ESD5311N
ESD5311N
    UMW(友台)
    DFN1006-2
    TVS 5V截止
ESD5311N 数据手册
UMW R ESD5311N Descriptions The ESD5311N is an ultra-low capacitance TVS (Transient Voltage Suppressor) designed to protect high speed data interfaces. It has been specifically designed to protect sensitive electronic components which are connected to data and transmission lines from overPin2 Pin1 stress caused by ESD (Electrostatic Discharge). The ESD5311N incorporates one pair of ultralow capacitance steering diodes plus a TVS diode. The ESD5311N may be used to provide ESD protection up to ±20kV (contact discharge) according to IEC61000-4-2, and withstand peak pulse current up to 4A (8/20μs) according to IEC61000-4-5. The ESD5311N is available in DFN1006-2L package. Standard products are Pb-free and Halogen-free. Applications Features ■ Stand-off voltage: 5V Max ■ USB 2.0 and USB 3.0 ■ Transient protection for each line according to ■ HDMI 1.3 and HDMI 1.4 IEC61000-4-2 (ESD): ±20kV (contact discharge) ■ IEC61000-4-5 (surge): 4 A (8/20μs) ■ SATA and eSATA DVI ■ IEEE 1394 ■ PCI Express ■ Ultra-low capacitance: CJ = 0.25pF typ. ■ Ultra-low leakage current: IR < 1nA typ. ■ Low clamping voltage: VCL = 21V typ. @ IPP = 16A (TLP) ■ Solid-state silicon technology ■ Portable Electronics ■ Notebooks Absolute maximum ratings Parameter Symbol Rating Unit Peak pulse power (tp = 8/20μs) Ppk 84 W Peak pulse current (tp = 8/20μs) IPP 4 A ESD according to IEC61000-4-2 air discharge VESD ESD according to IEC61000-4-2 contact discharge Operation junction temperature Storage temperature www.umw-ic.com 1 ±20 kV 125 o TL 260 o TSTG -55~150 o TJ Lead temperature ±20 C C C 友台半导体有限公司 R UMW ESD5311N Electrical characteristics (TA =25 oC, unless otherwise noted) Parameter Symbol Reverse maximum working voltage VRWM Reverse leakage current IR Reverse breakdown voltage Clamping voltage 1) Dynamic resistance 1) Condition Min. VRWM = 5V VBR IT = 1mA 7.5 VCL IPP = 16A, tp = 100ns RDYN Clamping voltage 2) VCL Clamping voltage 3) VCL Junction capacitance VESD = 8kV Max. Unit 5.0 V
ESD5311N
物料型号:ATMEGA16A-AU 器件简介:ATMEGA16A-AU 是一款低功耗、高性能的8位AVR微控制器,拥有16KB的系统内可编程Flash。
引脚分配:该芯片共有44个引脚,包括电源引脚、地引脚、复位引脚、I/O引脚、JTAG接口引脚、外部中断引脚等。
参数特性:工作电压范围为2.7V至5.5V,工作频率高达16MHz,具备多种省电模式。
功能详解:具有独立的看门狗定时器、模数转换器、定时器/计数器、串行通信接口、中断系统等。
应用信息:广泛应用于工业控制、消费电子、通信设备、医疗设备等领域。
封装信息:采用44引脚TQFP封装方式。
ESD5311N 价格&库存
很抱歉,暂时无法提供与“ESD5311N”相匹配的价格&库存,您可以联系我们找货
ESD5311N
  • 20+0.20110
  • 100+0.15040
  • 1000+0.11660
  • 10000+0.08450
  • 20000+0.08030
  • 100000+0.07440
库存:16061
ESD5311N
  • 1+0.37070
  • 500+0.12320
  • 5000+0.08228
  • 10000+0.06754
库存:16061
ESD5311N
    • 1+0.07840
    库存:11
