DRS ARCA 608030
DRS ARCA 608030
    FIBOX
    FIBOX  DRS ARCA 608030  Enclosure Accessory, DIN Rail Frame Set, Fibox ARCA 608030 Enclosure
DRS ARCA 608030 数据手册
DRS ARCA 608030 Enclosing innovations Order symbol: DRS ARCA 608030 EAN: Product nbr: 8120800 El. number: 6418074085429 Description: DIN rail frame set Finland: 3424094 Remarks: 3 rows x 37 modules Electric No. Denmark: 8212095685 Electric No. Sweden: 2500202 Including: Dimensions: Length Width Height Accessories: mm: MPS ARCA 3030 Mounting plate inch: MPS ARCA 4030 Mounting plate (350x250x2 mm) MPS ARCA 4040 Mounting plate MPS ARCA 5040 Mounting plate (450x350x2 mm) MPS ARCA 6040 Mounting plate (550x350x2 mm) MPS ARCA 6060 Mounting plate MPS ARCA 7050 Mounting plate (630x430x2 mm) MPS ARCA 8060 Mounting plate (730x530x2 mm) MPP ARCA 2030 Mounting plate perforated (250x150x2 mm - 26x11 mm) MPP ARCA 3020 Mounting plate perforated (250x150x2 mm - 26x11 mm) MPP ARCA 3030 Mounting plate perforated MPP ARCA 3040 Mounting plate perforated (350x250x2 mm - 26x11 mm) MPP ARCA 4030 Mounting plate perforated (350x250x2 mm - 26x11 mm) MPP ARCA 4040 Mounting plate perforated MPP ARCA 4050 Mounting plate perforated (450x350x2 mm - 26x11 mm) MPP ARCA 5040 Mounting plate perforated (450x350x2 mm - 26x11 mm) MPP ARCA 4060 Mounting plate perforated (550x350x2 mm - 26x11 mm) MPP ARCA 6040 Mounting plate perforated (550x350x2 mm - 26x11 mm) MPP ARCA 6060 Mounting plate perforated MPP ARCA 5070 Mounting plate perforated (630x430x2 mm - 26x11 mm) MPP ARCA 7050 Mounting plate perforated (630x430x2 mm - 26x11 mm) MPP ARCA 6080 Mounting plate perforated (730x530x2 mm - 26x11 mm) MPP ARCA 8060 Mounting plate perforated (730x530x2 mm - 26x11 mm) MPMP ARCA 3020 Mounting plate multiperforated (250x150x2 mm - 3.6 mm) MPMP ARCA 4030 Mounting plate multiperforated (350x250x2 mm - 3.6 mm) MPMP ARCA 5040 Mounting plate multiperforated (450x350x2 mm - 3.6 mm) MPMP ARCA 6040 Mounting plate multiperforated (550x350x2 mm - 3.6 mm) 0.0 0.0 0.0 Materials: Temperatures: Accessories: MPS ARCA 3020 Mounting plate (250x150x2 mm) © Fibox Oy, Data subject to change without notice (printed: 26.7.2017) Enclosing innovations MPMP ARCA 7050 Mounting plate multiperforated (630x430x2 mm - 3.6 mm) MPMP ARCA 8060 Mounting plate multiperforated (730x530x2 mm - 3.6 mm) MPX ARCA 3020 Mounting plate (250x150 mm) MPX ARCA 3030 Mounting plate MPX ARCA 4030 Mounting plate (350x250 mm) MPX ARCA 4040 Mounting plate MPX ARCA 5040 Mounting plate (450x350 mm) MPX ARCA 6040 Mounting plate (550x350 mm) MPX ARCA 6060 Mounting plate MPX ARCA 7050 Mounting plate (630x430 mm) MPX ARCA 8060 Mounting plate (730x530 mm) DRS ARCA 203015 DIN rail frame set DRS ARCA 203021 DIN rail frame set DRS ARCA 302015 DIN rail frame set DRS ARCA 302021 DIN rail frame set DRS ARCA 303015 DIN rail frame set DRS ARCA 303021 DIN rail frame set DRS ARCA 304015 DIN rail frame set DRS ARCA 304021 DIN rail frame set DRS ARCA 403015 DIN rail frame set DRS ARCA 403021 DIN rail frame set DRS ARCA 404015 DIN rail frame set DRS ARCA 404021 DIN rail frame set DRS ARCA 405015 DIN rail frame set DRS ARCA 405021 DIN rail frame set DRS ARCA 504015 DIN rail frame set DRS ARCA 504021 DIN rail frame set DRS ARCA 406021 DIN rail frame set DRS ARCA 406030 DIN rail frame set DRS ARCA 604021 DIN rail frame set DRS ARCA 604030 DIN rail frame set DRS ARCA 606021 DIN rail frame set DRS ARCA 606030 DIN rail frame set DRS ARCA 705025 DIN rail frame set DRS ARCA 507030 DIN rail frame set DRS ARCA 705030 DIN rail frame set DRS ARCA 806025 DIN rail frame set DRS ARCA 806030 DIN rail frame set IDS ARCA 2030 Inner door set IDS ARCA 3020 Inner door set IDS ARCA 3030 Inner door set IDS ARCA 3040 Inner door set IDS ARCA 4030 Inner door set IDS ARCA 4040 Inner door set IDS ARCA 4050 Inner door set Enclosing innovations IDS ARCA 5040 Inner door set IDS ARCA 4060 Inner door set IDS ARCA 6040 Inner door set IDS ARCA 6060 Inner door set IDS ARCA 5070 Inner door set IDS ARCA 7050 Inner door set IDS ARCA 6080 Inner door set IDS ARCA 8060 Inner door set SBK ARCA 20 Support bar kit SBK ARCA 30 Support bar kit SBK ARCA 40 Support bar kit SBK ARCA 50 Support bar kit SBK ARCA 60 Support bar kit SBK ARCA 70 Support bar kit SBK ARCA 80 Support bar kit CBS ARCA 15 Corner adjustment set CBS ARCA 21 Corner adjustment set CBS ARCA 30 Corner adjustment set CFS ARCA Coupling Flange WMK ARCA 10 SMALL Wall mounting lugs set WMK ARCA 40 SMALL Wall mounting lugs set WMK ARCA 10 MID Wall mounting lugs set for 5070-8060 WMK ARCA 40 MID Wall mounting lugs set for 5070-8060 WMKQ10S Plastic Wall mounting lugs set WMKQ50S Plastic Wall mounting lugs set WMKQ10M Plastic Wall mounting lugs set for 5070-8060 WMKQ50M Plastic Wall mounting lugs set for 5070-8060 PMK ARCA 20 Pole mounting kit PMK ARCA 30 Pole mounting kit PMK ARCA 40 Pole mounting kit PMK ARCA 50 Pole mounting kit PMK ARCA 60 Pole mounting kit PMK ARCA 70 Pole mounting kit PMK ARCA 80 Pole mounting kit PLS ARCA Padlocking set LIS ARCA DB3 Locking insert Double-bit 3mm LIS ARCA DB3 MID Locking insert Double-bit 3mm LIS ARCA S7 Locking insert Square 7mm LIS ARCA S7 MID Locking insert Square 7mm LIS ARCA S8 Locking insert Square 8mm LIS ARCA S8 MID Locking insert Square 8mm LIS ARCA T8 Locking insert Triangular 8mm LIS ARCA T8 MID Locking insert Triangular 8mm LIS ARCA 1242E wingknob Locking 1242E system Enclosing innovations LIS ARCA 1242E MID wingknob Locking 1242E system LIS ARCA V2432E wingknob Locking V2432E system LIS ARCA V2432E MID wingknob Locking V2432E system LIS ARCA 455E wingknob Locking 455E system LIS ARCA 455E MID wingknob Locking 455E system LIS ARCA 405E wingknob Locking 405E system LIS ARCA 405E MID wingknob Locking 405E system CLI ARCA DB3 Half cylinder locking Double-bit 3mm CLI ARCA S7 Half cylinder locking Square 7mm CLI ARCA S8 Half cylinder locking Square 8mm CLI ARCA T8 Half cylinder locking Triangular 8mm CLI ARCA 1242E Half cylinder locking 1242E system CLI ARCA V2432E Half cylinder locking V2432E system CLI ARCA 455E Half cylinder locking 455E system CLI ARCA 405E Half cylinder locking 405E system RCS ARCA 2030 Rain canopy set RCS ARCA 3020 Rain canopy set RCS ARCA 3040 Rain canopy set RCS ARCA 4030 Rain canopy set RCS ARCA 4050 Rain canopy set RCS ARCA 4060 Rain canopy set RCS ARCA 5040 Rain canopy set RCS ARCA 5070 Rain canopy set RCS ARCA 6040 Rain canopy set RCS ARCA 6080 Rain canopy set RCS ARCA 8060 Rain canopy set RCS ARCA 7050 Rain canopy set FHS S ARCA Hinge set small FHS M ARCA Hinge set medium Rating:
DRS ARCA 608030 价格&库存
很抱歉,暂时无法提供与“DRS ARCA 608030”相匹配的价格&库存,您可以联系我们找货
DRS ARCA 608030
  • 1+1919.63466
库存:2
