ARCA 403015S
ARCA 403015S
    FIBOX
    FIBOX - ARCA 403015S - Plastic Enclosure, Multipurpose, Polycarbonate, 400 mm, 300 mm, 149.9 mm, IP6...
ARCA 403015S 数据手册
ARCA 403015S Enclosing innovations Order symbol: ARCA 403015S EAN: Product nbr: 8120086 El. number: 6418074079695 Description: Cabinet, PC Finland: 3423165 Remarks: Swinghandle Electric No. Denmark: 8212091566 Including: Cabinet base, door with PUR gasket, mounting plate, screws for mounting plate. 3mm double bit lock(s) with key. S versions with swinghandle 2-point locking system. F versions with flange opening (including gasket and screws). Door guide included. Sample photo Dimensions: Length Width Height Accessories: mm: 400 300 150 MPP ARCA 4030 inch: 15.7 11.8 5.9 Mounting plate perforated (350x250x2 mm - 26x11 mm) MPMP ARCA 4030 Mounting plate multiperforated (350x250x2 mm - 3.6 mm) Materials: MPX ARCA 4030 Mounting plate (350x250 mm) Material: Polycarbonate DRS ARCA 403015 DIN rail frame set Base colour: RAL 7035 -light grey IDS ARCA 4030 Inner door set RAL 7035 -light grey PMK ARCA 30 Pole mounting kit Polyurethane RCS ARCA 4030 Rain canopy set SBK ARCA 30 Support bar kit Cover colour: Gasket material: Temperatures: SBK ARCA 40 Support bar kit Temperature °C (short term): -40 … 120 °C DSP ARCA VLS Door stopper ARCA, vertical, left, small Temperature °C (continuous): -40 … 80 °C DSP ARCA VRS Door stopper ARCA, vertical, right, small Temperature °F (short term): -40 … 250 °F Rating: Temperature °F (continuous): -40 … 175 °F Ingress Protection (EN 60529): IP66 Impact Resistance (EN 62262): IK10 +35°C /IK08 -25°C Accessories: Electrical insulation: Totally insulated MPS ARCA 4030 Mounting plate (350x250x2 mm) Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 94 5VA Glow Wire Test (IEC 695-2-1) °C: 960 Certificates: SGS Fimko Gost R 300 260 210 R4 ,2 152,5 120 10 Ø8 403015F 95 5,2x10 size 2 261 4030W 136 361,5 310 360 487 460 400 144 3,8 4,5 3,8 157x292 © Fibox Oy, Data subject to change without notice (printed: 2.1.2017)
ARCA 403015S 价格&库存
很抱歉,暂时无法提供与“ARCA 403015S”相匹配的价格&库存,您可以联系我们找货
