CAB PCQ 302017 G CABINET
    FIBOX
    FIBOX - CAB PCQ 302017 G CABINET - Plastic Enclosure, Wall Mount, Polycarbonate, 200 mm, 300 mm, 170...
CAB PCQ 302017 G CABINET 数据手册
QUICK CAB PCQ 302017 G Enclosing innovations Order symbol: CAB PCQ 302017 G EAN: Product nbr: 8113338 El. number: 6418074011145 Description: Cabinet, PC Finland: 3421970 Remarks: Grey cover Electric No. Italy: 7681020 Electric No. Sweden: 2539106 Including: Base with screws for mounting plate/DIN-rail, internal corner plugs, cover with PUR gasket and CS 12137 cover screws. Sample photo Dimensions: Length Width Height Accessories: mm: 300 200 170 EKIV 17 DIN-35 Mounting rail 6.7 EKIV 27 DIN-35 Mounting rail FP A 23 Swing-out door/Front plate Materials: MB 12225 AL Swing door set Material: Polycarbonate FP 12-23 Front plate Base colour: RAL 7035 -light grey DRF 23 DIN rail frame set Cover screws material: Polyamide DRF 33 DIN rail frame set Cover colour: RAL 7035 -light grey PAT 12040 Hinge set Cover screws colour: RAL 5023 Gasket material: Polyurethane inch: 11.8 7.9 Rating: Ingress Protection (EN 60529): IP66/IP67 Impact Resistance (EN 62262): IK08 Electrical insulation: Totally insulated Temperatures: Temperature °C (short term): -40 … 120 °C Temperature °C (continuous): -40 … 80 °C Temperature °F (short term): -40 … 250 °F Temperature °F (continuous): -40 … 175 °F Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 746C 5" Glow Wire Test (IEC 695-2-1) °C: 960 NEMA Class: NEMA 1, 4, 4X, 12, 13 Accessories: Certificates: EKIV 23 Germanischer Lloyd (GL) Mounting plate SGS Fimko Lloyds Register of Shipping (LR) Gost R QUICK 300x200x170 ø 4x10 ø5.2x10 255 225 260 272 284 298 50 128 160 158 23 9.1 M6 172 184 198 © Fibox Oy, Data subject to change without notice (printed: 26.7.2017) 132 172
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-20℃至+85℃,输入电流为5mA,输出电流为10mA。
5. 功能详解:EL817通过光电效应实现信号传输,具有隔离作用,提高电路安全性。
6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1mm x 3.6mm。
CAB PCQ 302017 G CABINET 价格&库存
很抱歉,暂时无法提供与“CAB PCQ 302017 G CABINET”相匹配的价格&库存,您可以联系我们找货
  • 1+688.71912
库存:12
