60-12-20266-TW10
60-12-20266-TW10
    PARKERCHOMERICS
    热垫 黑色 76.20mm x 19.05mm 矩形 粘贴 - 双侧
60-12-20266-TW10 数据手册
T-WING® HEAT SPREADERS Thin Heat Spreaders Parker Chomerics’ family of thin heat spreaders provides a low-cost, effective means of cooling IC devices in restricted spaces where conventional heat sinks are inappropriate. FEATURES/BENEFITS TYPICAL APPLICATIONS DESIGN DETAILS TESTING SUMMARY Microprocessors Memory modules • Laptop PCs and other high density, handheld portable electronics • High speed disk drives • • • • • • • • • • • • Low profile (0.33 mm/0.013 in) allows use in limited space environments Easy peel and stick adhesion to all surfaces, including packages with residual silicone mold release Offers low cost cooling for many package types Low application force (80 days, no failure P.S.T.C. No. 7 2 Environmental Stress Thermal Performance Environment Before After Rj-a, °C/W Restricted Convection 20.3 20.6 Rj-a, °C/W 100 LFM 12.7 13.1 Environmental Stress Adhesive Performance Environment Heat Aging High Temperature/Humidity 90° Peel Strength oz/in gm/cm Control 36 393 Heat Aging 36 393 High Temperature/Humidity 46 514 Rj-a, °C/W Restricted Convection 21.4 21.4 Temperature Shock 38 424 Rj-a, °C/W 100 LFM 14.1 14 Temperature Cycling 30 335 Temperature Cycling Note: Average of three samples tested per ASTM B571/D2861. Rj-a, °C/W Restricted Convection 21.4 21.7 Rj-a, °C/W 100 LFM 14.1 13.9 Note: Tested with a 1” x 4” (25.4 x 101.6 mm) T-WING. Phone +1 781-935-4850 www.parker.com/chomerics 4 Ordering Information T-WING® Heat Spreaders Standard Parts: Refer to table below for part numbers and sizes. T-WING heat spreaders are available in standard packages of 100 parts/pkg. Custom Parts: Custom configured T-WING parts are also available. Contact Parker Chomerics’ Applications Engineering Department for details. Available in standard sizes 1,000 parts per plastic tray. Also available die-cut on continuous rolls. A B C Folding Scores 0.0015 in. Black PET 0.007 in. RA Copper 0.0015 in. Black PET Release Liner 0.002 in. Thermattach PSA Part Numbers Size (inches/mm) A: Length, inches (mm) B: Width, inches (mm) C: Adhesive Width, inches (mm) 60-12-20264-TW10 2.0 (50.8) 0.50 (12.7) 0.50 (12.7) 60-12-20265-TW10 3.0 (76.2) 0.50 (12.7) 0.50 (12.7) 60-12-20266-TW10 3.0 (76.2) 0.75 (19.1) 0.75 (19.1) 60-12-20267-TW10 3.0 (76.2) 1.00 (25.4) 1.00 (25.4) 60-12-20268-TW10 4.0 (101.6) 1.00 (25.4) 1.00 (25.4) 60-12-20269-TW10 4.0 (101.6) 1.50 (38.1) 1.50 (38.1) Phone +1 781-935-4850 www.parker.com/chomerics 5
60-12-20266-TW10 价格&库存
很抱歉,暂时无法提供与“60-12-20266-TW10”相匹配的价格&库存,您可以联系我们找货
60-12-20266-TW10
  • 1+37.16118
  • 50+34.00509
  • 100+31.66769
