ARCA 504021S
ARCA 504021S
    FIBOX
    FIBOX - ARCA 504021S - Plastic Enclosure, Multipurpose, Polycarbonate, 500 mm, 400 mm, 210.8 mm, IP6...
ARCA 504021S 数据手册
ARCA 504021S Enclosing innovations Order symbol: ARCA 504021S EAN: Product nbr: 8120091 El. number: 6418074079749 Description: Cabinet, PC Finland: 3423170 Remarks: Swinghandle Electric No. Denmark: 8212091618 Including: Cabinet base, door with PUR gasket, mounting plate, screws for mounting plate. 3mm double bit lock(s) with key. S versions with swinghandle 2-point locking system. F versions with flange opening (including gasket and screws). Door guide included. Sample photo Dimensions: Length Width Height Accessories: mm: 500 400 210 MPP ARCA 5040 inch: 19.7 15.7 8.3 Mounting plate perforated (450x350x2 mm - 26x11 mm) MPMP ARCA 5040 Mounting plate multiperforated (450x350x2 mm - 3.6 mm) Materials: MPX ARCA 5040 Mounting plate (450x350 mm) Material: Polycarbonate DRS ARCA 504015 DIN rail frame set Base colour: RAL 7035 -light grey DRS ARCA 504021 DIN rail frame set RAL 7035 -light grey IDS ARCA 5040 Inner door set Polyurethane PMK ARCA 40 Pole mounting kit RCS ARCA 5040 Rain canopy set Cover colour: Gasket material: Temperatures: SBK ARCA 40 Support bar kit Temperature °C (short term): -40 … 120 °C SBK ARCA 50 Support bar kit Temperature °C (continuous): -40 … 80 °C DSP ARCA VLS Door stopper ARCA, vertical, left, small Temperature °F (short term): -40 … 250 °F DSP ARCA VRS Door stopper ARCA, vertical, right, small Temperature °F (continuous): -40 … 175 °F Rating: Ingress Protection (EN 60529): IP66 Accessories: Impact Resistance (EN 62262): IK10 +35°C /IK08 -25°C MPS ARCA 5040 Mounting plate (450x350x2 mm) Electrical insulation: Totally insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 94 5VA Glow Wire Test (IEC 695-2-1) °C: 960 Certificates: SGS Fimko Gost R 400 360 310 R4 ,2 212,5 180 10 Ø8 504021F 155 5,2x10 size 2 461,5 560 500 460 410 587 361 196 204 3,8 5040W 4,5 3,8 257x392 © Fibox Oy, Data subject to change without notice (printed: 2.1.2017)
ARCA 504021S 价格&库存
很抱歉,暂时无法提供与“ARCA 504021S”相匹配的价格&库存,您可以联系我们找货
