AR16148CHSSLT
AR16148CHSSLT
    FIBOX
AR16148CHSSLT 数据手册
ARCA AR16148CHSSLT Enclosing innovations Order symbol: AR16148CHSSLT EAN: Product nbr: 8561076 El. number: 6418074066848 Description: PC Enclosure Finland: Remarks: Hinged transparent cover w/S.S. Lockable latch Including: Hinged cover base with 10-32 brass inserts, latched cover with formed in place PUR gasket, and stainless hinge pin. Quick release latches. (Latch options available.) Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample photo Dimensions: Length Width Height Accessories: mm: 406 356 203 ALBP1614 Aluminum Back Panel 8.0 ADFP1614 Dead Front Panel w/ screws ASP1614 Aluminum Swing Panel Materials: ASPK1614 Swing Panel Kit incl. Panel Material: Polycarbonate ASPHK16 Swing Panel Kit w/o Panel Base colour: RAL 7035 -light grey AMFL14 14" Mounting Flange Set Cover screws material: Stainless steel Rating: Cover colour: Clear transparent Ingress Protection (EN 60529): IP66/IP67 Gasket material: Polyurethane Electrical insulation: Totally insulated inch: 16.0 14.0 Halogen free (DIN/VDE 0472, Part 815): 0 Temperatures: UV resistance: UL 508 Temperature °C (short term): -40 … 140 °C Flammability Rating: UL 508 Temperature °C (continuous): -40 … 80 °C Glow Wire Test (IEC 695-2-1) °C: 960 Temperature °F (short term): -40 … 284 °F Temperature °F (continuous): -40 … 175 °F NEMA Class: UL Type 4, 4X, 6, 6P, 12 and 13 Accessories: ABP1614 Painted Steel Back Panel 17,44 442,9 15,12 384 12,01 305 16,04 407,4 14,76 375 15,51 393,8 10-32 inserts Wall fastening lug 14,07 357,4 12,87 327 Screw cover Inner center 16,73 425 Outer center 17,36 441 Top View - cover removed 16,34 414,9 17,81 452,3 15,76 400,4 1,65 42 8,72 221,4 10-32 Inserts © Fibox Oy, Data subject to change without notice (printed: 18.5.2018) ,24 6 8,04 204,2 Hinged with latch Hinged screw cover
AR16148CHSSLT 价格&库存
很抱歉,暂时无法提供与“AR16148CHSSLT”相匹配的价格&库存,您可以联系我们找货
