FR257
FR257
    YFSEMI(江苏佑风微)
    DO-15(DO-204AC)
    FR257
FR257 数据手册
佑风电子 YFSEMI ELECTRON FR251 – FR257 Features ! ! ! ! ! Diffused Junction Low Forward Voltage Drop High Current Capability High Reliability High Surge Current Capability A B A Mechanical Data ! ! ! ! ! ! ! C Case: DO-15, Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.40 grams (approx.) Mounting Position: Any Marking: Type Number Lead Free: For RoHS / Lead Free Version D DO-15 Min Max Dim 24.5 — A 7.62 5.50 B 0.60 0.80 C 2.60 3.60 D All Dimensions in mm Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current (Note 1) @TA = 75°C Symbol FR251 FR252 FR253 FR254 FR255 FR256 FR257 Unit VRRM VRWM VR 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V IO 2.5 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 60 A Forward Voltage @IF = 2.5A VFM 1.3 V @TA = 25°C @TA = 100°C IRM 5.0 100 µA Peak Reverse Current At Rated DC Blocking Voltage Reverse Recovery Time (Note 2) trr Typical Junction Capacitance (Note 3) Cj 30 pF Operating Temperature Range Tj -65 to +150 °C TSTG -65 to +150 °C Storage Temperature Range 150 250 500 nS Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Measured with IF = 0.5A, IR = 1.0A, IRR = 0.25A. See figure 5. 3. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C. FR251 – FR257 1 of 2 www.yfsemi.com 佑风电子 YFSEMI ELECTRON 10 4 Single phase half wave Resistive or Inductive load 3 2 1 1.0 0.1 Tj = 25°C Pulse width = 300µs 0.01 0 0 25 50 A, 75 100 125 150 0.6 175 AMBIENT TEMPERATURE (°C) Fig. 1 Forward Derating Curve 0.8 1.0 1.2 1.4 VF, INSTANTANEOUS FORWARD VOLTAGE (V) Fig. 2 Typical Forward Characteristics 60 100 Cj, CAPACITANCE (pF) IFSM, PEAK FORWARD SURGE CURRENT (A) IF, INSTANTANEOUS FWD CURRENT (A) I(AV), AVERAGE FWD RECTIFIED CURRENT (A) FR251 – FR257 40 20 TA = 25°C f = 1.0MHz 10 1 0 1 10 1 100 10 100 VR, REVERSE VOLTAGE (V) Fig. 4 Typical Junction Capacitance NUMBER OF CYCLES AT 60Hz Fig. 3 Peak Forward Surge Current trr +0.5A 50Ω NI (Non-inductive) 10Ω NI Device Under Test (-) 0A (+) Pulse Generator (Note 2) 50V DC Approx (-) 1.0Ω NI Oscilloscope (Note 1) -0.25A (+) Notes: 1. Rise Time = 7.0ns max. Input Impedance = 1.0MΩ, 22pF. 2. Rise Time = 10ns max. Input Impedance = 50Ω. -1.0A Set time base for 5/10ns/cm Fig. 5 Reverse Recovery Time Characteristic and Test Circuit FR251 – FR257 2 of 2 www.yfsemi.com
FR257 价格&库存
很抱歉,暂时无法提供与“FR257”相匹配的价格&库存,您可以联系我们找货
