74HC03N
74HC03N
    HGSEMI(华冠)
    DIP-14
    带漏极开路输出的四路 2 输入与非门
74HC03N 数据手册
74HC03 Quadruple 2-Input NAND Gates with Open-Drain Outputs Features  Wide Operating Voltage Range: 2 V to 6 V  Outputs Can Drive Up To 10 LSTTL Loads  Low Power Consumption, 20-µA Maximum ICC  Typical tpd = 8 ns at 5 V  ±4-mA Output Drive at 5 V  Low Input Current of 1 µA DIP14 SOP14 TSSOP14 Ordering Information DEVICE Package Type MARKING Packing Packing Qty 74HC03N DIP14 74HC03 TUBE 1000pcs/Box 74HC03M/TR SOP14 74HC03 REEL 2500pcs/Reel TSSOP14 74HC03 REEL 2500pcs/Reel 74HC03MT/TR http://www.hgsemi.com.cn 1 / 11 2020 MAR 74HC03 Description This device contains four independent 2-input NAND Gates with open-drain outputs. Each gate performs the Boolean function Y = A ● B in positive logic Functional pinout Pin Configuration DIP14/SOP14/TSSOP14 Pin Functions PIN NAME DIP/SOP/TSSOP 1A 1B 1Y 2A 2B 2Y GND 3Y 3A 3B 4Y 4A 4B VCC 1 2 3 4 5 6 7 8 9 10 11 12 13 14 http://www.hgsemi.com.cn I/O Input Input Output Input Input Output — Output Input Input Output Input Input — DESCRIPTION Channel 1, Input A Channel 1, Input B Channel 1, Output Y Channel 2, Input A Channel 2, Input B Channel 2, Output Y Ground Channel 3, Output Y Channel 3, Input A Channel 3, Input B Channel 4, Output Y Channel 4, Input A Channel 4, Input B Positive Supply 2 / 11 2020 MAR 74HC03 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted)(1) VCC UNIT –0.5 7 V Input clamp current(2) VI < 0 or VI > VCC ±20 mA IOK Output clamp current(2) VO < 0 or VO > VCC ±20 mA Continuous output current VO = 0 to VCC ±25 mA Continuous current through VCC or GND ±50 mA Junction temperature(3) 150 °C 150 °C TJ Tstg 2. 3. MAX IIK IO 1. Supply voltage MIN Storage temperature –65 Stresses beyond those listed under Absolute Maximum Rating may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Condition. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Guaranteed by design. Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) VCC VIH VIL Supply voltage High-level input voltage Low-level input voltage MIN NOM MAX UNIT 2 5 6 V VCC = 2 V 1.5 VCC = 4.5 V 3.15 VCC = 6 V 4.2 V VCC = 2 V 0.5 VCC = 4.5 V 1.35 VCC = 6 V 1.8 V VI Input voltage 0 VCC V VO Output voltage 0 VCC V Δt/Δv TA Input transition rise and fall rate Operating free-air temperature http://www.hgsemi.com.cn VCC = 2 V 1000 VCC = 4.5 V 500 VCC = 6 V 400 74HC03 3 / 11 –40 85 ns °C 2020 MAR 74HC03 Thermal Information 74HC03 THERMAL METRIC(1) (SOP) (DIP) (TSSOP) 14 PINS 14 PINS 14 PINS 133.6 66.0 151.7 °C/W 89 53.7 79.4 °C/W 89.5 45.7 94.7 °C/W 45.5 33.3 25.2 °C/W 89.1 45.5 94.1 °C/W N/A N/A N/A °C/W Junction-to-ambient RθJA thermal resistance RθJC(top) Junction-to-case (top) thermal resistance Junction-to-board RθJB thermal resistance Junction-to-top ΨJT characterization parameter Junction-to-board characterization ΨJB parameter RθJC(bot) Junction-to-case (bottom) thermal resistance UNIT Electrical Characteristics over operating free-air temperature range (unless otherwise noted) (1) (2) Operating free-air temperature (TA) PARAMETER TEST CONDITIONS VCC 25°C MIN IOH VOL VI = VIH or VIL Low-level VI = VIH output voltage or VIL Input leakage II current ICC Ci Output voltage 6V 0.01 0.5 5 2V 0.002 0.1 0.1 4.5 V 0.001 0.1 0.1 6V 0.001 0.1 0.1 IOL = 4 mA 4.5 V 0.17 0.26 0.33 IOL = 5.2 mA 6V 0.15 0.26 0.33 6V ±0.1 ±1 µA 6V 2 20 µA 10 10 pF VO = VCC IOL = 20 µA IO = 0 Input capacitance (1) VCCI is the VCC associated with the input port. (2) VCCO is the VCC associated with the output port. http://www.hgsemi.com.cn 2 V to 6 V 4 / 11 3 MIN TYP UNIT MAX VI = VCC or 0 Supply current VI = VCC or 0 -40°C to 85°C TYP MAX µA V 2020 MAR 74HC03 Switching Characteristics over operating free-air temperature range (unless otherwise noted) Operating free-air temperature (TA) PARAMETER FROM TO VCC 25°C MIN tplh tphl tt Propagation delay, low-to-high Propagation delay high-to-low A or B Y A or B Y Transition-time Y –40°C to 85°C TYP MAX MIN TYP 2V 60 105 131 4.5 V 13 25 31 6V 10 23 27 2V 50 100 125 4.5 V 10 20 25 6V 8 17 21 2V 38 75 95 4.5 V 8 15 19 6V 6 13 16 UNIT MAX ns ns ns Operating Characteristics over operating free-air temperature range; typical values measured at TA = 25°C (unless otherwise noted) PARAMETER Cpd Power dissipation capacitance per gate TEST CONDITIONS VCC No load 2 V to 6 V MIN TYP 20 MAX UNIT pF Typical Characteristics(TA = 25°C ) IOL Output Low Current (mA) Figure 5-1. Typical output voltage in the low state (VOL) http://www.hgsemi.com.cn 5 / 11 2020 MAR 74HC03 Parameter Measurement Information Phase relationships between waveforms were chosen arbitrarily. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tt < 6 ns. The outputs are measured one at a time, with one input transition per measurement A. CL= 50 pF and includes probe and jig capacitance A. tt is the greater of tr and tf. Figure 6-1. Load Circuit Figure 6-2. Voltage Wave forms Transition Times A. The maximum between tPLH and tPHL is used for tpd. Figure 6-3. Voltage Wave forms Propagation Delays http://www.hgsemi.com.cn 6 / 11 2020 MAR 74HC03 Detailed Description Overview This device contains four independent 2-input NAND gates with open-drain outputs. Each gate performs the Boolean function Y = A ● B in positive logic. Functional Block Diagram Feature Description CMOS Open-Drain Outputs The open-drain output allows the device to sink current to GND but not to source current from VCC. When the output is not actively pulling the line low, it will go into a high impedance state. This allows the device to be used for a wide variety of applications, including up-translation and down-translation, as the output voltage can be determined by an external pull-up resistor. The current drive capability of this device creates fast edges into light loads, so routing and load conditions should be considered to prevent ringing. Additionally, the outputs of this device are capable of driving larger currents than the device can sustain without being damaged. It is important for the power output of the device to be limited to avoid thermal runaway and damage due to over-current. The electrical and thermal limits defined the in the Absolute Maximum Ratingsmust be followed at all times. The 74HC03 can drive a load with a total capacitance less than or equal to the maximum load listed in the Switching Characteristics connected to a high-impedance CMOS input while still meeting all of the datasheet specifications. Larger capacitive loads can be applied, however it is not recommended to exceed the provided load value. If larger capacitive loads are required, it is recommended to add a series resistor between the output and the capacitor to limit output current to the values given in the Absolute Maximum Ratings. Standard CMOS Inputs Standard CMOS inputs are high impedance and are typically modeled as a resistor from the input to ground in parallel with the input capacitance given in the Electrical Characteristics. The worst case resistance is calculated with the maximum input voltage, given in the Absolute Maximum Ratings, and the maximum input leakage current, given in the Electrical Characteristics, using ohm's law (R = V ÷ I). http://www.hgsemi.com.cn 7 / 11 2020 MAR 74HC03 Signals applied to the inputs need to have fast edge rates, as defined by the input transition time in the Recommended Operating Conditions to avoid excessive current consumption and oscillations. If a slow or noisy input signal is required, a device with a Sch mitt -trigger input should be used to condition the input signal prior to the standard CMOS input. Clamp Diode Structure The inputs and outputs to this device have both positive and negative clamping diodes as depicted in Figure 7-1. CAUTION Voltages beyond the values specified in the Absolute Maximum Ratings table can cause damage to the device. The recommended input and output voltage ratings may be exceeded if the input and output clamp-current ratings are observed. Figure 7-1. Electrical Placement of Clamping Diodes for Each Input and Output Device Functional Modes Table 7-1. Function Table INPUTS OUTPUT A B Y H H L L X Z X L Z http://www.hgsemi.com.cn 8 / 11 2020 MAR 74HC03 Physical Dimensions DIP14 B L1 L E D1 D d A c a Dimensions In Millimeters(DIP14) A B D D1 E L L1 a c Min: 6.10 18.94 8.40 7.42 3.10 0.50 3.00 1.50 0.40 Max: 6.68 19.56 9.00 7.82 3.55 0.70 3.60 1.55 0.50 Symbol: d 2.54 BSC SOP14 Q A C C1 B D A1 a 0.25 b Dimensions In Millimeters(SOP14) A A1 B C C1 D Min: 1.35 0.05 8.55 5.80 3.80 0.40 0° 0.35 Max: 1.55 0.20 8.75 6.20 4.00 0.80 8° 0.45 Symbol: http://www.hgsemi.com.cn 9 / 11 Q a b 1.27 BSC 2020 MAR 74HC03 Physical Dimensions TSSOP14 Dimensions In Millimeters(TSSOP14) A A1 B C C1 D Min: 0.85 0.05 4.90 6.20 4.30 0.40 0° 0.20 Max: 0.95 0.20 5.10 6.60 4.50 0.80 8° 0.25 Symbol: http://www.hgsemi.com.cn 10 / 11 Q a b 0.65 BSC 2020 MAR 74HC03 IMPORTANT STATEMENT: Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the altered documents. Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the occurrence of potential risks that may lead to personal injury or property loss. Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor will not bear the consequences caused by the application of products in these fields. The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance scope of Huaguan Semiconductor. Not all parameters of each device need to be tested. The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages, costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement. http://www.hgsemi.com.cn 11 / 11 2020 MAR
74HC03N 价格&库存
很抱歉,暂时无法提供与“74HC03N”相匹配的价格&库存,您可以联系我们找货
74HC03N
  • 5+1.34849
  • 50+0.99501
  • 150+0.87837
  • 500+0.73289
  • 2500+0.66809
  • 5000+0.62910
库存:274
