CD4023BE
CD4023BE
    HGSEMI(华冠)
    DIP-14
    CMOS 三路 3 输入与非门
CD4023BE 数据手册
CD4023B Features:  Wide supply voltage range from 3V to 15V  Fully static operation DIP14  5V, 10V, and 15V parametric ratings  Standardized symmetrical output characteristics  Inputs and outputs are protected against electrostatic effects SOP14  Specified from -40℃ to +105℃  Packaging information: DIP14/SOP14/TSSOP14 TSSOP14 Ordering Information DEVICE Package Type MARKING Packing Packing Qty CD4023BE DIP14 CD4023BE TUBE 1000pcs/Box CD4023BM/TR SOP14 CD4023B REEL 2500pcs/Reel TSSOP14 CD4023B REEL 2500pcs/Reel CD4023BMT/TR General Description The CD4023B provides the positive triple 3-input NAND function. The outputs are fully buffered for highest noise immunity and pattern insensitivity of output impedance. It operates over a recommended VDD power supply range of 3V to 15V referenced to GND (usually ground). Unused inputs must be connected to VDD, GND, or another input. http://www.hgsemi.com.cn 1/9 2012 MAR CD4023B Block Diagram Figure 2 Logic diagram (one gate) Figure 1. Functional diagram Pin Configurations DIP14,SOP14,TSSOP14 Pin Description Pin No. Pin Name Description 1 2A data input 2 2B data input 3 1A data input 4 1B data input 5 1C data input 6 1Y data output 7 GND ground (0V) 8 2C data input 9 2Y data output 10 3Y data output 11 3C data input 12 3B data input 13 3A data input 14 VDD supply voltage http://www.hgsemi.com.cn 2/9 2012 MAR CD4023B Function Table Input Output nA nB nC nY L X X H X L X H X X L H H H H L Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care. Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage VDD - -0.5 +18 V DC input current IIK any one input - ±10 mA input voltage VI all inputs -0.5 VDD+0.5 V storage temperature Tstg - -65 +150 ℃ Ptot - - 500 mW device dissipation P per output transistor - 100 mW Soldering temperature TL total power dissipation 10s DIP 245 SOP 250 ℃ Note: (1) For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. (2) For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. (3) For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. Recommended Operating Conditions Parameter Symbol Conditions Min. Typ. Max. Unit supply voltage VDD - 3 - 15 V ambient temperature Tamb in free air -40 - +105 ℃ http://www.hgsemi.com.cn 3/9 2012 MAR CD4023B Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter supply current LOW-level output current HIGH-level Symbol IDD IOL IOH output current LOW-level output voltage HIGH-level output voltage LOW-level input voltage HIGH-level input voltage input leakage current VOL VOH VIL VIH II http://www.hgsemi.com.cn Tamb=25℃ Conditions (V) Unit VO VIN VDD Min. Typ. Max. - 0, 5 5 - 0.01 0.25 uA - 0, 10 10 - 0.01 0.5 uA - 0, 15 15 - 0.01 1 uA 0.4 0, 5 5 0.51 1 - mA 0.5 0, 10 10 1.3 2.6 - mA 1.5 0, 15 15 3.4 6.8 - mA 4.6 0, 5 5 -0.51 -1 - mA 2.5 0, 5 5 -1.6 -3.2 - mA 9.5 0, 10 10 -1.3 -2.6 - mA 13.5 0, 15 15 -3.4 -6.8 - mA - 0, 5 5 - 0 0.05 V - 0, 10 10 - 0 0.05 V - 0, 15 15 - 0 0.05 V - 0, 5 5 4.95 5 - V - 0, 10 10 9.95 10 - V - 0, 15 15 14.95 15 - V 0.5, 4.5 - 5 - - 1.5 V 1, 9 - 10 - - 3 V 1.5, 13.5 - 15 - - 4 V 4.5 - 5 3.5 - - V 9 - 10 7 - - V 13.5 - 15 11 - - V - 0, 15 15 - ±10-5 ±0.1 uA 4/9 2012 MAR CD4023B DC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter supply current LOW-level output current HIGH-level output current LOW-level output voltage HIGH-level output voltage LOW-level input voltage HIGH-level input voltage input leakage current Conditions (V) Symbol Tamb=-40℃ Tamb=+85℃ Tamb=+105℃ Unit VO VIN VDD Min. Max. Min. Max. Min. Max. - 0, 5 5 - 0.25 - 7.5 - 7.5 uA - 0, 10 10 - 0.5 - 15 - 15 uA - 0, 15 15 - 1 - 30 - 30 uA 0.4 0, 5 5 0.61 - 0.42 - 0.36 - mA 0.5 0, 10 10 1.5 - 1.1 - 0.9 - mA 1.5 0, 15 15 4 - 2.8 - 2.4 - mA 4.6 0, 5 5 -0.61 - -0.42 - -0.36 - mA 2.5 0, 5 5 -1.8 - -1.3 - -1.15 - mA 9.5 0, 10 10 -1.5 - -1.1 - -0.9 - mA 13.5 0, 15 15 -4 - -2.8 - -2.4 - mA - 0, 5 5 - 0.05 - 0.05 - 0.05 V - 0, 10 10 - 0.05 - 0.05 - 0.05 V - 0, 15 15 - 0.05 - 0.05 - 0.05 V - 0, 5 5 4.95 - 4.95 - 4.95 - V - 0, 10 10 9.95 - 9.95 - 9.95 - V - 0, 15 15 14.95 - 14.95 - 14.95 - V 4.5 - 5 - 1.5 - 1.5 - 1.5 V 9 - 10 - 3 - 3 - 3 V 13.5 - 15 - 4 - 4 - 4 V 0.5,4.5 - 5 3.5 - 3.5 - 3.5 - V 1.9 - 10 7 - 7 - 7 - V 1.5,13.5 - 15 11 - 11 - 11 - V - 0, 15 15 - ±0.1 - ±1 - ±1 uA IDD IOL IOH VOL VOH VIL VIH II AC Characteristics (Tamb=25℃, GND=0V, tr, tf=20ns, CL=50pF, RL=200kΩ, unless otherwise specified.) Parameter propagation delay time transition time input capacitance Symbol tPHL, tPLH tTHL, tTLH CI http://www.hgsemi.com.cn Conditions see Figure 4 see Figure 4 Min. Typ. Max. Unit VDD=5V - 125 250 ns VDD=10V - 60 120 ns VDD=15V - 45 90 ns VDD=5V - 100 200 ns VDD=10V - 50 100 ns VDD=15V - 40 80 ns - 5 7.5 pF any input 5/9 2012 MAR CD4023B AC Testing Circuit Figure 3. Test circuit for switching times Definitions for test circuit: DUT=Device Under Test. CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. AC Testing Waveforms Figure 4. Propagation delay, output transition time Measurement Points Supply voltage Input Output VDD VM VM 5V to 15V 0.5×VDD 0.5×VDD Test Data Supply voltage Input Load VDD VI tr , tf CL 5V to 15V GND or VDD ≤ 20ns 50pF http://www.hgsemi.com.cn 6/9 2012 MAR CD4023B Physical Dimensions DIP14 B L1 L E D1 D d A c a Dimensions In Millimeters(DIP14) A B D D1 E L L1 a c Min: 6.10 18.94 8.40 7.42 3.10 0.50 3.00 1.50 0.40 Max: 6.68 19.56 9.00 7.82 3.55 0.70 3.60 1.55 0.50 Symbol: d 2.54 BSC SOP14 Q A C C1 B D A1 a 0.25 b Dimensions In Millimeters(SOP14) A A1 B C C1 D Min: 1.35 0.05 8.55 5.80 3.80 0.40 0° 0.35 Max: 1.55 0.20 8.75 6.20 4.00 0.80 8° 0.45 Symbol: http://www.hgsemi.com.cn 7/9 Q a b 1.27 BSC 2012 MAR CD4023B Physical Dimensions TSSOP14 Dimensions In Millimeters(TSSOP14) A A1 B C C1 D Min: 0.85 0.05 4.90 6.20 4.30 0.40 0° 0.20 Max: 0.95 0.20 5.10 6.60 4.50 0.80 8° 0.25 Symbol: http://www.hgsemi.com.cn 8/9 Q a b 0.65 BSC 2012 MAR CD4023B IMPORTANT STATEMENT: Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the altered documents. Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the occurrence of potential risks that may lead to personal injury or property loss. Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor will not bear the consequences caused by the application of products in these fields. The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance scope of Huaguan Semiconductor. Not all parameters of each device need to be tested. The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages, costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement. http://www.hgsemi.com.cn 9/9 2012 MAR
CD4023BE 价格&库存
很抱歉,暂时无法提供与“CD4023BE”相匹配的价格&库存,您可以联系我们找货
