UMW
R
ESD9N12BA
Descriptions
The
ESD9N12BA
is
Suppressor) designed
components
transmission
a
to
protect
which are
lines
TVS
(Transient
sensitive
connected
to
Voltage
electronic
data
and
from over-stress caused by ESD
(Electrostatic Discharge), EFT (Electrical Fast Transients)
and lightning.
The
ESD9N12BA
may
be
used
to
provide
ESD
protection up to ±30kV (contact discharge) according to
IEC61000-4-2, and withstand peak pulse current up to
5.5A (8/20μs) according to IEC61000-4-5.
The ESD9N12BA is available in DFN1006-2L package.
Standard products are Pb-free and Halogen-free.
Applications
Features
Stand-off voltage: ±12V Max.
Computers and peripherals
Transient protection for each line according to
Cellular handsets
IEC61000-4-2 (ESD): ±30kV (contact discharge)
Portable Electronics
IEC61000-4-5 (surge): 5.5A (8/20μs)
Notebooks
Capacitance: CJ = 27pF typ.
Ultra-low leakage current: IR = 0.1nA typ.
Low clamping voltage: VCL = 20V typ. @ IPP = 16A (TLP)
Solid-state silicon technology
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
99
W
Peak pulse current (tp = 8/20μs)
IPP
5.5
A
ESD according to IEC61000-4-2 air discharge
±30
VESD
ESD according to IEC61000-4-2 contact discharge
kV
±30
TJ
125
o
Operating temperature
TOP
-40~85
o
Lead temperature
TL
260
o
TSTG
-55~150
o
Junction temperature
Storage temperature
www.umw-ic.com
1
C
C
C
C
友台半导体有限公司
UMW
R
ESD9N12BA
Electrical characteristics (TA=25 oC, unless otherwise noted)
Symbol
Parameter
Stand-off voltage
IR
Reverse breakdown voltage
1)
Dynamic resistance
Clamping voltage
Min.
Typ.
VRWM
Reverse leakage current
Clamping voltage
Condition
1)
VRWM = 12V
0.1
VBR
IT = 1mA
13
VCL
IPP = 16A, tp = 100ns
RDYN
2)
VCL
Junction capacitance
Max.
Unit
±12
V
50
nA
16.5
V
V
0.35
Ω
IPP = 1A, tp = 8/20μs
16
V
IPP = 5.5A, tp = 8/20μs
18
V
VR = 0V, f = 1MHz
27
35
pF
VR = 12V, f = 1MHz
14
pF
CJ
1) TLP parameter: Z0 = 50Ω, tp = 100ns, tr = 2ns, averaging window from 60ns to 80ns. RDYN is calculated from 4A to16A.
2) Non-repetitive current pulse, according to IEC61000-4-5.
100
90
Front time: T1= 1.25 T = 8s
100
90
Time to half-value: T2= 20s
Current (%)
Peak pulse current (%)
Typical characteristics (TA=25oC, unless otherwise noted)
50
T2
10
T
T1
tr = 0.7~1ns
Time (s)
t
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
www.umw-ic.com
60ns
30ns
友台半导体有限公司
UMW
R
ESD9N12BA
28
Pulse waveform: tp = 8/20s
19
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
17
16
15
14
13
2
3
4
5
6
24
22
16
14
12
7
f = 1MHz
VAC = 50mV
26
IPP - Peak pulse current (A)
4
6
8
10
12
VR - Reverse voltage (V)
Capacitance vs. Reverse voltage
Clamping voltage vs. Peak pulse current
1000
% of Rated power
Peak pulse power (W)
100
100
10
1
www.umw-ic.com
10
100
Pulse time (s)
1000
80
60
40
50
75
100
125
150
o
TA - Ambient temperature ( C)
3
友台半导体有限公司
UMW
R
ESD9N12BA
Non-repetitive peak pulse power vs. Pulse time
Power derating vs. Ambient temperature
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
TLP current (A)
Z0 = 50
16
tr = 2ns
14
tp = 100ns
12
10
8
6
4
2
4
6
8
10 12 14 16 18 20 22
TLP voltage (V)
TLP Measurement
www.umw-ic.com
4
友台半导体有限公司
UMW
R
ESD9N12BA
DFN1006-2 PACKAGE OUTLINE DIMENSIONS
Inches
Millimeters
Dim
A
B
C
R
D
MIN
MAX
MIN
MAX
A
0.013
0.020
0.34
0.50
B
0.000
0.002
0.00
0.05
C
0.037
0.042
0.95
1.075
D
0.021
0.026
0.55
0.675
E
0.017
0.021
0.45
0.55
F
0.007
0.011
0.20
0.30
E
H
F
R
H
0.015Typ.
0.001
0.40Typ.
0.005
0.05
0.15
Marking
CA
Ordering information
Order code
UMW ESD9N12BA
www.umw-ic.com
Package
DFN1006-2
5
Baseqty
10000
Deliverymode
Tape and reel
友台半导体有限公司
很抱歉,暂时无法提供与“ESD9N12BA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14533
- 1000+0.09405
- 4000+0.08296
- 10000+0.07346
- 国内价格
- 20+0.15855
- 200+0.12258
- 600+0.10260
- 2000+0.09051
- 10000+0.08014
- 20000+0.07452
