ER1604FCT
ER1604FCT
    YFSEMI(江苏佑风微)
    ITO-220AB
    ER1604FCT
ER1604FCT 数据手册
佑风电子 YFSEMI ELECTRON ER1600FCT~ER1606FCT ISOLATION SUPERFAST RECOVERY RECTIFIER 16 Ampere VOLTAGE 50 to 600 Volt CURRENT FEATURES • Plastic package has Underwriters Laboratory Flammability Classification 94V-O. Flame Retardant Epoxy Molding Compound. • Low power loss, high efficiency. • Low forward voltge, high current capability • High surge capacity. • Super fast recovery times, high voltage. • Epitaxial chip construction. • Lead free in compliance with EU RoHS 2011/65/EU directive • Green molding compound as per IEC61249 Std. . (Halogen Free) MECHANICAL DATA • Case: ITO-220AB Molded plastic • Terminals: Lead solderable per MIL-STD-750, Method 2026 • Polarity: As marked. • Standard packaging: Any • Weight: 0.056 ounces, 1.6 grams. MAXIMUM RATING AND ELECTRICAL CHARACTERISTICSS Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% PA RA M ET ER SY M BO L ER 1 6 0 0 FC T ER 1 6 0 1 FC T E R1 6 0 1 A FC T E R1 6 0 2 F CT E R1 6 0 3 F CT ER 1 6 04 F C T E R 1 60 6 F C T UNI TS M a ximum Re c ur r e nt P e a k Re ve r s e Vo lt a g e V RRM 50 10 0 150 200 300 400 600 V M a ximum RM S Vo lt a g e V RM S 35 70 10 5 140 210 280 420 V M a ximum DC Blo c k ing Vo lt a g e V DC 50 10 0 150 200 300 400 600 V M a ximum Ave r a g e Fo r w a r d Cur r e nt a t T C = 9 0 O C I F ( AV) 16 A P ea k Fo r w a r d Sur g e Cur r e nt , 8 . 3 ms s ing le half s ine w a ve s up e r imp o s e d o n r a t e d lo a d I F SM 125 A M a ximum Fo r w a r d Vo lt a g e a t 8 A VF M a ximum DC Re ve r s e Cur r e nt a t T J = 2 5 O C Ra t e d DC B lo c k ing Vo lt a g e T J = 1 0 0 O C IR 1 500 μA M a ximum Re ve r s e Re c o ve r y Time ( No t e 2 ) t rr 35 ns Ty p ic a l J unc t io n Ca p a c it a nc e ( No t e 1 ) CJ 62 pF R θJ C 3 T J, T STG -50 to +150 0.95 1.3 1.7 V O Ty p ic a l The r ma l Re s is t a nc e O p e r a t ing a nd St o r a ge Te mp e r a t ur e Ra ng e C / W O C NOTES : 1. Measured at 1 MHz and applied reverse voltage of 4 VDC. 2. Reverse Recovery Test Conditions: IF=0.5A, IR=1A, Irr=0.25A. 3. Both Bonding and Chip structure are available. www.yfsemi.com 佑风电子 YFSEMI ELECTRON ER1600FCT~ER1606FCT 40 INSTANTANEOUS FORWARD CURRENT AMPERES AVERAGE FORWARD CURRENT, AMPERES RATING AND CHARACTERISTIC CURVES 20 16 12 6 LEADLENGHTS RESISTIVEORINDUCTIVE LOAD 4 200V 300-400V 10 600V 1 O T J =25 C Pulse Width=300us 0 0 20 40 60 80 100 120 140 160 .1 .6 .8 1.0 1.2 1.4 1.6 1.8 2.0 O CASE TEMPERATURE, C INSTANTANEOUS FORWARD VOLTAGE, VOLTS Fig.2- TYPICAL INSTANTANEOUS FORWARD CHARACTERISTIC Fig.1- FORWARD CURRENT DERATING CURVE O TJ= 125 C 100 O TJ= 75 C 10 1.0 150 PEAK FORWARD SURGE CURRENT, INVSTANTANEOUS REVERSE CURRENT, MICROAMPERES 1000 125 8.3ms Single Half Since-Wave JEDEC Method 100 75 50 25 0 1 2 O TJ= 25 C 5 10 20 50 100 NO. OF CYCLE AT 60HZ Fig.4- MAXIMUM NON - REPETITIVE SURGE CURRENT 0.1 20 40 60 80 100 120 80 FIG.3 TYPICAL REVERSE CHARACTERISTICS CAPACITANCE, pF PERCENT OF RATED PEAK INVERSE VOLTGE, VOLTS 70 O TJ = 25 C 60 50 40 20 10 1 2 5 10 20 50 100 200 500 REVERSE VOLTAGE, VOLTS Fig.5- TYPICAL JUNCTION CAPACITANCE www.yfsemi.com 佑风电子 YFSEMI ELECTRON ER1600FCT~ER1606FCT Part No_packing code_Version ER1600FCT_T0_00001 For example : RB500V-40_R2_00001 Serial number Part No. Version code means HF Packing size code means 13" Packing type means T/R Packing Code XX Packing type Tape and Ammunition Box (T/B) Tape and Reel (T/R) Bulk Packing (B/P) Tube Packing (T/P) Tape and Reel (Right Oriented) (TRR) Tape and Reel (Left Oriented) (TRL) FORMING Version Code XXXXX 1st Code Packing size code A N/A 0 HF 0 serial number R 7" 1 RoHS 1 serial number B 13" 2 T 26mm X S 52mm Y L F PANASERT T/B CATHODE UP (PBCU) PANASERT T/B CATHODE DOWN (PBCD) 2nd Code HF or RoHS 1st Code 2nd~5th Code U D www.yfsemi.com
ER1604FCT 价格&库存
很抱歉,暂时无法提供与“ER1604FCT”相匹配的价格&库存,您可以联系我们找货
