AR664SCT
AR664SCT
    FIBOX
    FIBOX - AR664SCT - ENCLOSURE, JUNCTION BOX, PC, GREY/CLEAR
AR664SCT 数据手册
ARCA AR664SCT Enclosing innovations Order symbol: AR664SCT EAN: Product nbr: 8561011 El. number: 6418074066282 Description: PC Enclosure Finland: Remarks: Transparent screw cover Including: Screw cover base with 10-32 brass inserts, cover with formed in place PUR gasket and 4 stainless cover screws. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample photo Dimensions: Length Width Height Accessories: mm: 152 152 102 ABP66 Painted Steel Back Panel 4.0 ALBP66 Aluminum Back Panel ADFP66 Dead Front Panel w/ screws Materials: ASP66 Aluminum Swing Panel Material: Polycarbonate ASPK66 Swing Panel Kit incl. Panel Base colour: RAL 7035 -light grey ASPHK6 Swing Panel Kit w/o Panel Cover screws material: Stainless steel AMFL6 6" Mounting Flange Set Cover colour: Clear transparent Rating: Gasket material: Polyurethane Ingress Protection (EN 60529): IP66/IP67 inch: 6.0 6.0 Electrical insulation: Totally insulated Temperatures: Halogen free (DIN/VDE 0472, Part 815): 0 Temperature °C (short term): -40 … 140 °C UV resistance: UL 508 Temperature °C (continuous): -40 … 80 °C Flammability Rating: UL 508 Temperature °F (short term): -40 … 284 °F Temperature °F (continuous): -40 … 175 °F Glow Wire Test (IEC 695-2-1) °C: 960 NEMA Class: UL Type 4, 4X, 6, 6P, 12 and 13 Accessories: APBP66 PVC Back Panel 7,32 186 7,16 181,9 10-32 inserts 7,04 178,9 4,00 101,6 7,39 187,6 6,06 153,9 4,88 124 6,10 155 Wall fastening lug 4,88 124 Screw cover Top View - cover removed 7,55 191,8 8,24 209,3 7,65 194,2 1,65 42 4,72 120 10-32 Inserts © Fibox Oy, Data subject to change without notice (printed: 18.5.2018) 4,07 103,5 ,24 6 Hinged with latch Hinged screw cover
AR664SCT 价格&库存
很抱歉,暂时无法提供与“AR664SCT”相匹配的价格&库存,您可以联系我们找货
