7B08070003
7B08070003
    TXC(台晶)
    SMD5032_4P
    无源晶振 SMD5032_4P
7B08070003 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0 × 3.2 NOMINAL FREQ. : 8.000000MHz TXC P/N : 7B08070003 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. MSL:Level 1 RoHS Compliant FMT-DOC024 Issue Date: 02.20'14 VER.F TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING XTAL 5.0 × 3.2 NOMINAL FREQ. : 8.000000MHz TXC P/N : 7B08070003 REVISION : A1 PE/RD QA MFG Robin Huang Samson Xiong Jake Liu 23-Sep-14 23-Sep-14 23-Sep-14 NOTE: (1)The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required MSL:Level 1 RoHS Compliant FMT-DOC024 Issue Date: 02.20'14 VER.F TXC P/N: TXC CORPORATION 7B08070003 A1 REVISION: PAGE: 1 Date Ref.No. Reviser Initial released 31-May-11 N/A Xiaoyan Jiang 7 Change Label A& Label B, Deleted Label C "G" Mark 11-Oct-11 ECR-11N092802 Xiaoyan Jiang S3 3 Frequency Tolerance Frequency Stability Change 15-Aug-13 ECR-13N081906 Xiaoyan Jiang A1 N/A S Turn A 23-Sep-14 N/A Xiaoyan Jiang Rev Revise page S1 N/A S2 FMT-DOC024 Revise contents Issue Date: 02.20'14 VER.F TXC CORPORATION TXC P/N: 7B08070003 REVISION: A1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 MARKING P.4 5 SUGGESTED REFLOW PROFILE & MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS FMT-DOC024 P.8~9 Issue Date: 02.20'14 VER.F TXC P/N: 7B08070003 TXC CORPORATION REVISION: A1 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.046±0.010 g/pcs Parameters SYM. Electrical Spec. MIN TYP MAX Notes UNITS FL 8.000000 MHz - - Fundamental - - CL 10 pF - Frequency Tolerance - ±20 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 8 Drive Level DL - 100 - uW - 9 Equivalent Resistance Rr Rr - - 80 Ω - 10 Shunt Capacitance C0 C0 - - 5 pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 85 ℃ 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance 4 -40 ~ 85 ±3 - ℃ ppm 1st Year at DC 100V - ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Rd., Beilun District, Ningbo, Zhejiang, China FMT-DOC024 Issue Date: 02.20'14 VER.F 7B08070003 TXC P/N: TXC CORPORATION REVISION: A1 PAGE: 4 ■ DIMENSIONS (Unit:mm) 5.0 ± 0.15 0.25 3 3.2 ± 0.15 1 Connection 3 GND 2 4 0.9± 0.15 4 GND 1 2 Suggested Layout 4 2.0 1.2 1.0 1.2 1.7 0.9± 0.15 2 1 1.4 ± 0.15 2.0 2.6 ± 0.15 1.2 ± 0.15 3 *Coplanarity of solderable areas Camber 0.10 mm Max ■ MARKING   TXC □□□□ TXC Logo Frequency Code Pin 1 Location ■ □□□□ Ex.: 8.000000 MHz = 8.00 Lot Code Line Code Date Code Date Code: MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years ■ SUGGESTED REFLOW PROFILE Solder melting point : 220 ± 10 ℃ , 60 sec. Min. Peak Temperature: 260 ± 5 ℃ , 10 sec. Max. (℃) 10 sec 260 220 180 ■ SUGGESTED MANUAL SOLDER CONDITION 150 Temperature: 350 ± 10 ℃ Time: 3 sec. Time (sec) 120 sec 60 sec Re-solder times: twice FMT-DOC024 Issue Date: 02.20'14 VER.F 7B08070003 TXC P/N: TXC CORPORATION A1 REVISION: PAGE: 5 ■ STRUCTURE ILLUSTRATION 5 6 4 1 2 3 COMPONENTS NO MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 2 Package Ceramic (AI2O3) + Kovar (Fe/Co/Ni) - 3 PAD Au Tungsten metalize + Ni plating + Au plating SiO2 - 4 Crystal blank 5 Conductive adhesive Resin + Ag - 6 Electrode Ag - FMT-DOC024 Issue Date: 02.20'14 VER.F TXC P/N: TXC CORPORATION 7B08070003 A1 REVISION: PAGE: 6 ■ EMBOSS CARRIER TAPE & REEL DIMENSIONS A 1.65±0.10 B C D E F G H 5.40±0.10 3.50±0.10 8.00±0.10 12.00±0.30 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm) REMARK : Products put in 1000pcs Trailer 160mm(Min) Empty Sealed Leader 160mm(Min) 230mm(Min) User direction of feed DIMENSIONS FMT-DOC024 L L1 W W1 180±1.00 13±0.50 16.5±0.20 12±0.10 (UNIT:mm) Issue Date: 02.20'14 VER.F TXC P/N: TXC CORPORATION 7B08070003 REVISION: A1 PAGE: 7 ■PACKING Reel Quantity : 1. Reel X 5 (5 Reels x 1) 2. Reel X 10 (10 Reels x 1) 3. Reel X 20 (10 Reels x 2) 4. Reel X 40 (10 Reels x 4) Label B Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label A Label B QA Pass (Label A) Size:100 X 100mm (Label B) Size:80 X 40mm [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC024 Issue Date: 02.20'14 VER.F TXC CORPORATION TXC P/N: 7B08070003 REVISION: A1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Criteria 75 cm height,3 times on concrete floor . A‧C Mechanical Shock Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5 ms duration time A‧C Vibration Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes Perpendicular axes each test time 4 Hrs Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcoho 1.1 Drop Test 1.2 Test Methods Test Item 1.3 A‧C (Total test time 12 Hrs) Solderability 1.4 E solvent ( 1 : 4 ) 2.Environmental Endurance No. 2.1 Test Methods Test Item Resistance To Soldering Heat Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. Test Criteria B‧C‧D 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for 500 ± 12 Hrs B‧C‧D 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 500 ± 12 Hrs B‧C‧D Total 100 cycles of the following temperature cycle 2.4 Temperature cycle 2.5 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 500 Hrs FMT-DOC024 B‧C‧D B‧C‧D Issue Date: 02.20'14 VER.F TXC CORPORATION TXC P/N: 7B08070003 REVISION A1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±5ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 2 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. Measurement condition Electrical characteristics measured by S&A250B or equivalent. FMT-DOC024 Issue Date: 02.20'14 VER.F
7B08070003 价格&库存
很抱歉,暂时无法提供与“7B08070003”相匹配的价格&库存,您可以联系我们找货
