7C-24.000MBB-T
7C-24.000MBB-T
    TXC(台晶)
    SIP4
    XTAL OSC XO 24.0000MHZ CMOS SMD
7C-24.000MBB-T 数据手册
Oscillators 5 x 3.2 mm SMD CMOS CXO 7C SERIES Features > Ultra small SMD seam sealed clock crystal oscillator units. > High precision characteristic covering up to wide frequency range. > Designed for automatic mounting and reflow soldering. > Optionable stand-by function for output: Tri-state output. > Supply voltage range : 1.8 V ~ 5.0 V > High stability, low jitter, low power consumption. > Main application : wireless communication set, PDA, and DSC. > RoHS Compliant / Pb Free. Electrical Specifications Item / Type 7C Output Type CMOS Output Load 15 pF Oscillation Mode Supply Voltage 15 pF , 30 pF 1.8 V 5V 2.5 V , 2.8 V , 3.3 V Frequency Range 1 ~ 150 MHz Frequency Stability ± 50 ppm (-10 ~ + 70 ºC), or specify Operating Temperature Range - 40 ~ + 85 ºC Storage Temperature Range - 55 ~ + 125 ºC Voltage Vol (Max.) / Voh (Min.) 0.1 VDD / 0.9 VDD Rise (Tr) / Fall (Tf) Time Supply Current 10 ns Max. 20 mA Max. 30 mA Max. Symmetry 40 ~ 60 % Start-up Time 10 ms Max Oscillators Phase Jitter (12 KHz ~ 20 MHz) Aging (at 25 ºC) 1 ps Max ± 3 ppm / year Max. Dimensions PAD FUNCTION: 1:ENABLE CONTROL 2:GND 3:OUT 4:VDD Suggested Layout Units:mm Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com 30 15 pF , 50 pF Fundamental / 3rd Overtone 45 mA Max.
7C-24.000MBB-T 价格&库存
很抱歉,暂时无法提供与“7C-24.000MBB-T”相匹配的价格&库存,您可以联系我们找货
7C-24.000MBB-T
  • 1+16.55560
库存:5
