CAB PCQ 404017 T CABINET
    FIBOX
    FIBOX - CAB PCQ 404017 T CABINET - Plastic Enclosure, Multipurpose, Polycarbonate, 400 mm, 400 mm, 1...
CAB PCQ 404017 T CABINET 数据手册
CAB PCQ 404017 T Order symbol: CAB PCQ 404017 T EAN: 6418074011114 Product nbr: 8113088 El. number: UL Code: 8143088 • • • UL Name: UL CAB PCQ 404017 T Finland: 3421928 Denmark: Sweden: 2540107 Description: Enclosure. PC Remarks: Smoked transparent cover Including: Base with screws for mounting plate/DIN-rail. internal corner plugs. cover with PUR gasket and CS 12137 cover screws. Sample image Dimensions: Height Width Depth Accessories: mm: 400 400 170 DRF 43/44 DIN rail frame kit. for enclosures: inch: Materials: Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: Clear transparent Gasket material: Polyurethane Temperatures: PAT 12040 Hinge kit MB 12225 AL Swing door kit EKIV 37 DIN-35 Mounting rail. for enclosures: (366 x 35 x 1) FP A 44 Swing-out door/Front panel (aluminum). for enclosures: (368 x 368 x 1) EKIV 44 Back Panel. for enclosures: (370 x 370 x 1) Rating: Temperature °C (short term):: -40 … 120 Ingress protection (EN 60529): IP66; IP67; Temperature °C (continuous): -40 … 80 Impact Resistance (EN 62262): IK08; Temperature °F (short term): -40 … 250 Electrical insulation: Totally insulated Temperature °F (continuous): -40 … 175 Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 746C 5" Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class Certificates: Certificate FI 40848 © Fibox Oy, Data subject to change without notice (printed: 21.05.2022)
CAB PCQ 404017 T CABINET 价格&库存
很抱歉,暂时无法提供与“CAB PCQ 404017 T CABINET”相匹配的价格&库存,您可以联系我们找货
