AR884CHSSLT
AR884CHSSLT
    FIBOX
    FIBOX - AR884CHSSLT - ENCLOSURE, JUNCTION BOX, PC, GREY/CLEAR
AR884CHSSLT 数据手册
ARCA AR884CHSSLT Enclosing innovations Order symbol: AR884CHSSLT EAN: Product nbr: 8561094 El. number: 6418074066725 Description: PC Enclosure Finland: Remarks: Hinged transparent cover w/S.S. Lockable latch Including: Hinged cover base with 10-32 brass inserts, latched cover with formed in place PUR gasket, and stainless hinge pin. Quick release latches. (Latch options available.) Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample photo Dimensions: Length Width Height Accessories: mm: 203 203 102 ABP88 Painted Steel Back Panel 4.0 ALBP88 Aluminum Back Panel ADFP88 Dead Front Panel w/ screws Materials: ASP88 Aluminum Swing Panel Material: Polycarbonate ASPK88 Swing Panel Kit incl. Panel Base colour: RAL 7035 -light grey ASPHK8 Swing Panel Kit w/o Panel Cover screws material: Stainless steel AMFL8 8" Mounting Flange Set Cover colour: Clear transparent Rating: Gasket material: Polyurethane Ingress Protection (EN 60529): IP66/IP67 inch: 8.0 8.0 Electrical insulation: Totally insulated Temperatures: Halogen free (DIN/VDE 0472, Part 815): 0 Temperature °C (short term): -40 … 140 °C UV resistance: UL 508 Temperature °C (continuous): -40 … 80 °C Flammability Rating: UL 508 Temperature °F (short term): -40 … 284 °F Temperature °F (continuous): -40 … 175 °F Glow Wire Test (IEC 695-2-1) °C: 960 NEMA Class: UL Type 4, 4X, 6, 6P, 12 and 13 Accessories: APBP88 PVC Back Panel 9,29 236 9,11 231,4 9,32 236,8 10-32 inserts 8,98 228 5,98 152 7,92 201,2 6,89 175 7,95 201,9 6,89 175 Wall fastening lug Screw cover Top View - cover removed 10,20 259 9,46 240,2 9,39 238,5 1,64 41,6 4,90 124,5 4,25 108 ,24 6 10-32 Inserts © Fibox Oy, Data subject to change without notice (printed: 18.5.2018) Hinged with latch Hinged screw cover
AR884CHSSLT 价格&库存
很抱歉,暂时无法提供与“AR884CHSSLT”相匹配的价格&库存,您可以联系我们找货
