ARCA 604021
ARCA 604021
    FIBOX
    FIBOX - ARCA 604021 - Plastic Enclosure, IK10, 2 Point Lock, Utility Box, Polycarbonate, 210 mm, 400...
ARCA 604021 数据手册
ARCA 604021 Enclosing innovations Order symbol: ARCA 604021 EAN: Product nbr: 8120012 El. number: 6418074079237 Description: Cabinet, PC Finland: 3423100 Remarks: 2-point locking Electric No. Denmark: 8212091100 Electric No. Sweden: 2500118 Including: Cabinet base, door with PUR gasket, mounting plate, screws for mounting plate. 3mm double bit lock(s) with key. S versions with swinghandle 2-point locking system. F versions with flange opening (including gasket and screws). Door guide included. Sample photo Dimensions: Length Width Height Accessories: mm: 600 400 210 MPP ARCA 6040 inch: 23.6 15.7 8.3 Mounting plate perforated (550x350x2 mm - 26x11 mm) MPMP ARCA 6040 Mounting plate multiperforated (550x350x2 mm - 3.6 mm) Materials: MPX ARCA 6040 Mounting plate (550x350 mm) Material: Polycarbonate DRS ARCA 604021 DIN rail frame set Base colour: RAL 7035 -light grey DRS ARCA 604030 DIN rail frame set RAL 7035 -light grey IDS ARCA 6040 Inner door set Polyurethane PMK ARCA 40 Pole mounting kit RCS ARCA 6040 Rain canopy set Cover colour: Gasket material: Temperatures: SBK ARCA 40 Support bar kit Temperature °C (short term): -40 … 120 °C SBK ARCA 60 Support bar kit Temperature °C (continuous): -40 … 80 °C DSP ARCA VLS Door stopper ARCA, vertical, left, small Temperature °F (short term): -40 … 250 °F DSP ARCA VRS Door stopper ARCA, vertical, right, small Temperature °F (continuous): -40 … 175 °F Rating: Ingress Protection (EN 60529): IP66 Accessories: MPS ARCA 6040 Impact Resistance (EN 62262): IK10 +35°C /IK08 -25°C Mounting plate (550x350x2 mm) Electrical insulation: Totally insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 94 5VA Glow Wire Test (IEC 695-2-1) °C: 960 Certificates: SGS Fimko Gost 10 400 360 310 R4 ,2 R 212,5 180 Ø8 604021F 155 5,2x10 size 2 196 204 6040W 561,5 687 660 600 560 510 361,5 3,8 4,5 3,8 257x492 © Fibox Oy, Data subject to change without notice (printed: 26.7.2017)
ARCA 604021 价格&库存
很抱歉,暂时无法提供与“ARCA 604021”相匹配的价格&库存,您可以联系我们找货
ARCA 604021
    • 1+2567.78146
    库存:43
