CD4078BE
CD4078BE
    HGSEMI(华冠)
    DIP-14
    CMOS 八输入或非/或门,高压类型
CD4078BE 数据手册
CD4078B CMOS 8-Input NOR/OR High-Voltage Types(20-Volt Rating) DESCRIPTION CD4078B NOR/OR Gate provides the system designer with direct implementa-tion of the positivelogic 8-input NOR and OR functions and supplements the existing family of CMOS gates. The CD4078B types are supplied in 14-lead dual-in-line plastic packages (N suffix).14-lead small-outline packages(M suffixes) and 14 lead thin shrink small-outline packages(MT suffixes). Features  Medium-Speed Operation: tPHL,tPLH=75ns(typ.) at VDD=10V  Buffered inputs and output  5V,10V and 15V parametric ratings  Standardized symmetrical output characteristics  100% tested for quiescent current at 20V  Maximum input current of 1uA at 18V over fult package-temperature range:100nA at 18V and 25℃   Noise margin (over full package-temperature range): 1V at VDD=5V 2V at VDD=10V 2.5V at VDD=15V Meets all requirements of JEDEC Tentative Standard No. 13B“Standard Specifications for Description of B Series CMOS Devices‘’ ORDERING INFORMATION Device Package Type Marking Packing Packing Qty CD4078BE DIP14 CD4078BE TUBE 1000pcs/box CD4078BM /TR SOP14 CD4078B REEL 2500pcs/reel CD4078BMT/TR TSSOP14 CD4078B REEL 2500pcs/reel CONNECTION DIAGRAM http://www.hgsemi.com.cn 1/9 2022 JULY CD4078B FUNCTIONAL DIAGRAM ABSOLUTE MAXIMUM RATINGS CONDITION MIN MAX Voltages referenced to vss terminal -0.5V +20V Input voltage range all inputs -0.5V Vdd+0.5V DC input current any one input ±10mA Device dissipation per output for ta=full package-temperature range(all transistor package types) 100mW operating-temperature range(TA) -40°C +85°C storage temperature range(Tstg) -65°C +150°C Lead temperature(during soldering): +265°C at distance 1/16±1/32inch(1.59+079mm)from case for 10s max ORDERING INFORMATION Device Package Type Marking Packing Packing Qty CD4078BE DIP14 CD4078BE TUBE 1000pcs/box CD4078BM /TR SOP14 CD4078B REEL 2500pcs/reel CD4078BMT/TR TSSOP14 CD4078B REEL 2500pcs/reel RECOMMENDED OPERATING CONDIYIONS For maximum reliability,nominal operating conditions should be selected so shat operation is laways within the following ranges: CHARACTERISTIC Supply Voltage Range (For TA Full Package Temperature Range) http://www.hgsemi.com.cn 2/9 Min. Max. Units 5 18 V 2022 JULY CD4078B DYNAMIC ELECTRICAL CHARACTERISTICS At TA=25℃;lnput tr tf=20ns,CL=50pf,RL=200kΩ CHARACTERISTIC Propagation Delay Time, tPHL,tPLH Propagation Time, tPHL,tPLH Lnput Caoacitance, CIN TEST CONDITIONS VDD VOLTSZ 5 10 15 5 10 15 LIMITS Any luput TYP. MAX. 150 75 55 400 50 40 5 300 150 110 200 100 80 7.5 UNITS ns ns pF STATIC ELECTRICAL CHARACTCRISTICS CHARACTER. ISTIC Quiescent Device Current, IDD Max. Output Low (Sink) Current lOL Min. Output High (Source) Current, IOH Min. Output Voitage Lew Level, VOL Max. Output Voitage High Level. VOH Min. Input Low Voltage. VIL Max. Input High Voltage. VIN Min. Input Current VIN Max. http://www.hgsemi.com.cn CONDITIONS VO (V) - - - - 0.4 0.5 1.5 4.6 2.5 9.5 13.5 - - - - - - 0.5 4.5 1.9 1.5 13.5 0.5 4.5 1.9 1.5 13.5 LIMITS AT INDICATED TEMPERATURES(℃) 0.05 0.05 0.05 1.95 9.95 14.95 4.95 9.95 14.95 +25 Typ. 0.01 0.01 0.01 0.02 1 2.6 6.8 -1 -3.2 -2.6 -6.8 0 0 0 5 10 15 5 1.5 - - 1.5 - 10 3 - - 3 - 15 4 - - 4 - 5 3.5 3.5 - - - 10 7 7 - - - 15 11 11 - - 0.18 18 - ±10-5 ±0.1 VIN (V) 0.5 0.10 0.15 0.20 0.5 0.10 0.15 0.5 0.5 0.10 0.15 0.5 0.10 0.15 0.5 0.10 0.15 VDD (V) 5 10 15 20 5 10 15 5 5 10 15 5 10 15 5 10 15 - -40 0.25 0.5 1 5 0.61 1.5 4 -0.61 -1.8 -1.5 -4 ±0.1 3/9 +85 7.5 15 30 150 0.42 1.1 2.8 -0.42 -1.3 -1.1 -2.8 ±1 Min. - - - - 0.51 1.3 3.4 -0.51 -1.6 -1.3 -3.4 Max. 0.25 0.5 1 5 UNITS µA mA 0.05 0.05 0.05 V V µA 2022 JULY CD4078B TYPICAL CHARA CTERISTIC Fig.1-Logic diagram. Fig.2-Typocal output low(sink)current Fig.3-Minimum output low(sink)current characteristics. characteristics. Fig.4 -Typocal output high(souece)current Fig.5 -Minimum output high(source)currnt characteristics. characteristics. http://www.hgsemi.com.cn 4/9 2022 JULY CD4078B Fig.6 -Typocal transition time as a function of load Fig.7 -Typocal propagation delay time as a function capacitance. of load capacirance. Fig.8 -Schematic diagram. http://www.hgsemi.com.cn 5/9 2022 JULY CD4078B Fig.9 -Typocal voltage transfer charac-teristics(NOR Fig.10 -Typocal dynamic power dissipation as a output). function of frequency. Fig.11 -Quiescent-device-current test circut. Fig.12 -lnput current test circuit. Fig.13 -lnput voltage test circuit. Fig.14 -Dynamic power dissipation test circuit http://www.hgsemi.com.cn 6/9 2022 JULY CD4078B Physical Dimensions DIP-14L B L1 L E D1 D d A c a Dimensions In Millimeters(DIP14L) A B D D1 E L L1 a c Min: 6.10 18.94 8.40 7.42 3.10 0.50 3.00 1.50 0.40 Max: 6.68 19.56 9.00 7.82 3.55 0.70 3.60 1.55 0.50 Symbol: d 2.54 BSC SOP14L Q A C C1 B D A1 a 0.25 b Dimensions In Millimeters(SOP14L) A A1 B C C1 D Min: 1.35 0.05 8.55 5.80 3.80 0.40 0° 0.35 Max: 1.55 0.20 8.75 6.20 4.00 0.80 8° 0.45 Symbol: http://www.hgsemi.com.cn 7/9 Q a b 1.27 BSC 2022 JULY CD4078B Physical Dimensions TSSOP-14L Dimensions In Millimeters(TSSOP14L) A A1 B C C1 D Min: 0.85 0.05 4.90 6.20 4.30 0.40 0° 0.20 Max: 0.95 0.20 5.10 6.60 4.50 0.80 8° 0.25 Symbol: http://www.hgsemi.com.cn 8/9 Q a b 0.65 BSC 2022 JULY CD4078B IMPORTANT STATEMENT: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the onsequences of the application of these products in these fields. Huaguan Semiconductor Co,Ltd. the performance of the semiconductor products produced by the company can reach the performance indicators that can be applied at the time of sales. The use of testing and other quality control technologies is limite d to the quality assurance scope of Huaguan semiconductor. Not all parameters of each device need to be tested. The above documents are for reference only, and all are subject to the physical parameters. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 9/9 2022 JULY
CD4078BE 价格&库存
很抱歉,暂时无法提供与“CD4078BE”相匹配的价格&库存,您可以联系我们找货
