CAB ABS 302018 G3B
CAB ABS 302018 G3B
    FIBOX
    FIBOX - CAB ABS 302018 G3B - Plastic Enclosure, IK08, Grey Door, Wall Mount, ABS, 180 mm, 200 mm, 30...
CAB ABS 302018 G3B 数据手册
CAB CAB ABS 302018 G3B Enclosing innovations Order symbol: CAB ABS 302018 G3B EAN: Product nbr: 8183332 El. number: 6418074020109 Description: Cabinet, ABS, Grey door Finland: 3424305 Remarks: Lock on the long side Electric No. Denmark: 8212019001 Electric No. Italy: 7811020 Electric No. Sweden: 2540065 Including: Cabinet base, door with PUR gasket, 3mm double bit lock(s) with key, screws for mounting plate/DIN-rail and corner plugs. Sample photo Dimensions: Length Width Height Accessories: mm: 300 200 180 EKIV 17 DIN-35 Mounting rail 7.1 DS35170E1 DIN-35 Mounting rail EKIV 27 DIN-35 Mounting rail Materials: DS35270E1 DIN-35 Mounting rail Material: ABS FP A 23 Swing-out door/Front plate Base colour: RAL 7035 -light grey MB 12225 AL Swing door set Cover colour: RAL 7035 -light grey FP 23 Front plate Gasket material: Polyurethane FP 12-23 Front plate DRF 23 DIN rail frame set inch: 11.8 7.9 Temperatures: Rating: Temperature °C (short term): -40 … 80 °C Ingress Protection (EN 60529): IP65 Temperature °C (continuous): -40 … 60 °C Impact Resistance (EN 62262): IK08 Temperature °F (short term): -40 … 175 °F Electrical insulation: Totally insulated Temperature °F (continuous): -40 … 140 °F Halogen free (DIN/VDE 0472, Part 815): 1 Flammability Rating: UL 94 HB Glow Wire Test (IEC 695-2-1) °C: 650 Accessories: EKIV 23 NEMA Class: NEMA 1, 4, 4X, 12, 13 Mounting plate Certificates: SGS Fimko Gost R ø4x10 CAB 3020L ø5.2x10 49 19 128 29 42 160 255 3 260 225 50 300 284 272 198 100 8.2 168 ø9.1 23 50 M6 16 172 184 198 © Fibox Oy, Data subject to change without notice (printed: 26.7.2017) 132 182
CAB ABS 302018 G3B 价格&库存
很抱歉,暂时无法提供与“CAB ABS 302018 G3B”相匹配的价格&库存,您可以联系我们找货
