ESD0522P
ESD0522P
    UMW(友台)
    DFN1610-6L
    ESD 5V截止
ESD0522P 数据手册
ESD0522P Ultra Low Capacitance ESD Protection Array DESCRIPTION ESD0522P is an ultra-low capacitance Transient Voltage Suppressor (TVS) designed to protection for high-speed data interfaces. With typical capacitance of 0.2pF (I/O to I/O) only, ESD0522P is designed to protect parasitic-sensitive systems against over-voltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4(±15KV air, ±8KV contact discharge), IEC61000-4-4 (electrical fast transient-EFT) (40A, 5/50ns), very fast charged device model (CDM) ESD and cable discharge event(CDE),etc. ESD0522P uses ultra-small DFN1610-6L package. Each GESD0522P device can protect two high-speed data lines. The combined features of ultra-low capacitance, ultra-small size and high ESD robustness makes GESD0522P ideal for high-speed data ports and high-frequency lines (e.g., HDMI &DVI) applications. The low clamping voltage of the ESD0522P guarantees a minimum stress on the protected IC. FEATURES ■ Transient protection for high-speed data lines IEC 61000-4-2(ESD) ±15KV(Air) ±8KV(Contact) IEC 61000-4-4(EFT)40A(5/50ns) Cable Discharge Event(CDE) ■ Package optimized for high-speed lines ■ Protects two I/O lines ■ Ultra Low capacitance:0.2pf (typical between I/O channel) ■ Low operating and clamping voltages MACHANICAL DATA APPLICATIONS ■ High Definition Multi-Media Interface (HDMI) ■ DFN1610-6L package ■ USB 1.1/2.0/3.0/OTG ■ Flammability Rating: UL 94V-0 ■ IEEE 1394 Firewire Ports ■ Terminal: Matte tin plated. ■ ■ Packaging: Tape and Reel ■ Projection TV Monitors and Flat Panel Displays Notebook Computers ■ ■ Set Top Box High temperature soldering guaranted:260℃/10s Reel size: 7 inch www.umw-ic.com ■ 1 友台半导体有限公司 ESD0522P Ultra Low Capacitance ESD Protection Array ABSOLUTE MAXIMUM RATING Symbol Parameter Value Units PPP Peak Pulse Power (8/20μs) 60 W VESD ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) ±30 ±20 kV TOPT Operating Temperature -55/+125 C TSTG Storage Temperature -55/+150 C ELECTRICAL CHARACTERISTICS (Tamb=25C) Symbol Parameter Test Condition VRWM Reverse Working Voltage Any I/O pin to GND IT = 1mA Any I/O pin to GND VRWM = 5V IR Reverse Leakage Current Any I/O pin to GND IF = 15 mA VF Diode Forward Voltage Any I/O pin to GND IPP = 1A, tp = 8/20μs Any I/O pin to GND VC Clamping Voltage IPP = 4A, tp = 8/20μs Any I/O pin to GND Ground VR = 0V, f = 1MHz CESD Capacitance Between I/O and GND VR = 0V, f = 1MHz CESD Capacitance Between I/O and I/O Note: I/O pins are pin 1 and 2, GND pins are pin 3 and 4. VBR Reverse Breakdown Voltage www.umw-ic.com 2 Min Typ Max Units 5.0 V 6.0 V 100 nA 1.2 V 10 V 15 V 0.4 0.6 pF 0.2 0.3 pF 友台半导体有限公司 ESD0522P Ultra Low Capacitance ESD Protection Array ELECTRICAL CHARACTERISTICS CURVE www.umw-ic.com 3 友台半导体有限公司 ESD0522P Ultra Low Capacitance ESD Protection Array DFN1610-6L PACKAGE OUTLINE DIMENSIONS Marking 0522P Ordering information Order code UMW ESD0522P www.umw-ic.com Package DFN1610-6L 4 Base qty Delivery mode 3000 Tape and reel 友台半导体有限公司
ESD0522P
物料型号:UMW ESD0522P
器件简介: - ESD0522P是一款超低电容瞬态电压抑制器(TVS),专为高速数据接口的ESD保护设计。 - 典型电容仅为0.2pF,符合多种国际电工委员会(IEC)标准,包括ESD、EFT和CDE。
引脚分配: - 该器件使用DFN1610-6L封装,每个GESD0522P设备可以保护两条高速数据线。
参数特性: - 工作温度范围:-55°C至+125°C - 存储温度范围:-55°C至+150°C - 反向工作电压:5.0V - 反向击穿电压:6.0V - 反向漏电流:100nA(在5V反向工作电压下) - 二极管正向电压:1.2V - 钳位电压:在1A峰值脉冲电流下为10V,在4A峰值脉冲电流下为15V - 电容:在1MHz频率下,I/O到地或I/O到I/O的电容分别为0.4-0.6pF和0.2-0.3pF
功能详解: - 提供高速数据线的瞬态保护,包括ESD、EFT和CDE。 - 钳位电压低,对被保护的IC造成的压力小。
应用信息: - 适用于HDMI、USB、IEEE 1394 Firewire端口、投影电视监视器、平板显示器、笔记本电脑和机顶盒等。
封装信息: - DFN1610-6L封装,阻燃等级为UL 94V-0,端子为镀锡,采用胶带和卷轴包装,可承受260℃/10s的高温焊接。
订购信息: - 订购代码:UMW ESD0522P - 基础数量:3000 - 交货方式:胶带和卷轴
ESD0522P 价格&库存
很抱歉,暂时无法提供与“ESD0522P”相匹配的价格&库存,您可以联系我们找货
