CD4046BE
CD4046BE
    HGSEMI(华冠)
    DIP-16
    微功耗锁相环
CD4046BE 数据手册
CD4046B Micropower Phase-Locked Loop Features  Wide supply voltage range:3.0V to 18V  Low dynamic:70µW (typ.) at DIP-16 power consumption:fo = 10 kHz, VDD = 5V  VCO frequency:1.3 MHz (typ.) at VDD = 10V  Low frequency drift:0.06%/°C at VDD = 10V with temperature  High VCO linearity:1% (typ.) SOP-16 TSSOP-16 Ordering Information DEVICE Package Type MARKING Packing Packing Qty CD4046BE DIP-16 CD4046BE TUBE 1000pcs/box CD4046BM/TR SOP-16 CD4046B REEL 2500pcs/reel TSSOP-16 CD4046B REEL 2500pcs/reel CD4046BMT/TR http://www.hgsemi.com.cn 1 / 14 2014 JUN CD4046B General Description The CD4046B micropower phase-locked loop (PLL) consists of a low power, linear, voltage-controlled oscillator (VCO), a source follower, a zener diode, and two phase comparators. The two phase comparators have a common signal input and a common comparator input. The signal input can be directly coupled for a large voltage signal, or capacitively coupled to the self-biasing amplifier at the signal input for a small voltage signal.Phase comparator I, an exclusive OR gate, provides a digital error signal (phase comp. I Out) and maintains 90° phase shifts at the VCO center frequency. Between signal input and comparator input (both at 50% duty cycle), it may lock onto the signal input frequencies that are close to harmonics of the VCO center frequency.Phase comparator II is an edge-controlled digital memory network. It provides a digital error signal (phase comp. II Out) and lock-in signal (phase pulses) to indicate a locked condition and maintains a 0° phase shift between signal input and comparator input. The linear voltage-controlled oscillator (VCO) produces an output signal (VCO Out) whose frequency is determined by the voltage at the VCOIN input, and the capacitor and resistors connected to pin C1A, C1B, R1 and R2.The source follower output of the VCOIN (demodulator Out) is used with an external resistor of 10 kΩ or more. The INHIBIT input, when high, disables the VCO and source follower to minimize standby power consumption. The zener diode is provided for power supply regulation, if necessary. Applications FM demodulator and modulator Frequency synthesis and multiplication Frequency discrimination Data synchronization and conditioning Voltage-to-frequency conversion Tone decoding FSK modulation Motor speed control http://www.hgsemi.com.cn 2 / 14 2014 JUN CD4046B Block & Connection Diagrams FIGURE 1 Dual-In-Line Package Top View Order Number CD4046B http://www.hgsemi.com.cn 3 / 14 2014 JUN CD4046B Absolute Maximum Ratings (Notes 1 & 2) If Military/Aerospace specified devices are required, please contact the National Semiconductor Sales Office/Distributors for availability and specifications. Condition Min Max UNITS DC Supply Voltage (VDD) -0.5 +18 VDC Input Voltage (VIN) -0.5 +0.5 VDC Storage Temperature Range (TS) -65 150 °C Power Dissipation (PD) - - - Dual-In-Line - 700 mW Small Outline - 500 mW Lead Temperature (TL) - - - (Soldering, 10 seconds) - 260 °C Min Max UNITS +3 +15 VDC Recommended Operating Conditions (Note 2) Condition DC Supply Voltage (VDD) Input Voltage (VIN) 0 to VDD VDC Operating Temperature Range (TA) http://www.hgsemi.com.cn -40 4 / 14 +85 °C 2014 JUN CD4046B DC Electrical Characteristics (Note 2) Symbol Parameter -40°C Conditions Min +25°C Max Min +85°C Min Max Units Typ Max 0.005 20 150 µA Pin 5 = VDD, Pin 14 = VDD, Pin 3, 9 = VSS IDD Quiescent Device Current VDD = 5V 20 VDD = 10V 40 0.01 40 300 µA VDD = 15V 80 0.015 80 600 µA Pin 5 = VDD, Pin 14 = Open, Pin 3, 9 = VSS VOL Low Level Output Voltage VDD = 5V 70 5 55 205 µA VDD = 10V 530 20 410 710 µA VDD = 15V 1500 50 1200 1800 µA VDD = 5V 0.05 0 0.05 0.05 V VDD = 10V 0.05 0 0.05 0.05 V VDD = 15V 0.05 0 0.05 0.05 V VDD = 5V VOH VIL VIH IOL IOH High Level Output Voltage Low Level Input Voltage Comparator and Signal In High Level Input Voltage Comparator and Signal In Low Level Output Current (Note 4) High Level Output Current (Note 4) 4.95 4.95 5 4.95 V VDD = 10V 9.95 9.95 10 9.95 V VDD = 15V 14.95 14.95 15 14.95 V VDD = 5V, VO = 0.5V or 4.5V 1.5 2.25 1.5 1.5 V VDD = 10V, VO = 1V or 9V 3.0 4.5 3.0 3.0 V 6.25 4.0 4.0 V VDD = 15V, VO = 1.5V or 13.5V VDD = 5V, VO = 0.5V or 4.5V 4.0 3.5 3.5 2.75 3.5 V VDD = 10V, VO = 1V or 9V 7.0 7.0 5.5 7.0 V VDD = 15V, VO = 1.5V or 13.5V 11.0 11.0 8.25 11.0 V VDD = 5V, VO = 0.4V 0.52 0.44 0.88 0.36 mA VDD = 10V, VO = 0.5V 1.3 1.1 2.25 0.9 mA VDD = 15V, VO = 1.5V 3.6 3.0 8.8 2.4 mA VDD = 5V, VO = 4.6V -0.52 -0.44 -0.88 -0.36 mA VDD = 10V, VO = 9.5V -1.3 -1.1 -2.25 -0.9 mA VDD = 15V, VO = 13.5V -3.6 -3.0 -8.8 -2.4 mA All Inputs Except Signal Input IIN CIN Input Current Input Capacitance VDD = 15V, VIN = 0V -0.3 -10-5 -0.3 -1.0 µA VDD = 15V, VIN = 15V 0.3 10-5 0.3 1.0 µA Any Input (Note 3) 7.5 pF fo = 10 kHz, R1 = 1 MΩ R2 = ∞, VCOIN = VDD/2 PT Total Power Dissipation VDD = 5V 0.07 mW VDD = 10V 0.6 mW VDD = 15V 2.4 mW Note 1: ‘‘Absolute Maximum Ratings’’ are those values beyond which the safety of the device cannot be guaranteed. They are not meant to imply that the devices should be operated at these limits. The table of ‘‘Recommended Operating Conditions’’ and ‘‘Electrical Characteristics’’ provides conditions for actual device operation. Note 2: VSS e 0V unless otherwise specified. Note 3: Capacitance is guaranteed by periodic testing. Note 4: IOH and IOL are tested one output at a time. http://www.hgsemi.com.cn 5 / 14 2014 JUN CD4046B AC Electrical Characteristics* Symbol TA = 25°C, CL = 50 pF Parameter Conditions Min Typ Max Units VCO SECTION fo = 10 kHz, R1 = 1 MΩ R2 = ∞, VCOIN = VDD/2 IDD Operating Current VDD = 5V 20 µA VDD = 10V 90 µA VDD = 15V 200 µA C1 = 50 pF, R1 = 10 kΩ, R2 = ∞, VCOIN = VDD Maximum Operating Frequency VDD = 5V 0.4 0.8 MHz VDD = 10V 0.6 1.2 MHz VDD = 15V 1.0 1.6 MHz 1 % 1 % 1 % VDD = 5V 0.12 –0.24 %/ °C VDD = 10V 0.04 –0.08 %/ °C VDD = 15V 0.015 –0.03 %/ °C VDD = 5V 0.06 –0.12 %/ °C VDD = 10V 0.05 –0.1 %/ °C VDD = 15V 0.03 –0.06 %/ °C VDD = 5V 10 MΩ VDD = 10V 6 10 MΩ VDD = 15V 106 MΩ VDD = 5V 50 % VDD = 10V 50 % VDD = 15V 50 VDD = 5V 90 200 ns VDD = 10V 50 100 ns VDD = 15V 45 80 ns VCOIN = 2.5V ± 0.3V, R1 ≥ 10 kΩ, VDD = 5V Linearity VCOIN = 5V ± 2.5V, R1 ≥ 400 kΩ, VDD = 10V VCOIN = 7.5V ± 5V, fMAX R1 ≥ 1 MX, VDD = 15V %/°C∞1/f. VDD Temperature-Frequency Stability No Frequency Offset, fMIN = 0 Frequency Offset, fMIN ≠ 0 VCOIN VCO tTHL tTHL Input Resistance Output Duty Cycle VCO Output Transition Time R2 = ∞ 6 % *AC Parameters are guaranteed by DC correlated testing. http://www.hgsemi.com.cn 6 / 14 2014 JUN CD4046B AC Electrical Characteristics* Symbol TA e 25°C, CL = 50 pF (Continued) Parameter Conditions Min Typ Max Units PHASE COMPARATORS SECTION Input Resistance Signal Input Comparator Input RIN VDD = 5V 1 3 MΩ VDD = 10V 0.2 0.7 MΩ VDD = 15V 0.1 0.3 MΩ VDD = 5V 106 MΩ VDD = 10V 106 MΩ VDD = 15V 106 MΩ CSERIES = 1000 pF AC-Coupled Signal Input Voltage Sensitivity f = 50 kHz VDD = 5V 200 400 mV VDD = 10V VDD = 15V 400 800 mV 700 1400 mV RS ≥ 10 kΩ, VDD = 5V 1.50 2.2 V RS ≥ 10 kΩ, VDD = 10V 1.50 2.2 V RS ≥ 50 kΩ, VDD = 15V 1.50 2.2 V DEMODULATOR OUTPUT Offset Voltage VCOIN- RS ≥ 50 kΩ VDEM Linearity VCOIN = 2.5V±0.3V, VDD = 5V 0.1 % VCOIN = 5V±2.5V, VDD = 10V 0.6 % VCOIN = 7.5V±5V, VDD = 15V 0.8 % ZENER DIODE VZ Zener Diode Voltage IZ = 50 µA RZ Zener Dynamic Resistance IZ = 1 mA 6.3 7.0 100 7.7 V Ω *AC Parameters are guaranteed by DC correlated testing. http://www.hgsemi.com.cn 7 / 14 2014 JUN CD4046B Phase Comparator State Diagrams FIGURE 2 Typical Waveforms PHASE COMPARATORI PHASE COMPARATORI FIGURE 3. Typical Waveform Employing Phase FIGURE 4. Typical Waveform Employing Phase Comparator I in Locked Condition Comparator II in Locked Condition http://www.hgsemi.com.cn 8 / 14 2014 JUN CD4046B Typical Performance Characteristics FIGURE 5a FIGURE 5b FIGURE 5C FIGURE 6a Note: To obtain approximate total power dissipation of PLL system for no-signal input: Phase Comparator I, PD (Total) - PD (fo) + PD (fMIN) + PD (RS); Phas - Comparator II, PD (Total) - PD (fMIN). http://www.hgsemi.com.cn 9 / 14 2014 JUN CD4046B Typical Performance Characteristics (Continued) FIGURE 6b FIGURE 6c FIGURE 7. Typical VCO Linearity vs R1 and C1 Note: To obtain approximate total power dissipation of PLL system for no-signal input: Phase Comparator I, PD (Total) - PD (fo) + PD (fMIN) + PD (RS); Phase Comparator II, PD (Total) - PD (fMIN). http://www.hgsemi.com.cn 10 / 14 2014 JUN CD4046B Design Information This information is a guide for approximating the value of external components for the CD4046B in a phase-lockedloop system. The selected external components must be within the following ranges: R1, R2 ≥ 10 kΩ, RS ≥ 10 kΩ, C1 ≥ 50 pF. In addition to the given design information, refer to Figure 5 for R1, R2 and C1 component selections. Using Phase Comparator I Characteristics VCO Without Offset Using Phase Comparator II VCO With Offset R2= ∞ VCO Without Offset VCO With Offset R2= ∞ VCO Frequency VCO in PLL system will adjust to center frequency, fo For No Signal Input Frequency Lock Range, 2 fL VCO in PLL system will adjust to lowest operating frequency, fmin 2 fL = full VCO frequency range 2 fL = fmax - fmin Frequency Capture 2fc ≈ Range, 2 fC 1 2πfL π π1 fC = fL Loop Filter Component For 2 fC, see Ref. Selection Phase Angle Between Single and Comparator 90° at center frequency (fo), approximating 0° and 180° at ends of lock range (2 fL) Always 0° in lock Locks on Harmonics of Center Frequency Yes No Signal Input Noise Rejection High Low VCO Component Given: fo. Given: fo and fL. Given: fmax. Given:fmin and fmax Selection Use fo with Figure 5a to Calculate fmin Calculate fo from the Use fmin with determine R1 and C1. from the equation equation Figure 5b to fmin = fo - fL. fmax Fo = Use fmin with Figure 5b to determine R2 and C1. Calculate fmax fmin from the equation fmax fmin Use fmax fmin = 2 Use fo with Figure 5a to determine R1 and C1. Determine fmax fmin fmax Use with Figure 5c fmin to determine ration R2/R1 to obtain R1. fo + fL. fo − fL with Figure 5c to determine ratio R2/ R1 to obtain R1. http://www.hgsemi.com.cn 11 / 14 2014 JUN CD4046B Physical Dimensions DIP16 B L1 L E D1 d D A c a b Dimensions In Millimeters(DIP16) A B D D1 E L L1 a b c Min: 6.10 18.94 8.40 7.42 3.10 0.50 300 1.50 0.85 0.40 Max: 6.68 19.56 9.00 7.82 3.55 0.70 3.60 1.55 0.90 0.50 Symbol: d 2.54 BSC SOP16 Q A C1 C B D A1 a 0.25 b Dimensions In Millimeters(SOP16) A A1 B C C1 D Min: 1.35 0.05 9.80 5.80 3.80 0.40 0° 0.35 Max: 1.55 0.20 10.0 6.20 4.00 0.80 8° 0.45 Symbol: http://www.hgsemi.com.cn 12 / 14 Q a b 1.27 BSC 2014 JUN CD4046B Physical Dimensions TSSOP16 Dimensions In Millimeters(TSSOP16) A A1 B C C1 D Min: 0.85 0.05 4.90 6.20 4.30 0.40 0° 0.20 Max: 0.95 0.20 5.10 6.60 4.50 0.80 8° 0.25 Symbol: http://www.hgsemi.com.cn 13 / 14 Q a b 0.65 BSC 2014 JUN CD4046B IMPORTANT STATEMENT: Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the altered documents. Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the occurrence of potential risks that may lead to personal injury or property loss. Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor will not bear the consequences caused by the application of products in these fields. The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance scope of Huaguan Semiconductor. Not all parameters of each device need to be tested. The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages, costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement. http://www.hgsemi.com.cn 14 / 14 2014 JUN
CD4046BE 价格&库存
很抱歉,暂时无法提供与“CD4046BE”相匹配的价格&库存,您可以联系我们找货
CD4046BE
    • 1+0.85360
    • 50+0.65670
    • 1000+0.60500
    库存:1604
    CD4046BE
      • 5+1.41621
      • 50+1.09901
      • 150+0.97071
      • 500+0.81065
      • 2500+0.73937
      • 5000+0.69650
      库存:990
