82-121-74019-G8708
82-121-74019-G8708
    PARKERCHOMERICS
    Gasket, EMI Shielding, Nylon Ripstop Fabric over Foam, 1 m, 2.3 mm x 2.3 mm, 90 dB
82-121-74019-G8708 数据手册
SOFT-SHIELD® 5000 Low Closure Force, Conductive Fabric Jacket over Foam core EMI Gaskets Customer Value Proposition: SOFT-SHIELD® 5000 Series gaskets offer a low cost and high performance EMI gasketing solution for commercial electronic systems. The high reliability conductive fabric over foam core construction provides a cost effective alternative to beryllium copper or stainless steel fingerstock EMI gaskets. Applications for these conductive fabric over urethane foam core gaskets include; commercial electronic enclosures, medical electronics and general industrial applications. The variety of available cross-section profiles allow for very low closure forces, thus offering a minimization of the number of necessary fasteners for easy, user friendly installation, without an effect to shielding effectiveness. Cut-to-length strips of gasket are self terminating thereby enhancing the reliability of the application. The urethane foam core has excellent compressibility making the gasket material especially attractive for thin-walled plastic enclosures. Gaskets are offered standard with a UL 94 V-0 flammability rating. Contact Information: Parker Hannifin Corporation Chomerics Division 77 Dragon Court Woburn, MA 01801 phone 781 935 4850 fax 781 933 4318 chomailbox@parker.com www.chomerics.com www.parker.com/chomerics Product Features: • Low closure force required for optimum performance. • Provides shielding effectiveness over 90 dB from 10 MHz to 10 GHz. • Silver nickel-plated, woven, ripstop nylon jacket over highly compressible urethane foam core. • Supplied standard with a pressure sensitive acrylic based adhesive (PSA) • Self terminating jacket – no loose fibers or sharp edges when gasket is cut. • No degradation of shielding effectiveness after 10,000 deflection cycles. • Supplied in standard 8 foot lengths in multiple cross section styles including rectangular, square, D-shape, C-fold, astragel, P-shape, triangular, and knife-edge with rigid inserts. Custom profiles are also possible. • Available as kiss-cut parts on polyester film release liner for “peel and stick applications. • Available as individual pre-cut pieces . • Single-piece “picture frame” gaskets can also be fabricated from continuous lengths, incorporating integral pre-cut notches. • UL 94V-0 rated. • RoHS & REACH compliant Gasket prof Designates SOFT-SHIELD 5000 EMI gaskets A Jacket Type SOFT-SHIELD 5000 - Available Profiles 1 Nickel-plated nylon rip-stop fabric Contact Chomerics for any other special requirements and an updated profile list. 2 Other (to be assigned) ® ORDERING INFORMATION Referring to Tables 1-9 to order SOFT-SHIELD 5000 Series gasketing. B PSA Tape Backing 1 No PSA tape 2 PSA tape RECTANGULAR PRO 74005, 74021 Compression (lbs/lin.inch) 1.8 1.6 1.4 T 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 40 50 40 50 Deflection (%) 74021 Table 1 74005 RECTANGULAR STRIPS inches (mm) Height Width 0.020 (0.50) 0.157 (4.00) 0.039 (1.00) 0.157 (4.00) 74003 0.039 (1.00) 0.197 (5.00) 74038 0.039 (1.00) 0.275 (7.00) 74004 0.039 (1.00) 0.394 (10.00) 74035 0.059 (1.50) 0.157 (4.00) 74040 0.062 (1.60) 0.200 (5.00) 74034 0.071 (1.80) 0.551 (14.00) 74002 0.079 (2.00) 0.157 (4.00) 74005 0.079 (2.00) 0.275 (7.00) 74066 0.079 (2.00) 0.355 (9.00) 7.5 6 4.5 3 1.5 0 0 10 20 30 Deflection (%) 74003 74004 74020 74035 74038 5 Compression (lbs/lin.inch) 74039 74020 74003, 74004, 74020, 74035 9 Compression (lbs/lin.inch) Profile Number 4 3 2 1 0 0 5 10 15 20 25 30 35 Deflection (%) NOTE: Compression/deflection curves are typical. Dimensions shown do not include P All SOFT-SHIELD 5000 Series profiles can be supplied in eit NOTE: Dimensions shown do not include PSA thickness (0.005 inch typically). All SOFT-SHIELD 5000 Series profiles are supplied in UL 94V-0 rated versions. US Headquarters TEL: 781-935-4850 FA Europe TEL: +(44) 1628 4040 Asia Pacific TEL: +(852) 2 428 SOFT-SHIELD® 5000 - Available Profiles 74002, 74023 Compression (lbs/lin.inch) 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 40 50 30 40 50 30 40 50 30 40 50 Deflection (%) 74002 74023 74000, 74015, 74025 RECTANGULAR STRIPS inches (mm) Profile Number Height Width 74025 0.079 (2.00) 0.394 (10.00) 74049 0.079 (2.00) 0.827 (21.00) 74099 0.090 (2.30) 0.157 (4.00) 74102 0.098 (2.50) 0.870 (22.00) 74048 0.118 (3.00) 0.157 (4.00) 74023 0.125 (3.18) 0.250 (6.35) 74000 0.125 (3.18) 0.375 (9.53) 74012 0.125 (3.18) 0.500 (12.70) 74001 0.125 (3.18) 0.800 (20.32) 74015 0.130 (3.30) 0.190 (4.83) 74054 0.200 (5.00) 0.300 (7.60) 74016 0.250 (6.35) 0.375 (9.53) 74014 0.250 (6.35) 0.500 (12.70) 74021 0.375 (9.53) 0.500 (12.70) 3 2.5 2 1.5 1 0.5 0 0 10 20 Deflection (%) 74000 74015 74025 74012, 74001 3.5 Compression (lbs/lin.inch) Table 1 continued Compression (lbs/lin.inch) 3.5 3 2.5 2 1.5 1 0.5 0 0 10 20 Deflection (%) 74012 74001 Compression (lbs/lin.inch) 74014, 74016 1 0.8 0.6 0.4 0.2 0 0 10 20 Deflection (%) 74014 74016 NOTE: Dimensions shown do not include PSA thickness (0.005 inch typically). All SOFT-SHIELD 5000 Series profiles are supplied in UL 94V-0 rated versions. SOFT-SHIELD® 5000 - Available Profiles 74024, 74022, 74018 Compression (lbs/lin.inch) 1.4 Table 2 1.2 1 0.8 0.6 0.4 0.2 0 SQUARE STRIPS inches (mm) Height Width 74018 0.118 (3.00) 0.118 (3.00) 74017 0.200 (5.00) 0.200 (5.00) 74022 0.236 (6.00) 0.236 (6.00) 74118 0.250 (6.35) 0.250 (6.35) 74024 0.375 (9.53) 0.375 (9.53) 74028 0.500 (12.70) 0.500 (12.70) 10 20 30 40 50 40 50 Deflection (%) 74024 74022 74018 74017, 74028 1.6 1.4 Compression (lbs/lin.inch) Profile Number 0 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 Deflection (%) 74017 74028 74037 D-STRIPS inches (mm) Profile Number Height Width 74037 0.060 (1.52) 0.150 (3.80) 74081 0.070 (1.78) 0.250 (6.35) 74019 0.090 (2.30) 0.090 (2.30) 74031 0.090 (2.30) 0.150 (3.80) 74053 0.100 (2.54) 0.250 (6.35) 74052 0.108 (2.74) 0.150 (3.80) 74055 0.110 (2.79) 0.225 (5.72) 74074 0.110 (2.79) 0.380 (9.65) 74013 0.120 (3.05) 0.150 (3.80) 3 2 1 0 Compression (lbs/lin.inch) Table 3 Compression (lbs/lin.inch) 4 0 5 10 15 30 25 20 Deflection (%) 35 74019, 74031 1 0.8 0.6 0.4 0.2 0 0 10 20 30 Deflection (%) 74019 74031 NOTE: Dimensions shown do not include PSA thickness (0.005 inch typically). All SOFT-SHIELD 5000 Series profiles are supplied in UL 94V-0 rated versions. 40 50 SOFT-SHIELD® 5000 - Available Profiles 74006, 74029, 74033, 74036 Compression (lbs/lin.inch) 1.2 Table 3 continued D-STRIPS inches (mm) Height 74036 0.120 (3.05) 0.250 (6.35) 74006 0.140 (3.56) 0.250 (6.35) 74058 0.141 (3.58) 0.360 (9.14) 74056 0.155 (3.94) 0.250 (6.35) 74041 0.157 (4.00) 0.150 (3.80) 74030 0.157 (4.00) 0.236 (6.00) 74033 0.180 (4.57) 0.400 (10.16) 74011 0.250 (6.35) 0.375 (9.53) 74029 0.375 (9.53) 0.500 (12.70) 0.6 0.4 0.2 0 Width 0 10 20 74006 74029 74033 Height Width 74057 0.250 (6.35) 0.280 (7.11) 74008 0.385 (9.78) 0.420 (10.67) 74027 0.465 (11.81) 0.420 (10.67) Compression (lbs/lin.inch) Profile Number 50 40 50 74036 74011, 74013, 74030 0.8 0.6 0.4 0.2 0 0 10 74013 20 30 Deflection (%) 74030 74008, 74027 1.4 C-FOLD STRIPS inches (mm) 40 1 74011 Table 4 30 Deflection (%) Compression (lbs/lin.inch) Profile Number 1 0.8 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 40 50 60 70 Deflection (%) 74008 74027 74010 0.9 Table 5 ASTRAGEL STRIPS inches (mm) Profile Number Height Width 74010 0.675 (17.14) 0.580 (14.73) Compression (lbs/lin.inch) 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 0 5 15 25 35 45 Deflection (%) NOTE: Dimensions shown do not include PSA thickness (0.005 inch typically). All SOFT-SHIELD 5000 Series profiles are supplied in UL 94V-0 rated versions. 55 65 75 SOFT-SHIELD® 5000 - Available Profiles 74009 Table 6 P-STRIPS inches (mm) inches (mm) Profile Profile Number Height Width P Shape 74009 0.130 (3.30) 0.520 (13.20) Compression (lbs/lin.inch) 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 40 50 30 40 50 Deflection (%) 74042 Table 7 TRIANGULAR STRIPS inches (mm) Profile Profile Number Height Width Triangle Shape 74063 0.118 (3.00) 0.150 (3.81) Triangle Shape 74042 0.782 (19.86) 0.882 (22.40) Compression (lbs/lin.inch) 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 Deflection (%) KNIFE-EDGE STRIPS inches (mm) Profile Knife Shape Profile Number Height Width 74007 0.106 (2.69) 0.445 (11.30) Table 9 Compression (lbs/lin.inch) Rigid Insert Table 8 16 14 12 10 8 6 4 2 0 OTHER SOFT-SHIELD 5000 PROFILES inches (mm) Profile 74007 18 Profile Number Height Width Stealth Shape 74059 0.080 (2.03) 0.675 (17.15) Stealth Shape 74101 0.100 (2.54) 0.393 (9.98) Stealth Shape 74095 0.120 (3.05) 0.400 (10.16) Stealth Shape 74084 0.134 (3.40) 0.625 (15.88) Clip Shape 74045 0.200 (5.08) 0.156 (3.96) Clip Shape 74077 0.240 (6.10) 0.296 (7.52) T-Slot Shape 74079 0.180 (4.57) 0.375 (9.52) Tall D Shape 74032 0.126 (3.20) 0.090 (2.29) 0 5 10 15 20 25 Deflection (%) H W NOTE: Dimensions shown do not include PSA thickness (0.005 inch typically). All SOFT-SHIELD 5000 Series profiles are supplied in UL 94V-0 rated versions. 30 35 SOFT-SHIELD® 5000 - Product Information Table 10 Table 11 Typical Properties Property Dimensional Tolerances Test Method SOFT-SHIELD 5000 Shielding Effectiveness CHO-TM-TP08 See Figure 1 Compression-Deflection ASTM C165 (modified) See Graphs per Profile ASTM D3574 (modified)
82-121-74019-G8708 价格&库存
很抱歉,暂时无法提供与“82-121-74019-G8708”相匹配的价格&库存,您可以联系我们找货
