TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING CXO 3.2 × 2.5
NOMINAL FREQ.
24.000000MHz
TXC P/N
7X24000001
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
Attachment: Product Specification Sheet
1
2
3
4
5
FMT-DOC024
RoHS Compliant
Issue Date: 02.20'14 VER.F
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
24.000000MHz
TXC P/N
7X24000001
REVISION
A1
PE/RD
QA
MFG
Oscar Chen
Alex Huang
Leye Tang
20-May-14
20-May-14
20-May-14
NOTE:
(1) The green product standard set by TXC is based upon the international standards. Related
information is publicly described on the TXC's Website, and updated regularly. The document is
compliant with the latest green product quality system directives at the time.
(2) Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3) Revision "Ax" is production ready. PE, QA and MFG's approval required.
RoHS Compliant
FMT-DOC024
TXC CORPORATION
Rev
Revise page
A1
N/A
FMT-DOC024
TXC P/N: 7X24000001
Revise contents
Initial released
REVISION: A1
PAGE: 1
Date
Ref.No.
Reviser
20-May-14
N/A
Yachuan Miao
TXC CORPORATION
TXC P/N: 7X24000001
REVISION: A1
PAGE: 2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.025±0.002 g/pcs
Parameters
Symbol
Electrical Spec.
Min.
Typ.
Max.
Notes
Units
1 Nominal Frequency
24.000000
MHz
2 Frequency Stability
±30
ppm
Topr
-40
4 Storage Temperature
Tstg
-55
5 Supply Voltage
VDD
3 Operating Temperature
Icc
6 Input Current
125
V
mA
Yes
Pad 1
pF
9 Output Voltage High
VoH
90%Vdd
V
10 Output Voltage Low
VoL
10%Vdd
V
Tr
10
ns
10%→90%VDD Level
90%→10%VDD Level
8 Output Load :
CMOS
85
3.3 ±10%
7 Enable Control
25
11 Rise Time
CL
15
Tf
10
ns
13 Symmetry (Duty ratio)
TH/T
45
55
14 Start-up Time
Tosc
10
ms
15 Enable Voltage High
Vhi
70%Vdd
V
16 Disable Voltage Low
Vlo
30%Vdd
V
12 Fall Time
17 Aging
±3
ppm/yr. 1st. Year at 25℃
18 Output Disable Delay Time
T off
150
us
19 Output Enable Delay Time
T on
150
us
FMT-DOC024
TXC CORPORATION
TXC P/N:
7X24000001 REVISION: A1
PAGE: 3
■ DIMENSIONS
(Unit:mm)
1.00±0.10
3.20±0.10
3
PAD FUNCTION:
2.50±0.10
4
1: ENABLE CONTROL
2: GND
3: OUT
4: VDD
1
2
4
3
0.80 1.40
1.20
0.50
1
1.40
1.20
1.20±0.15
Suggested Layout
1.00±0.15
0.90±0.15
0.65±0.15
2
■ MARKING
T □□□
TXC Logo
Pin 1 Location
Frequency Code
ex:14.318180 MHz=143
Lot Code
Date Code
Output Level
Output Level:
VDD(V)
CODE
5.00 3.30 2.80 2.50 1.80 2.90 3.00 2.85 2.60 2.55 2.00 1.50 2.70 3.40 1.90 1.20 1.00
A
B
C
D
E
F
G
H
J
K
L
M
N
P
Q
R
S
1
2
3
4
5
6
7
8
9
10 11 12
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
Production location:Taiwan
FMT-DOC024
TXC CORPORATION
TXC P/N:
7X24000001
REVISION: A1
PAGE: 4
■ TEST DIAGRAM
Control input (output enable/disable)
Logic 1 or open on pad 1: Oscillator output
Logic 0 on pad 1 : Disable output to high impedance
■ WAVEFORM CONDITIONS
Waveform measurement system should
have a min. bandwidth of 5 times the
frequency being tested.
FMT-DOC024
TXC CORPORATION
TXC P/N:
7X24000001
REVISION: A1
PAGE: 5
■ OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay.
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
FMT-DOC024
TXC CORPORATION
TXC P/N:
PAGE: 6
■ STRUCTURE ILLUSTRATION
6
5
3
4
NO
1
7
COMPONENTS
8
2
FINISH/SPECIFICATIONS
MATERIALS
1 Lid
Kovar (Fe/Co/Ni)
2 Base (Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad (Au)
3 IC chip
4 Crystal blank
SiO2
5 Conductive adhesive Ag
Silicon resin
6 Electrode
Noble Metal
7 Die attached
Conductive (Ag)
Epoxy resin
8 Bonding wire
Au
FMT-DOC024
Pad 1 options : NC is 5 wires ,
EN is 6 wires.
TXC CORPORATION
TXC P/N:
PAGE: 7
■ EMBOSS CARRIER TAPE & REEL
A
DIMENSIONS
B
C
D
E
F
G
H
1.65
3.40
2.70
4.00
8.00
4.00
1.55
1.75
±0.10
±0.10
±0.10
±0.10
±0.20
±0.10
±0.05
±0.10
(UNIT:mm)
REMARK :
DIMENSIONS
FMT-DOC024
L
178
L1
60.2
W
11.5
W1
8
±1.00
±0.50
±0.2
+1/-0
Standard Reel Quantity is 3,000 pcs per reel
(UNIT:mm)
TXC CORPORATION
TXC P/N:
PAGE: 7
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
Test Methods
REF. DOC
JIS C6701
1 Drop Test
75 cm height,3 times on concrete floor .
1 Mechanical Shock
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
1 Vibration
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minutes
perpendicular axes each test time
4 Hrs
MIL-STD-202
MIL-STD-883
(Total test time 12 Hrs)
1 Gross Leak
Standard Sample For Automatic Gross Leak Detector, Test
Pressure: 2kg / cm2
MIL-STD-883
2 Fine Leak
Helium Bomging 4.5 kgf / cm 2 for 2 Hrs
MIL-STD-883
2 Solderability
Temperature
245 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
MIL-STD-883
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs
2 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
REF. DOC
MIL-STD-202
MIL-STD-883
Total 100 cycles of the following temperature cycle
2 Thermal Shock
MIL-STD-883
3 High Temp&Humidity
85℃ ± 3℃, RH 85% , 1000 Hrs
EIA-JESD22
3 Pressure Cooker Storage
121 ± 3℃ , RH100% , 2 bar , 240 Hrs
EIA-JESD22
FMT-DOC024
很抱歉,暂时无法提供与“7X24000001”相匹配的价格&库存,您可以联系我们找货
