C-MP MOUNTING PLATE
C-MP MOUNTING PLATE
    FIBOX
    FIBOX - C-MP MOUNTING PLATE - Plate, 140mm x 80mm x 65mm / 140mm x 80mm x 85mm, Mounting, PICCOLO Ra...
C-MP MOUNTING PLATE 数据手册
FIBOX PICCOLO 15 PC ABS EMC PBPC SABS PICCOLO EMC PICCOLO PUSH BUTTONS PICCOLO SIGNAL The FIBOX PICCOLO range of enclosures is specifically designed for housing push buttons, terminal blocks, motor starters and electronic devices. They are also ideal for mounting and protecting process control sensors and switches. There are six basic sizes and a choice of two cover depths. Push Button configurations are available as standard. FIBOX PICCOLO is available in polycarbonate or ABS. The enclosures are rated EN 60529 IP66/IP67. FIBOX PICCOLO 16 Including: Enclosure base, cover with PUR gasket, 4 cover screws, and mounting screws. FIBOX PICCOLO PC: IP66 / IP67, IK 08 ABS: IP66 / IP67, IK 07 Z C ORDER SYMBOL ORDER SYMBOL Grey cover Transparent cover B X A L X S mm mm mm 65 85 52 72 PC B 65 G PC B 85 G PC B 65 T PC B 85 T B 75 110 mm 80 mm 65 85 52 72 ABS B 65 G ABS B 85 G ABS B 65 T ABS B 85 T LxS 90 x 60 PICCOLO C 65 85 52 72 PC C 65 G PC C 85 G PC C 65 T PC C 85 T B 105 140 mm 80 mm 65 85 52 72 ABS C 65 G ABS C 85 G ABS C 65 T ABS C 85 T LxS 120 x 60 PICCOLO D 65 85 52 72 PC D 65 G PC D 85 G PC D 65 T PC D 85 T B 135 170 mm 80 mm 65 85 52 72 ABS D 65 G ABS D 85 G ABS D 65 T ABS D 85 T LxS 150 x 60 PICCOLO F 65 85 52 72 PC F 65 G PC F 85 G PC F 65 T PC F 85 T B 195 65 85 52 72 ABS F 65 G ABS F 85 G ABS F 65 T ABS F 85 T LxS 210 x 60 95 81.7 PC H 95 G PC H 95 T 95 81.7 ABS H 95 G ABS H 95 T BxA 130 x 100 PICCOLO B X Y Y Y Y X X X X X X X 230 mm 80 mm PICCOLO H Y X X 170 mm 140 mm LxS 152 x 122 PICCOLO M Y X X 230 mm 140 mm External height Y External width X External depth Z 95 81.7 PC M 95 G PC M 95 T 95 81.7 ABS M 95 G ABS M 95 T 125 111.7 PC MH 125 G PC MH 125 T 125 111.7 ABS MH 125 G ABS MH 125 T Free internal mounting height C Mounting plate assembly B X A Wall mounting L BxA 190 x 100 X SxL 212 x 122 S FP 22040 fastening lug measures PC B 65 T X Z Y External height X External width Z External depth C Free internal mounting height B Mounting plate assembly A Mounting plate assembly L Wall mounting S Wall mounting SYMBOLS AND ABBREVIATIONS Cover G = Grey T = Smoked grey Y = colour of the enclosure S A Total height = base + cover Enclosure size Enclosure range/type PC ABS SABS C B B L L EMC PBPC Y polycarbonate smooth sides ABS grey, smooth sides ABS signal Y=yellow smooth sides polycarbonate, painted for EMC-shielding, smooth sides polycarbonate, push buttons in cover 1 = one hole 1M = one hole miniature size A S PICCOLO EMC, PICCOLO YELLOW AND PICCOLO PUSH BUTTONS FIBOX PICCOLO EMC POLYCARBONATE ENCLOSURE DIMENSIONS mm ORDER SYMBOL EMC PC B 65 G EMC PC C 65 G EMC PC D 65 G EMC PC F 65 G EMC PC H 95 G EMC PC M 95 G 110 x 80 x 65 140 x 80 x 65 170 x 80 x 65 230 x 80 x 65 170 x 140 x 95 230 x 140 x 95 VING REMO UCT PROD Choose PICCOLO PB Polycarbonate enclosures to house 30.5 mm or 22.5 mm pushbuttons in corrosive environments. Piccolo PB enclosures feature high impact resistance, stylish design, and light grey colour. FIBOX PICCOLO BUSH BUTTON ENCLOSURES PBPC B 85 G 1 PBPC D 85 G 2 PBPC F 85 G 3 PBPC H 95 G 4 PBPC M 95 G 6 PBPC B 85 G 1M PBPC C 85 G 2M PBPC D 85 G 3M PBPC F 85 G 4M ø 30.5 MM ø 22.5 MM 110 x 80 x 85 170 x 80 x 85 230 x 80 x 85 170 x 140 x 95 230 x 140 x 95 110 x 80 x 85 140 x 80 x 85 170 x 80 x 85 230 x 80 x 85 VING RE MO UCT PROD Bright Yellow PICCOLO enclosure with black cover screws for places where visible safety is needed. FIBOX PICCOLO SIGNAL ABS ENCLOSURE SABS B 65 Y SABS C 65 Y SABS D 65 Y SABS F 65 Y SABS H 95 Y SABS M 95 Y Data subject to change without notice. 110 x 80 x 65 140 x 80 x 65 170 x 80 x 65 230 x 80 x 65 170 x 140 x 95 230 x 140 x 95 A standard PICCOLO EMC shielded plastic enclosure family for fulfilling the newest European regulations of electromagnetic compatibility. Five different standard sizes available ex stock with 40 to 60 db attenuation through reliable Ni-coating inside the enclosure. VING REMO UCT PROD FIBOX PICCOLO 17 FIBOX PICCOLO 18 TECHNICAL INFORMATION PROPERTY POLYCARBONATE (PC) ABS CONFORMITY TO STANDARDS (UL, CSA, CE, Lloyds, BV, FI) Ingress Protection (EN 60529) IP66/IP67 IP66/67 Impact Resistance (EN 50102) Temperature Range (short term) Temperature Range (continuous) Electrical Insulation IK 08 IK 07 -40°. . .120°C -40°. . .250°F -40°. . .80°C -40°. . .175°F Totally insulated -40°. . .80°C -40°. . .175°F -40°. . .60°C -40°. . .140°F Totally insulated USA Enclosures for Electrical Equipment PC: UL Type 1, 4X, 6, 12 and 13 (UL 50/508) ABS: NEMA 1, 4, 4X, 6, 12 and 13 Canada Industrial Control Equipment Enclosures for Electrical Equipment/ULc Europe Enclosures for Switch Gear and Control Gear Assemblies EN 50298:1998 Europe Safety of Information Technology Equipment EN 60950 Australia Enclosures for switch gear and control gear AS 3132-1991 RAL 7035 Industry Grey Clear Transparent RAL 7035 Polyamide (PA) PUR UL94-5V 960°C Halogen Free UL 508 720 hours in "Weatherometer" Good RAL 7035 Industry Grey Clear Transparent RAL 7035 Polyamide (PA) PUR UL94HB 650°C Halogen Free Celsius Fahrenheit Celsius Fahrenheit Light Grey Parts Colour Transparent Clear PC Cover Cover Screws Cover Screws Gasket Enclosure Flammability Rating Glow Wire Test Non-toxicity UV resistance Chemical Resistance * UL 746 C 5 in. vertical flame test IEC 695-2-1, Self-extinguishing Good Data subject to change without notice. *Consult separate raw material data for more detailed information ACCESSORIES Product Order symbol Size mm Product Order symbol Mounting plate B-MP C-MP D-MP F-MP H-MP M-MP 80 x 54 110 x 54 140 x 54 200 x 54 125 x 94 185 x 94 Mounting foot kit, 2 pcs incl. screws FP 22040 Mounting foot kit, 4 pcs incl. screws FP 22046 Screw sets MB S-20 KN MB S-40 KN MB S-20 BKN MB S-40 BKN Mounting rail B-3 DIN 35 CHM-3 DH-3 FM-3 35 x 80 35 x 110 35 x 140 35 x 200 Inspection windows 60 x 77 96 x 77 130 x 77 162 x 77 199 x 77 L02 L04 L06 L08 L10 Ventilation device MB 10631 Hinges TH A Size mm Cover screws Grey S-20 S-40 Black S-20B S-40B Hinges, 1 pair incl. screws PA 22039 CUSTOMISATION Enclosures can be machined, painted, screen printed and preassembled to meet your customisation requirements. Fibox's service centre offers complete CNC machining, hinge mounting, screen printing, assembly and much more. Our wide selection of enclosures and accessories can be customised to create a unique enclosure meeting your application requirements. Mounting screw KN 3.9 x 9.5 0.8 1.6 20 40 0.8 1.6 20 40
C-MP MOUNTING PLATE 价格&库存
很抱歉,暂时无法提供与“C-MP MOUNTING PLATE”相匹配的价格&库存,您可以联系我们找货
