CAB ABS 504020 G3B
CAB ABS 504020 G3B
    FIBOX
    FIBOX - CAB ABS 504020 G3B - Plastic Enclosure, IK08, Grey Door, Wall Mount, ABS, 200 mm, 400 mm, 50...
CAB ABS 504020 G3B 数据手册
CAB CAB ABS 504020 G3B Enclosing innovations Order symbol: CAB ABS 504020 G3B EAN: Product nbr: 8183362 El. number: 6418074020420 Description: Cabinet, ABS, Grey door Finland: 3424324 Remarks: Locks on the long side Electric No. Denmark: 8212019069 Electric No. Italy: 7811060 Electric No. Sweden: 2540081 Including: Cabinet base, door with PUR gasket, 3mm double bit lock(s) with key, screws for mounting plate/DIN-rail and corner plugs. Sample photo Dimensions: Length Width Height Accessories: mm: 500 400 200 EKIV 37 DIN-35 Mounting rail 7.9 DS35370E1 DIN-35 Mounting rail EKIV 47 DIN-35 Mounting rail Materials: DS35470E1 DIN-35 Mounting rail Material: ABS FP A 54 Swing-out door/Front plate Base colour: RAL 7035 -light grey MB 12225 AL Swing door set Cover colour: RAL 7035 -light grey FP 54 Front plate Gasket material: Polyurethane FP 18X2-54 Front plate DRF 54 DIN rail frame set inch: 19.7 15.7 Temperatures: Rating: Temperature °C (short term): -40 … 80 °C Ingress Protection (EN 60529): IP65 Temperature °C (continuous): -40 … 60 °C Impact Resistance (EN 62262): IK08 Temperature °F (short term): -40 … 175 °F Electrical insulation: Totally insulated Temperature °F (continuous): -40 … 140 °F Halogen free (DIN/VDE 0472, Part 815): 1 Flammability Rating: UL 94 HB Glow Wire Test (IEC 695-2-1) °C: 650 Accessories: EKIV 54 NEMA Class: NEMA 1, 4, 4X, 12, 13 Mounting plate Certificates: SGS Fimko Gost R CAB 500x400x200 M6 Ø4X10 CAB 4050 G3B 50 100 120 Ø5.2X10 4 188 CAB 5040 G3B 125 498 484 472 398 460 428 350 455 50 125 50 25 3 360 330 372 384 398 © Fibox Oy, Data subject to change without notice (printed: 26.7.2017) 4.6 328 16 398 50 CAB 5040 G3B 17 152 202
CAB ABS 504020 G3B 价格&库存
很抱歉,暂时无法提供与“CAB ABS 504020 G3B”相匹配的价格&库存,您可以联系我们找货
