CD4073B/CD4082B
CMOS AND Gate High-Voltage Types
Features
CD4073B and CD4082B AND Gates.provide the system ed Inner with
direct implementation of the AND function and supplement the
existing family of CMOS gates.
Medium-Speed Operation -TPLH, TPHL=60ns(tsp.)at VDD = 10 V
100% tested for quiescent current at 20V Maximum input current
SOP14
of 1μA at 18 V over full pack-temperature range,100 nA at 18 V and
25ºC
Noise margin (full package-temperature range)
1V at VDD=5V
2V at VDD=10V
TSSOP14
2.5V at VDD=15V
Standardized,symmetrical ou taut characteristics
5V、10Vand 15V parametric ratings
Meets all requirements of JEDEC Tentative Tankard
No.13B,Standard Specifications
DIP14
Orderinginf Ormation
DEVICE
Package Type
MARKING
Packing
Packing Qty
CD4073BE
DIP14
CD4073BE
TUBE
1000pcs/box
CD4073BM/TR
SOP14
CD4073B
REEL
2500pcs/reel
TSSOP14
CD4073B
REEL
2500pcs/reel
CD4082BE
DIP14
CD4082BE
TUBE
1000pcs/box
CD4082BM/TR
SOP14
CD4082B
REEL
2500pcs/reel
TSSOP14
CD4082B
REEL
2500pcs/reel
CD4073BMT/TR
CD4082BMT/TR
http://www.hgsemi.com.cn
1 / 10
2019 DEC
CD4073B/CD4082B
Logic Diagram
2 / 10
2019 DEC
CD4073B/CD4082B
*ALL INPUTS ARE PROTECTED BY
CMOS PROTECTION NETWORK
Fig.1 - Logic diagram for CD4073B(1 of 3 identical Gates).
Fig.2 - Logic diagram for CD4082B (1 of 2 identical gates).
3 / 10
2019 DEC
CD4073B/CD4082B
Pin Configuration
DIP/SOP/TSSOP
DIP/SOP/TSSOP
CB4073B
CB4082B
MAXIMUM RATINGS,Absolute-Maximum Values:
Condition
Min
Max
Units
Voltages reference to VSS Terminal)
-0.5
+20
V
INPUT VOLTAGE RANGE,ALLINPUTS
-0.5
+0.5
V
DC INPUT CURRENTANY ONE INPUT
+10
mA
500
mA
12
200
mW
100
mW
OPERATING-TEMPERATURE RANGE(TA)
-40
+85
STORAGE TEMPERATURE RANGE(stag)
-65
+150
+265
DC SUPPLY-VOLTAGE RANGE,(VDD):
POWER DISSIPATION PER PACKAG-(PD):
For TA=55℃ to +100℃
For TA=+100℃ to +125℃ (Derate Lineaitry at)
DEVICE DISSIPATION PER OUTPUT TRANSISTOR:
FOR TA-FULL PACKAGE=TEMPERATURE RANGE(AI Pakage Types)
At distance 1/16±1/32inch(1.59+0.79mm)from case for 10s max
Recommendedoperatingconditions
For maximum reliability. nominal operating conditions should be selected so that operation is always
within the following ranges:
CHARACTERISTIC
MIN.
Supply-Voltage Range (for T=Full Package
LIMITS
5
Temperature Range)
UNITS
MAX.
15
V
DYNAIC ELECTRICAL CHARACTETISTICS
at TA=25ºC,Input tr,ft=20ns,and CL=50 pf,RL=200KΩ
CHARACTERISTIC
TEST CONDITIOS
VDD Volts
5
10
15
5
10
15
Propagation Delay Time,TPHL,TPLH
Transition Time, TPHL,TPLH
Input Capacitance,CIN
Any Input
4 / 10
ALL TYPES LIMITS
TYP.
MAX.
125
60
40
100
50
40
5
250
120
90
200
100
80
7.5
UNITS
NS
NS
Pf
2019 DEC
CD4073B/CD4082B
STATIC ELECTRICAL CHARACTERISTICS
CHARACTER.
ISTIC
CONDITIONS
VO
(V)
Quiescent Device
Current,IDD Max.
Output Low
(Sink)Current IOL Min.
Output High (Source)
Current,
IOH Min.
VIN
(V)
LIMITS AT INDICATED TEMPERATURES(℃)
UNITS
+25
VDD
(V)
-40
+85
Min
TYP
MAX
0.5
5
0.25
7.5
0.01
0.25
0.10
10
0.5
15
0.01
0.5
0.15
15
1
30
0.01
1
0.20
150
0.02
5
0.4
0.5
5
0.61
0.42
0.51
1
0.5
0.10
10
1.5
1.1
1.3
2.6
1.5
0.15
15
4
2.8
3.4
6.8
4.6
0.5
5
-0.61
-0.42
-0.51
-1
2.5
0.5
5
-1.8
-1.3
-1.6
-3.2
9.5
0.10
10
-1.5
-1.1
-1.3
-2.6
13.5
0.15
10
-4
-2.8
-3.4
-6.8
Output Voltage
Low-Level,
VOL Max.
0.5
5
0.05
0.10
10
0.05
0.15
15
0.05
Output Voltage
High-Level,
VOH Min.
0.5
5
1.95
4.95
5
0.10
10
9.95
9.95
10
0.15
15
14.95
14.95
15
0.5
5
1.5
1.5
1
10
3
3
1.5
15
4
4
0.5.4.5
5
3.5
3.5
1.9
10
7
7
1.5.13.5
15
11
11
0.18
18
±10-5
±0.1
Input Low Voltage,
VIL Max.
Input High Voltage,
VIH Min.
Input Current
VIN Max.
±0.1
5 / 10
±1
µA
mA
V
V
µA
2019 DEC
CD4073B/CD4082B
INPUT VOLTAGE(VIN)-V
LOAD CAPACITANCE(CL)--pf
Fig.3-Typocalvoltagetransfercharacteristic.
Fig.4 - Typical propagation delay time as a
function of load capacitance.
DRAIN-TO-SOURCE VOKTAGE(VDS)-V
DRAIN-TO-SOURCE VOLTAGE(VDS)-V
Fig.5 - Typical output low (sink)
Fig.6 - Minimum output low (sink)
Current characteristics.
Fig.7 -Minimum output high (source)current
Fig.8 - Typical
characteristics
D
current
characteristics.
6 / 10
2019 DEC
CD4073B/CD4082B
Fig.9 -Typical transition time as a function of
Fig.10 -Typical dynamic power diss i- Ration
load capacitance
per gate as a function
TERMINAL ASSIGNMENTS
Fig.12 - Input
Fig.11 - Quiescent device current test circuit.
Fig.13 - Input-voltage test circuit.
7 / 10
2019 DEC
CD4073B/CD4082B
Physical Dimensions
DIP14
B
L1
L
E
D1
D
d
A
c
a
Dimensions In Millimeters(DIP14)
A
B
D
D1
E
L
L1
a
c
Min:
6.10
18.94
8.40
7.42
3.10
0.50
3.00
1.50
0.40
Max:
6.68
19.56
9.00
7.82
3.55
0.70
3.60
1.55
0.50
Symbol:
d
2.54 BSC
SOP14
Q
A
C
C1
B
D
A1
a
0.25
b
Dimensions In Millimeters(SOP14)
A
A1
B
C
C1
D
Min:
1.35
0.05
8.55
5.80
3.80
0.40
0°
0.35
Max:
1.55
0.20
8.75
6.20
4.00
0.80
8°
0.45
Symbol:
8 / 10
Q
a
b
1.27 BSC
2019 DEC
CD4073B/CD4082B
Physical Dimensions
TSSOP14
Dimensions In Millimeters(TSSOP14)
A
A1
B
C
C1
D
Min:
0.85
0.05
4.90
6.20
4.30
0.40
0°
0.20
Max:
0.95
0.20
5.10
6.60
4.50
0.80
8°
0.25
Symbol:
9 / 10
Q
a
b
0.65 BSC
2019 DEC
CD4073B/CD4082B
IMPORTANT STATEMENT:
Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant
information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the
altered documents.
Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design
and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design,
validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the
occurrence of potential risks that may lead to personal injury or property loss.
Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor
will not bear the consequences caused by the application of products in these fields.
The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network
tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed
to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance
scope of Huaguan Semiconductor. Not all parameters of each device need to be tested.
The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this
document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly
forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages,
costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement.
10 / 10
2019 DEC
