AR10106CHSC
AR10106CHSC
    FIBOX
AR10106CHSC 数据手册
ARCA AR10106CHSC Enclosing innovations Order symbol: AR10106CHSC EAN: Product nbr: 8561110 El. number: 6418074066572 Description: PC Enclosure Finland: Remarks: Hinged opaque screw cover Including: Hinged screw cover base with 10-32 brass inserts, cover with formed in place PUR gasket, stainless hinge pin and 2 cover screws. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample photo Dimensions: Length Width Height Accessories: mm: 254 254 152 ABP1010 Painted Steel Back Panel 6.0 ALBP1010 Aluminum Back Panel ADFP1010 Dead Front Panel w/ screws Materials: ASP1010 Aluminum Swing Panel Material: Polycarbonate ASPK1010 Swing Panel Kit incl. Panel Base colour: RAL 7035 -light grey ASPHK10 Swing Panel Kit w/o Panel Cover screws material: Stainless steel AMFL10 10" Mounting Flange Set Cover colour: RAL 7035 -light grey Rating: Gasket material: Polyurethane Ingress Protection (EN 60529): IP66/IP67 inch: 10.0 10.0 Electrical insulation: Totally insulated Temperatures: Halogen free (DIN/VDE 0472, Part 815): 0 Temperature °C (short term): -40 … 140 °C UV resistance: UL 508 Temperature °C (continuous): -40 … 80 °C Flammability Rating: UL 508 Temperature °F (short term): -40 … 284 °F Temperature °F (continuous): -40 … 175 °F Glow Wire Test (IEC 695-2-1) °C: 960 NEMA Class: UL Type 4, 4X, 6, 6P, 12 and 13 Accessories: APBP1010 PVC Back Panel 11,30 287 11,10 282 10,98 278,9 7,99 203 9,86 250,5 8,86 225 10-32 inserts 11,36 288,5 9,90 251,4 8,86 225 Wall fastening lug Top View - cover removed Screw cover 11,45 290,8 12,21 310,2 11,62 295,1 1,65 42 6,25 158,8 6,92 175,8 ,24 6 10-32 Inserts © Fibox Oy, Data subject to change without notice (printed: 18.5.2018) Hinged with latch Hinged screw cover
AR10106CHSC 价格&库存
很抱歉,暂时无法提供与“AR10106CHSC”相匹配的价格&库存,您可以联系我们找货
