to be construed as specifications. Part Number Standard Fill Volume (cc) Standard Fill Mass (g) Description 65-00-GEL25NS-0010-M 10 26 10cc manual dispense syringe 65-00-GEL25NS-0030-M 27 70 30cc EFD plastic cartridge 65-00-GEL25NS-0055-M 52 135 55cc EFD plastic cartridge 65-00-GEL25NS-0180-M 150 390 6oz SEMCO plastic cartridge 65-00-GEL25NS-0300-M 290 750 Aluminum caulking cartridge 65-00-GEL25NS-0610-M 570 1,480 20oz SEMCO plastic cartridge 65-00-GEL25NS-9KG-M 3,300 8,580 1 US gal. pail www.parker.com/chomerics CHOMERICS is a registered trademark of Parker Hannifin Corporation. ® 2020 Parker Chomerics THERM-A-GAP GEL 25NS June 2020
65-00-GEL25NS-0030-M 价格&库存
很抱歉,暂时无法提供与“65-00-GEL25NS-0030-M”相匹配的价格&库存,您可以联系我们找货
