UMW
R
AO4466
N-Channel MOSFET
General Description
D
The AO4466 uses advanced trench technology to
provide excellent RDS(ON) and low gate charge. This
device is suitable for use as a load switch or in PWM
applications. The source leads are separated to allow
a Kelvin connection to the source, which may be
used to bypass the source inductance.
G
S
Product Summary
VDS (V) = 30V
ID =10A
RDS(ON) < 18mΩ
RDS(ON) < 25mΩ
(VGS = 10V)
(VGS = 4.5V)
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
TA=25°C
Continuous Drain
AF
Current
Pulsed Drain Current
TA=70°C
TA=25°C
Avalanche Current B, G
B, G
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
Maximum Junction-to-Lead
www.umw-ic.com
C
V
±20
V
ID
7
IDM
64
A
3.1
PD
TA=70°C
Repetitive avalanche energy 0.1mH
Units
30
10
B
Power Dissipation
Maximum
W
2
IAR
12
A
EAR
7
mJ
-55 to 150
°C
TJ, TSTG
Symbol
t ≤ 10s
Steady-State
Steady-State
RθJA
RθJL
1
Typ
36
62
18
Max
40
75
24
Units
°C/W
°C/W
°C/W
UTD Semiconductor Co.,Limited
UMW
R
AO4466
N-Channel MOSFET
Electrical Characteristics (TJ=25°C unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
ID=250µA, VGS=0V
IDSS
Zero Gate Voltage Drain Current
IGSS
Gate-Body leakage current
VDS=0V, VGS= ±20V
VGS(th)
Gate Threshold Voltage
VDS=VGS ID=250µA
1
ID(ON)
On state drain current
VGS=4.5V, VDS=5V
64
RDS(ON)
Static Drain-Source On-Resistance
Min
30
VDS=30 VGS=0V
TJ=55°C
µA
5
1.5
100
nA
2.5
V
A
mΩ
VGS=4.5V, ID=5A
19
25
mΩ
VDS=5V, ID =3A
IS=1A,VGS=0V
17
Diode Forward Voltage
IS
Ciss
Coss
Maximum Body-Diode Continuous Current
Input Capacitance
VGS=0V, VDS=15V, f=1MHz
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Qg(10V)
Gate resistance
Total Gate Charge
Qgd
1
18
VSD
Gate Source Charge
Units
V
13
Forward Transconductance
Qgs
Max
VGS=10V, ID=10A
gFS
Qg(4.5V) Total Gate Charge
Typ
VGS=0V, VDS=0V, f=1MHz
VGS=10V, VDS=15V, ID=10A
S
0.75
1
V
298
373
2.4
448
A
pF
46
67
88
pF
24
41
58
pF
0.6
5.7
1.8
7.1
2.8
8.6
Ω
nC
2.7
3.5
4.2
nC
1.2
nC
Gate Drain Charge
1.6
nC
tD(on)
Turn-On DelayTime
4.3
ns
tr
Turn-On Rise Time
2.8
ns
tD(off)
Turn-Off DelayTime
15.8
ns
tf
trr
Turn-Off Fall Time
3
ns
VGS=10V, VDS=15V, RL=1.5Ω,
RGEN=3Ω
IF=10A, dI/dt=100A/µs
8.4
10.5
12.6
3.6
4.5
5.4
trr
Body Diode Reverse Recovery Charge IF=10A, dI/dt=100A/µs
IF=10A, dI/dt=500A/µs
Body Diode Reverse Recovery Time
4.7
6.0
7.2
Qrr
Body Diode Reverse Recovery Charge IF=10A, dI/dt=500A/µs
5.3
6.6
8
Qrr
ns
nC
ns
nC
A: The value of R θJA is measured with the device mounted on 1in 2 FR-4 board with 2oz. Copper, in a still air environment with
T A=25°C. The value in any given application depends on the user's specific board design.
B: Repetitive rating, pulse width limited by junction temperature.
C. The R θJA is the sum of the thermal impedence from junction to lead R θJL and lead to ambient.
D. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AO4466”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.44330
- 200+0.28600
- 1500+0.24860
- 3000+0.22000
- 国内价格
- 10+0.47898
- 100+0.37714
- 300+0.32627
- 3000+0.27929
- 6000+0.24873
- 9000+0.23350
- 国内价格
- 5+0.39967
- 50+0.34932
- 600+0.30533
