CHO-FOIL®and CHO-FABTM
EMI Shielding Foil and Fabric Tape with Conductive Adhesive
Customer Value
Proposition:
Parker Chomerics CHO-FOIL® metal foil tapes provide an
economical solution to applications requiring excellent
electrical conductivity across substrates. These foil tapes
can provide a low impedance connection between a braided
cable shield and the metal connector backshell in molded
cables. Due to the highly conductive pressure sensitive
acrylic adhesive (PSA), the tape can provide an effective
shielded cable assembly without the need for soldering
the tape to the braid. The uniform dispersion of unique,
oxidation-resistant conductive particles in the acrylic PSA
produce a very low resistance through the tape. Thus,
wrapping a cable assembly with the foil tape, using a slight
overlap, can provide an effective prototype cable shielding
system.
Seams of EMI shielded rooms and other shielded test
enclosure setups are more easily sealed with CHO-FOIL
tape so as to provide electrical continuity and thus higher
shielding effectiveness. Double-sided conductive adhesive
is available to ensure leak free seams. The use of CHO-FOIL
tape can ensure good electrically conductive mating flanges
and corrosion resistant grounding areas.
For applications requiring lighter weight and a more flexible
electrically conductive tape, the electrically conductive
fabric tape, CHO-FABTM, will provide excellent shielding
and good corrosion resistant performance. In the case of
shielded cables, CHO-FAB is very conformable, strong,
lightweight, and doesn’t have sharp edges that are present
on metal foil tapes.
Contact Information:
Parker Hannifin Corporation
Chomerics Division
77 Dragon Court
Woburn, MA 01801
phone 781 935 4850
fax 781 933 4318
chomailbox@parker.com
www.parker.com/chomerics
Product Features:
• Available in copper, aluminum, and tin-plated copper
foils, or nickel-plated silver fabric.
• Embossment available on Copper (CCE) and
Tinned-Copper (CCKE) CHO-FOIL; max roll width of
12”, lengths of 18 or 36 yards.
• Foil tapes are available with single or double-sided,
electrically conductive, pressure sensitive acrylic
adhesive (PSA)
• Optionally, CHO-FOIL tapes are available with
electrically non-conductive PSA
• Available as rotary kiss cut parts on rolls, die-cut
parts, or in slit roll widths from .500”. Roll lengths are
18 or 36 yards.
CHO-FOIL® and CHO-FAB® - Product Information
Table 1
NOTE: The following table represents actual experimental test data taken according to Parker Chomerics internal test
procedures. This data differs from Table 1 due to differences in test methods.
PROPERTIES
Typical Values
Property
Test Method
Part Number Prefix
CCH
CCE
CCJ
CCK
CCD
CAD
CFT
Foil/Fabric Type
1 oz. RA
Copper
1 oz. Embossed
RA Copper
Aluminum
1 oz. Tin-Plated
Copper
1 oz. RA
Copper
Aluminum
Nickel-Plated
Silver
Foil/Fabric Thickness, mils (mm)
1.4 (0.0356)
1.4 (0.0356)
2 (0.0508)
1.6 (0.0406)
1.4 (0.0356)
2 (0.0508)
5 (0.127)
Adhesive Type
Adhesive Thickness, mils (mm)
Total Thickness, mils (mm)
CHO-FOIL
CHO-FAB
2 sides: 1.5 each
(0.0381 each)
1.5 (0.0381)
2.9 (0.0737)
4* (0.1102)
3.5 (0.0889)
3.1 (0.0787)
4.4 (0.11180
5 (0.127)
-40 to 400
(-40 to 205)
TEST DATA
1.5 (0.0381)
很抱歉,暂时无法提供与“CCH-18-101-0050”相匹配的价格&库存,您可以联系我们找货
