ARCA 404021
ARCA 404021
    FIBOX
    FIBOX - ARCA 404021 - Plastic Enclosure, 2-Point Lock, Multipurpose, Polycarbonate, 400 mm, 400 mm, ...
ARCA 404021 数据手册
ARCA 404021 Order symbol : ARCA 404021 Product nr : 8120009 Description : Cabinet, PC Remarks : Grey cover, 2-point locking, hinges on the long side EAN : 6418074079206 El. number : • • • Sample image Finland : Denmark : Sweden : 2506467 Including : Cabinet base. door with PUR gasket. mounting plate. screws for mounting plate. 3mm double bit lock(s) with key. S versions with swinghandle 2-point locking system. Door guide included. Dimensions : Height Width Depth Accessories : mm : 400 400 210 inch : 15.75 15.75 8.58 IDS ARCA 4040 Inner door set (380 x 380 x 30) MPX ARCA 4040 Mounting plate (350x350 mm) (350 x 350 x 5) MPMP ARCA 4040 Mounting plate multiperforated (350x350x2 mm - ⌀3.6 mm) (350 x 350 x 2) DRS ARCA 404021 DIN rail frame set (385 x 385 x35) MPS ARCA 4040 Mounting plate (350x250x2 mm) (350 x 350 x 2) MPP ARCA 4040 Mounting plate perforated (350x350x2 mm 26x11 mm) (350 x 350 x 2) Materials : Material : Polycarbonate Base colour : RAL 7035 -light grey Cover colour : RAL 7035 -light grey Gasket material : Polyurethane Temperatures : Temperature °C (short term) : -40 … 120 Temperature °C (continuous) : -40 … 80 Rating : Temperature °F (short term) : -40 … 250 Ingress protection (EN 60529): IP66; Temperature °F (continuous) : -40 … 175 Impact Resistance (EN 62262): IK10; Electrical insulation : Totally insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance : UL 508 Flammability Rating : UL 94 5VA Glow Wire Test (IEC 695-2-1) °C : 960 °C NEMA Class NEMA 1, 4, 4X, 12 and 13 Certificates : Certificate FI 40467 © Fibox Oy, Data subject to change without notice (printed: 07.11.2022)
ARCA 404021 价格&库存
很抱歉,暂时无法提供与“ARCA 404021”相匹配的价格&库存,您可以联系我们找货
ARCA 404021
  • 1+1351.01833
  • 5+1283.44294
  • 10+1215.85713
  • 20+1148.41713
  • 50+1080.83132
库存:1
