UMW
R
AO4406A
11N06C
30V N-Channel Enhancement Mode MOSFET
Description
The AO4406A uses advanced trench technology
to provide excellent RDS(ON), low gate charge and
operation with gate voltages as low as 4.5V. This
device is suitable for use as a
Battery protection or in other Switching application.
General Features
VDS = 30V ID =12 A
RDS(ON) < 13mΩ @ V GS=10V
Application
Battery protection
Load switch
Uninterruptible power supply
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @ 10V1
12
A
ID@TA=70℃
8
A
IDM
Pulsed Drain Current2
30
A
EAS
Single Pulse Avalanche Energy3
mJ
IAS
Avalanche Current
22
A
PD@TA=25℃
Total Power Dissipation4
4.5
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
RθJA
Thermal Resistance Junction-ambient 1
50
℃/W
RθJC
Thermal Resistance Junction-Case1
30
℃/W
www.umw-ic.com
1
友台半导体有限公司
UMW
R
AO4406A
11N06C
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.027
V/℃
VGS=10V , ID=10A
10
13
RDS(ON)
VGS(th)
Static Drain-Source
Gate Threshold Voltage
VGS=4.5V , ID=8A
--1.2
12
1.5
16
2.5
mΩ
V
△VGS(th)
VGS(th) Temperature Coefficient
VGS=VDS , ID =250uA
-5.8
mV/℃
1
Drain-Source Leakage Current
VDS=24V , VGS=0V , TJ=25℃
IDSS
VDS=24V , VGS=0V , TJ=55℃
5
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=10A
5.8
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.2
3.8
Qg
Total Gate Charge (4.5V)
12.6
17.6
Qgs
Gate-Source Charge
4.2
5.9
Qgd
Gate-Drain Charge
5.1
7.1
Td(on)
Turn-On Delay Time
6.2
12.4
Tr
On-Resistance2
VDS=15V , VGS=4.5V , ID=10A
uA
nC
Rise Time
VDD=15V , VGS=10V , RG=3.3
59
106
Turn-Off Delay Time
ID=10A
27.6
55
Fall Time
8.4
16.8
Ciss
Input Capacitance
960
Coss
Output Capacitance
139
Crss
Reverse Transfer Capacitance
87
IS
Continuous Source Current1,5
10.3
A
42
A
1.2
V
12.5
nS
5
nC
Td(off)
Tf
ISM
VSD
Pulsed Source
Current2,5
Diode Forward
Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VDS=15V , VGS=0V , f=1MHz
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=10A ,
TJ=25℃
dI/dt=100A/µs
ns
pF
Note :
1 .The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3 .The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=35A
4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID
and IDM , in real applications , should be limited by total power dissipation.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
AO4406A
11N06C
Typical Characteristics
12
42
ID=10A
VGS=10V
35
ID Drain Current (A)
VGS=7V
11
RDSON (mΩ)
VGS=5V
28
VGS=4.5V
21
VGS=3V
9
14
8
7
6
1
1.5
2
2.5
VDS , Drain-to-Source Voltage (V)
2
3
4
6
8
10
VGS (V)
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. Gate-Source
Voltage
12
IS -Source Current(A)
10
8
TJ=150℃ TJ=25℃
6
4
2
0.6
0.9
VSD , Source-to-Drain Voltage (V)
Fig.3 Forward Characteristics of reverse
Fig.4 Gate-Charge Characteristics
diode
1.8
Normalized On Resistance
1.8
1.4
Normalized VGS(th)
1.4
1.0
1
0.6
0.6
0.2
0.2
-50
100
-50
150
Fig.5 Normalized VGS(th) vs. TJ
www.umw-ic.com
100
150
TJ , Junction Temperature (℃)
TJ ,Junction Temperature (℃ )
Fig.6 Normalized RDSON vs. TJ
3
友台半导体有限公司
UMW
R
AO4406A
11N06C
10000
100.00
F=1.0MHz
100us
10.00
1000
1ms
10ms
ID (A)
Capacitance (pF)
Ciss
1.00
Coss
100ms
100
Crss
0.10
DC
TA=25o C
Single Pulse
10
1
5
9
13
17
21
0.01
0.01
25
VDS , Drain to Source Voltage (V)
Fig.7 Capacitance
0.1
1
10
VDS (V)
100
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.01
P DM
T ON
0.01
T
D = TON/T
SINGLE
TJpeak = TC+P DMXRθJC
0.001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.11 Unclamped Inductive Switching Waveform
Fig.10 Switching Time Waveform
www.umw-ic.com
4
友台半导体有限公司
UMW
R
AO4406A
11N06C
SOP8 Package outline
Marking
("xxxx"代表年份周期)
Ordering information
Order code
Package
Baseqty
Deliverymode
UMW AO4406A
SOP-8
3000
Tape and reel
www.umw-ic.com
5
友台半导体有限公司
很抱歉,暂时无法提供与“AO4406A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.65340
- 200+0.42130
- 1500+0.36630
- 3000+0.32450
- 国内价格
- 5+0.70050
- 20+0.65380
- 100+0.60710
- 500+0.56040
- 1000+0.51370
- 2000+0.46700
- 国内价格
- 5+0.69477
- 50+0.55221
- 150+0.48093
- 500+0.42747
- 3000+0.32390
- 6000+0.30240
- 国内价格
- 5+0.63043
- 50+0.50107
- 600+0.38788
- 1200+0.38206
- 3000+0.29390
