AR181610CHSSL
AR181610CHSSL
    FIBOX
    FIBOX - AR181610CHSSL - ENCLOSURE, HINGED, MULTIPURPOSE, PC, GRY
AR181610CHSSL 数据手册
ARCA AR181610CHSSL Enclosing innovations Order symbol: AR181610CHSSL EAN: Product nbr: 8561070 El. number: Description: PC Enclosure Finland: Remarks: Hinged opaque cover w/S.S. Lockable latch 6418074066855 Including: Hinged cover base with 10-32 brass inserts, latched cover with formed in place PUR gasket, and stainless hinge pin. Quick release latches. (Latch options available.) Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample photo Dimensions: Length Width Height Accessories: mm: 457 406 254 ALBP1816 Aluminum Back Panel 10.0 ADFP1816 Dead Front Panel w/ screws ASP1816 Aluminum Swing Panel Materials: APSPK1816 Plastic Swing Panel Kit incl. Panel Material: Polycarbonate ASPK1816 Swing Panel Kit incl. Panel Base colour: RAL 7035 -light grey AMFL16 16" Mounting Flange Set Cover screws material: Stainless steel Rating: Cover colour: RAL 7035 -light grey Ingress Protection (EN 60529): IP66/IP67 Gasket material: Polyurethane Electrical insulation: Totally insulated inch: 18.0 16.0 Halogen free (DIN/VDE 0472, Part 815): 0 Temperatures: UV resistance: UL 508 Temperature °C (short term): -40 … 140 °C Flammability Rating: UL 508 Temperature °C (continuous): -40 … 80 °C Glow Wire Test (IEC 695-2-1) °C: 960 Temperature °F (short term): -40 … 284 °F Temperature °F (continuous): -40 … 175 °F NEMA Class: UL Type 4, 4X, 6, 6P, 12 and 13 Accessories: ABP1816 Painted Steel Back Panel 19,40 492,8 17,51 444,7 17,11 434,7 14,02 356 18,00 457,2 16,73 425 16,03 407,2 14,88 378 10-32 inserts Wall fastening lug Screw cover Inner center 18,74 476 Outer center 19,37 492 Top View - cover removed 19,81 503,1 18,33 465,7 17,77 451,3 1,65 42 10,69 271,4 10-32 Inserts © Fibox Oy, Data subject to change without notice (printed: 7.8.2017) ,24 6 10,01 254,2 Hinged with latch Hinged screw cover
AR181610CHSSL 价格&库存
很抱歉,暂时无法提供与“AR181610CHSSL”相匹配的价格&库存,您可以联系我们找货
