UMW
R
AOD442
60V N-Channel MOSFET
General Description
D
The AOD442 used advanced trench technology to provide
excellent RDS(ON) and low gate charge. Those devices are
suitable for use as a load switch or in PWM applications.
G
General Features
S
VDS
60V
37A
ID (at VGS=10V)
RDS(ON) (at VGS=10V)
< 20mΩ
RDS(ON) (at VGS = 4.5V)
< 25mΩ
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
Continuous Drain
Current G
TC=25°C
Pulsed Drain Current
C
Continuous Drain
Current
Avalanche Current C
Avalanche energy L=0.1mH
C
TC=25°C
Power Dissipation
B
TA=25°C
Power Dissipation A
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
AD
Maximum Junction-to-Case
www.umw-ic.com
IAS, IAR
30
A
EAS, EAR
45
mJ
60
Steady-State
Steady-State
W
30
2.1
W
1.3
TJ, TSTG
-55 to 175
Symbol
t ≤ 10s
A
5
PDSM
TA=70°C
A
7
PD
TC=100°C
V
60
IDSM
TA=70°C
±20
26
IDM
TA=25°C
Units
V
37
ID
TC=100°C
Maximum
60
Typ
17.4
51
1.8
RθJA
RθJC
1
°C
Max
25
60
2.5
Units
°C/W
°C/W
°C/W
UTD Semiconductor Co.,Limited
UMW
R
AOD442
Electrical Characteristics (T J=25°C unless otherwise noted)
Parameter
Symbol
STATIC PARAMETERS
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
Conditions
Min
ID=250µA, VGS=0V
VDS=48V, VGS=0V
TJ=55°C
5
Gate-Body leakage current
VDS=0V, VGS= ±20V
Gate Threshold Voltage
On state drain current
VDS=VGS ID=250µA
1.6
VGS=10V, VDS=5V
60
Rg
Gate resistance
SWITCHING PARAMETERS
Qg(10V) Total Gate Charge
Qg(4.5V) Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
tD(on)
Turn-On DelayTime
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
A
mΩ
1
V
32
A
VDS=5V, ID=20A
65
0.7
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Output Capacitance
V
16
Diode Forward Voltage
IS=1A,VGS=0V
Maximum Body-Diode Continuous Current
Reverse Transfer Capacitance
nA
2.7
VGS=10V, ID=20A
Forward Transconductance
Crss
100
VGS=4.5V, ID=20A
VSD
Coss
2.1
µA
mΩ
gFS
IS
Units
V
1
IGSS
Static Drain-Source On-Resistance
Max
60
VGS(th)
ID(ON)
RDS(ON)
Typ
VGS=0V, VDS=30V, f=1MHz
VGS=0V, VDS=0V, f=1MHz
VGS=10V, VDS=30V, ID=20A
S
1535
1920
2300
pF
108
155
200
pF
70
116
165
pF
0.3
0.65
0.8
Ω
38
47.6
68
nC
30
nC
4.8
6
7
nC
8.5
14.4
nC
7.4
VGS=10V, VDS=30V, RL=1.5Ω,
RGEN=3Ω
ns
5.1
ns
28.2
ns
tf
Turn-Off Fall Time
trr
Body Diode Reverse Recovery Time
IF=20A, dI/dt=100A/µs
34
Qrr
Body Diode Reverse Recovery Charge IF=20A, dI/dt=100A/µs
46
5.5
ns
41
ns
nC
2
A. The value of RθJA is measured with the device mounted on 1in FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The
Power dissipation PDSM is based on R θJA and the maximum allowed junction temperature of 150°C. The value in any given application depends on
the user's specific board design, and the maximum temperature of 175°C may be used if the PCB allows it.
B. The power dissipation PD is based on TJ(MAX)=175°C, using junction-to-case thermal resistance, and is more useful in setting the upper
dissipation limit for cases where additional heatsinking is used.
C. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=175°C. Ratings are based on low frequency and duty cycles to keep initial
TJ =25°C.
D. The RθJA is the sum of the thermal impedence from junction to case R θJC and case to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AOD442”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.46308
- 50+1.15506
- 150+1.02298
- 500+0.85828
- 2500+0.75622
- 5000+0.71216
- 国内价格
- 1+1.08120
- 100+0.83130
- 1250+0.70380
- 2500+0.65280
