CAB ABS 303018 G3B
CAB ABS 303018 G3B
    FIBOX
    FIBOX - CAB ABS 303018 G3B - Plastic Enclosure, IK08, Grey Door, Wall Mount, ABS, 180 mm, 300 mm, 30...
CAB ABS 303018 G3B 数据手册
CAB CAB ABS 303018 G3B Enclosing innovations Order symbol: CAB ABS 303018 G3B EAN: Product nbr: 8183342 El. number: 6418074020185 Description: Cabinet, ABS, Grey door Finland: 3424311 Remarks: Lock on the long side Electric No. Denmark: 8212019027 Electric No. Italy: 7811030 Electric No. Sweden: 2540069 Including: Cabinet base, door with PUR gasket, 3mm double bit lock(s) with key, screws for mounting plate/DIN-rail and corner plugs. Sample photo Dimensions: Length Width Height Accessories: mm: 300 300 180 EKIV 27 DIN-35 Mounting rail 7.1 DS35270E1 DIN-35 Mounting rail FP A 33 Swing-out door/Front plate Materials: MB 12225 AL Swing door set Material: ABS FP 33 Front plate Base colour: RAL 7035 -light grey FP 12-33 Front plate Cover colour: RAL 7035 -light grey FP 12x2-33 Front plate Gasket material: Polyurethane DRF 33 DIN rail frame set inch: 11.8 11.8 Rating: Temperatures: Ingress Protection (EN 60529): IP65 Temperature °C (short term): -40 … 80 °C Impact Resistance (EN 62262): IK08 Temperature °C (continuous): -40 … 60 °C Electrical insulation: Totally insulated Temperature °F (short term): -40 … 175 °F Halogen free (DIN/VDE 0472, Part 815): 1 Temperature °F (continuous): -40 … 140 °F Flammability Rating: UL 94 HB Glow Wire Test (IEC 695-2-1) °C: 650 NEMA Class: NEMA 1, 4, 4X, 12, 13 Accessories: EKIV 33 Mounting plate Certificates: SGS Fimko Gost R ø4x10 ø5.2x10 49 228 10 0 3 225 260 198 50 272 284 300 255 29 19 42 CAB 3030L 8.2 260 168 ø9.1 23 50 272 284 16 300 © Fibox Oy, Data subject to change without notice (printed: 26.7.2017) 132 182 M6
CAB ABS 303018 G3B 价格&库存
很抱歉,暂时无法提供与“CAB ABS 303018 G3B”相匹配的价格&库存,您可以联系我们找货
