AR20168CHSSL
AR20168CHSSL
    FIBOX
    FIBOX - AR20168CHSSL
AR20168CHSSL 数据手册
The 21ST Century Solution CUSTOMIZATION ARCA enclosures advance beyond tradition to meet and exceed the growing demands of today’s applications.  ARCA’s rugged construction achieves a unique appearance without sacrificing robustness. The stylized cover features an overlapping design proving superior protection of the formed-in-place PUR gasket. All Fibox ARCA enclosures can be customized to meet your requirements. Sophisticated CNC machinery can fabricate enclosures with holes, cutouts, recesses, and more. With custom colors available and all the standard hardware accessories you might need Fibox can easily customize your enclosure and make it unique to your application. ARCA enclosures are available with a variety of cover and mounting options including transparent and opaque covers, our standard raised lid design or for select ARCA sizes a flat cover design. Cover options also include a screw cover, hinged screw cover, and latched hinged cover. Inner panels are available in both metal and non-metallic versions with fixed or hinged mounting. Our largest size additions (24x20x8 and 24x24x10) include both JIC and NEMA panel options while our latest additions include flat covers and pre formed knock outs. ARCA When a custom enclosure is required, you can count on the expertise of Fibox to design and produce the highest quality product to protect your investment With custom cut outs, colors, and all the standard hardware you need Fibox can easily customize your ARCA enclosure for your application. Overlapping cover for strength and increased gasket protection Molded continuous hinge features a compact profile, adding strength and rigidity Wall fastening lugs included; optional mounting flanges Opaque or transparent raised lid covers Stylized corners add rigidity and strength Opaque flat cover available in select sizes Interchangeable metal or non-metallic latches mount without penetrating the enclosure Wide selection of plastic and membrane glands DRAWINGS Ventilation devices Inspection windows TECHNICAL INFORMATION Property Environmental ingress Impact resistance NRTL Listing Glass filled polycarbonate in both cover and base Top level mounting point creates easier, stronger accessory mounting Oversized, formed in place seamless PUR gasket Easily removable stainless steel hinge pin Optional hinged panels, or mount fixed front plates without additional components Standard mounting plates available in optional materials Pre-formed knock-outs available in select size Industry standard 10-32 brass inserts PC: IP 66 IK 08 UL Type 4, 4X, 6, 6P, 12, and 13 UV-Protected Fibox accessories can be fitted to most enclosures and cabinets Temperature Range: °Celsius Short term °Fahrenheit Temperature Range: °Celsius Long term °Fahrenheit Electrical insulation Color Cover screws and hardware Accessory mounting screws Gasket Flammability rating Toxicity Data subject to change without notice. Fibox Enclosures www.fiboxusa.com Tel: (410) 760-9696 Fax: (410) 760-8686 UL Type 4, 4X, 6, 6P, 12 and 13 Impact rating per UL 508 / UL 50 Underwriters Laboratories UL, cUL Listed under UL 508 -40°. . .+140°C -40°. . .+284°F -40°. . .+80°C -40°. . .+175°F Totally insulated RAL 7035 - Light gray 10-32, stainless steel 10-32, stainless steel Formed in place polyurethane (PUR) Enclosure flammability rating per UL 508 Non-Toxic, halogen free, RoHS compliant Toll-free USA 1 888 342 6987 www.fiboxusa.com E-mail: sales@fiboxusa.com NEMA 4X F 175 F ARCA ARCA Flat Cover Design Fibox’s ARCA non-metallic enclosures provide users of classic electrical junction boxes an easy upgrade path to a high performance enclosure featuring the latest technologies.  PC: IP 66 IK 08 UL Type 4, 4X, 6, 6P, 12, and 13 UV-Protected Precision, injection molded, ARCA enclosures feature excellent chemical resistance and the wide temperature utilization range of polycarbonate plastic. Available in classic JIC sizes, these enclosures feature industry standard dimensions and panels. Offering greater real estate on the cover, without sacrificing the sleek design and robust strength synonymous with an ARCA, select ARCA enclosures offer a flat cover. Polycarbonate SCREW COVER OPAQUE COVER TRANSPARENT COVER SIZE H x W x D INCHES SIZE H x W x D METRIC AR664SC AR664SCT 6.0 x 6.0 x 4.0 152 x 152 x 102 AR865SC AR865SCT 8.0 x 6.0 x 5.0 203 x 152 x 127 AR884SC AR884SCT 8.0 x 8.0 x 4.3 203 x 203 x 108 AR1084SC AR1084SCT 10.0 x 8.0 x 4.3 254 x 203 x 108 AR1086SC AR1086SCT 10.0 x 8.0 x 6.0 254 x 203 x 152 AR10106SC AR10106SCT 10.0 x 10.0 x 6.3 254 x 254 x 159 AR12106SC AR12106SCT 12.0 x 10.0 x 6.0 305 x 254 x 152 AR14127SC AR14127SCT 14.0 x 12.0 x 7.0 356 x 305 x 178 AR16148SC AR16148SCT 16.0 x 14.0 x 8.0 406 x 356 x 203 AR181610SC AR181610SCT 18.0 x 16.0 x 10.0 457 x 406 x 254 HINGED SCREW COVER OPAQUE COVER TRANSPARENT COVER SIZE H x W x D INCHES SIZE H x W x D METRIC AR664CHSC AR664CHSCT 6.0 x 6.0 x 4.0 152 x 152 x 102 AR865CHSC AR865CHSCT 8.0 x 6.0 x 5.0 203 x 152 x 127 AR884CHSC AR884CHSCT 8.0 x 8.0 x 4.3 203 x 203 x 108 AR1084CHSC AR1084CHSCT 10.0 x 8.0 x 4.3 254 x 203 x 108 AR1086CHSC AR1086CHSCT 10.0 x 8.0 x 6.0 254 x 203 x 152 AR10106CHSC AR10106CHSCT 10.0 x 10.0 x 6.3 254 x 254 x 159 AR12106CHSC AR12106CHSCT 12.0 x 10.0 x 6.0 305 x 254 x 152 AR14127CHSC AR14127CHSCT 14.0 x 12.0 x 7.0 356 x 305 x 178 AR16148CHSC AR16148CHSCT 16.0 x 14.0 x 8.0 406 x 356 x 203 AR181610CHSC AR181610CHSCT 18.0 x 16.0 x 10.0 457 x 406 x 254 HINGED COVER WITH LOCKABLE LATCH OPAQUE COVER TRANSPARENT COVER SIZE H x W x D INCHES SIZE H x W x D METRIC AR664CHSSL AR664CHSSLT 6.0 x 6.0 x 4.0 152 x 152 x 102 AR865CHSSL AR865CHSSLT 8.0 x 6.0 x 5.0 203 x 152 x 127 AR884CHSSL AR884CHSSLT 8.0 x 8.0 x 4.3 203 x 203 x 108 AR1084CHSSL AR1084CHSSLT 10.0 x 8.0 x 4.3 254 x 203 x 108 AR1086CHSSL AR1086CHSSLT 10.0 x 8.0 x 6.0 254 x 203 x 152 AR10106CHSSL AR10106CHSSLT 10.0 x 10.0 x 6.3 254 x 254 x 159 AR12106CHSSL AR12106CHSSLT 12.0 x 10.0 x 6.0 305 x 254 x 152 AR14127CHSSL AR14127CHSSLT 14.0 x 12.0 x 7.0 356 x 305 x 178 AR16148CHSSL AR16148CHSSLT 16.0 x 14.0 x 8.0 406 x 356 x 203 AR181610CHSSL AR181610CHSSLT 18.0 x 16.0 x 10.0 457 x 406 x 254 AR20168CHSSL CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 20.0 x 16.0 x 8.0 508 x 406 x 203 AR24208CHSSL CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 24.0 x 20.0 x 8.0 609 x 508 x 203 AR242410CHSSL CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 24.0 x 24.0 x 10 609 x 609 x 254 HINGED COVER WITH QUICK RELEASE LATCH Polycarbonate Accessories OPAQUE FLAT COVER DESIGN BACK PANELS FOR ALL ARCA SERIES  –  AVAILABLE IN ALUMINIUM AND NON-METALLIC PANEL CATALOG NUMBER ABP66 ABP86 ABP88 ABP 88 ABP108 ABP 1010 ABP 1210 ABP 1412 ABP 1614 ABP 1816 ABP 2016 ABP 2420 ABP 2424 PANEL SIZE HxW 4.9 x 4.9 (124 x 124) 6.7 x 4.9 (171 x 124) 6.9 x 6.9 (175 x 175) 8.9 x 6.9 (225 x 175) 8.9 x 6.9 (225 x 175) 8.9 x 8.9 (225 x 225) 10.8 x 8.9 (275 x 225) 12.8 x 10.8 (324 x 275) 14.8 x 12.9 (376 x 328) 16.7 x 14.9 (424 x 378) 18.9 x 14.9 (480 x 378) 22.9 x 18.9 (581 x 480) 23 x 23 (584 x 584) ENCLOSURE MOUNTING FxG 6.7 x 4.0 (170 x 102) 8.7 x 4.0 (220 x 102) 8.4 x 6.0 (213 x 152) 10.4 x 6.0 (264 x 152) 10.7 x 6.0 (271 x 152) 10.4 x 8.8 (264 x 223) 12.7 x 8.0 (322 x 203) 14.8 x 10.0 (375 x 254) 16.7 x 12.0 (424 x 305) 18.7 x 14.0 (475 x 356) 23.25 x 14 (590.6 x 355.8) 27.25 x 18 (692 x 457.4) 27.26 x 21 (692.5 x 533.4) EXTERIOR OVERALL HxWxD 7.6 x 7.4 x 4.7 (192 x 188 x 120) 9.5 x 7.4 x 5.7 (242 x 189 x 145) 9.5 x 9.3 x 4.9 (241 x 236 x 125) 11.5 x 9.3 x 4.9 (292 x 236 x 125) 11.5 x 9.3 x 6.7 (291 x 237 x 171) 11.4 x 11.4 x 7.0 (290 x 290 x 177) 13.5 x 11.4 x 6.7 (342 x 289 x 171) 15.5 x 13.3 x 7.7 (393 x 339 x 196) 17.8 x 15.5 x 8.7 (452 x 394 x 221) 19.8 x 17.5 x 10.7 (503 x 444 x 272) 23.31 x 17.43 x 8.75 (566.6 x 442.8 x 222) 25.75 x 21.43 x 8.75 (654 x 544.4 x 222) 26.14 x 25.83 x 10.64 (664 x 656 x 270) SCREW COVER HINGED SCREW COVER HINGED LATCHED COVER SIZE H x W x D INCHES SIZE H x W x D METRIC AR864FSC AR864CHFSC AR864CHFSSL 8.0 x 6.0 x 4.0 203 x 152 x 102 AR1083FSC AR1083CHFSC AR1083CHFSSL 10.0 x 8.0 x 3.0 254 x 203 x 76.5 AR1085FSC AR1085CHFSC AR1085CHFSSL 10.0 x 8.0 x 5.0 254 x 203 x 127.5 AR12105FSC AR12105CHFSC AR12105CHFSSL 12.0 x 10.0 x 5.0 305 x 254 x 127.5 AR14126FSC AR14126CHFSC AR14126CHFSSL 14.0 x 12.0 x 6.0 356 x 305 x 153 ARCA Knock-out Base Fibox presents the first and only non-metallic JIC enclosure with pre-formed knock-outs. Select ARCA enclosure bases include knock-out sized at 3/4 and 1/2 inches. Polycarbonate SCREW COVER OPAQUE COVER TRANSPARENT COVER KNOCK-OUT CONFIGURATION SIZE H x W x D INCHES SIZE H x W x D METRIC ARK865SC ARK865SCT 1/2 , 1/2 8.0 x 6.0 x 5.0 203 x 152 x 127 ARK1086SC ARK1086SCT 1/2, 3/4, 1/2 10.0 x 8.0 x 6.0 254 x 203 x 152 ARK12106SC ARK12106SCT 1/2, 3/4, 1/2 , 3/4 12.0 x 10.0 x 6.0 305 x 254 x 152 ARK14127SCT 1/2, 3/4, 3/4, 3/4, 1/2 14.0 x 12.0 x 7.0 356 x 305 x 178 OPAQUE COVER TRANSPARENT COVER SIZE H x W x D INCHES SIZE H x W x D METRIC AR664CHSS AR664CHSST 6.0 x 6.0 x 4.0 152 x 152 x 102 AR865CHSS AR865CHSST 8.0 x 6.0 x 5.0 203 x 152 x 127 ARK14127SC AR884CHSS AR884CHSST 8.0 x 8.0 x 4.3 203 x 203 x 108 HINGED SCREW COVER AR1084CHSS AR1084CHSST 10.0 x 8.0 x 4.3 254 x 203 x 108 AR1086CHSS AR1086CHSST 10.0 x 8.0 x 6.0 254 x 203 x 152 AR10106CHSS AR10106CHSST 10.0 x 10.0 x 6.3 254 x 254 x 159 AR12106CHSS AR12106CHSST 12.0 x 10.0 x 6.0 305 x 254 x 152 AR14127CHSS AR14127CHSST 14.0 x 12.0 x 7.0 356 x 305 x 178 AR16148CHSS AR16148CHSST 16.0 x 14.0 x 8.0 406 x 356 x 203 AR181610CHSS AR181610CHSST 18.0 x 16.0 x 10.0 457 x 406 x 254 AR20168CHSS CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 20.0 x 16.0 x 8.0 508 x 406 x 203 AR24208CHSS CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 24.0 x 20.0 x 8.0 609 x 508 x 203 AR242410CHSS CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 24.0 x 24.0 x 10 609 x 609 x 254 Accessories ORDER SYMBOL AVBK DESCRIPTION ADJUSTABLE-DEPTH MOUNTING KITS FOR INSTALLING PANELS AT ANY DEPTH WITHIN YOUR ENCLOSURE. ORDER SYMBOL AMFL HINGED COVER WITH LOCKABLE TWIST OPAQUE COVER TRANSPARENT COVER SIZE H x W x D INCHES SIZE H x W x D METRIC AR20168CHTSS CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 20.0 x 16.0 x 8.0 508 x 406 x 203 AR24208CHTSS CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 24.0 x 20.0 x 8.0 609 x 508 x 203 AR242410CHTSS CONTACT YOUR FIBOX REPRESENTATIVE FOR WINDOW OPTIONS 24.0 x 24.0 x 10 609 x 609 x 254 ASPK SWING PANEL KITS PROVIDE PROTECTED ACCESS TO YOUR ENCLOSURE. AMFS DESCRIPTION FLANGE MOUNTING BRACKETS ENABLE ENCLOSURES TO BE WALL OR PANEL MOUNTED. STAINLESS STEEL MOUNTING FEET ENABLE ENCLOSURES TO BE WALL OR PANEL MOUNTED. OPAQUE COVER TRANSPARENT COVER KNOCK-OUT CONFIGURATION SIZE H x W x D INCHES SIZE H x W x D METRIC ARK865CHSC ARK865CHSCT 1/2, 1/2 8.0 x 6.0 x 5.0 203 x 152 x 127 ARK1086CHSC ARK1086CHSCT 1/2, 3/4, 1/2 10.0 x 8.0 x 6.0 254 x 203 x 152 ARK12106CHSC ARK12106CHSCT 1/2, 3/4, 1/2 , 3/4 12.0 x 10.0 x 6.0 305 x 254 x 152 ARK14127CHSC ARK14127CHSCT 1/2, 3/4, 3/4, 3/4, 1/2 14.0 x 12.0 x 7.0 356 x 305 x 178 HINGED LOCKABLE LATCH COVER OPAQUE COVER TRANSPARENT COVER KNOCK-OUT CONFIGURATION SIZE H x W x D INCHES SIZE H x W x D METRIC ARK865CHSSL ARK865CHSSLT 1/2 , 1/2 8.0 x 6.0 x 5.0 203 x 152 x 127 ARK1086CHSSL ARK1086CHSSLT 1/2, 3/4, 1/2 10.0 x 8.0 x 6.0 254 x 203 x 152 ARK12106CHSSL ARK12106CHSSLT 1/2, 3/4, 1/2 , 3/4 12.0 x 10.0 x 6.0 305 x 254 x 152 ARK14127CHSSL ARK14127CHSSLT 1/2, 3/4, 3/4, 3/4, 1/2 14.0 x 12.0 x 7.0 356 x 305 x 178
AR20168CHSSL 价格&库存
很抱歉,暂时无法提供与“AR20168CHSSL”相匹配的价格&库存,您可以联系我们找货
