TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD TCXO 2.0 * 1.6
NOMINAL FREQ.
26 MHz
TXC P/N
7Z26001013
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & DATE
(1) TXC requires one copy returned with signature and title of authorized individual that signifies
acceptance of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be
produced per these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification
Sheets" from customers will be regarded as the agreement on the contents of these
specifications.
Attachment(s):
V 1. Product Specification Sheet
2. Testing Report(Electrical & Temperature)
3. Reliability Report
RoHS Compliant
FMT-DOC024
Issue date: 12.15 '08 VER.E
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
SMD TCXO 2.0 * 1.6
NOMINAL FREQ.
26 MHz
TXC P/N
7Z26001013
REVISION
S1
PE/RD
QA
MFG
2012/8/28
NOTE:
(1) Lead Free Products are " Directive 2002 / 95 / EC of The European Parliament of 27
January 2003 on the restriction of the use of certain hazardous substances (RoHS) in
electrical and electronic equipment" Compliant (Attachment: SGS Test Report).
(2) Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3) Revision "Ax" is production ready. PE, QA and MFG's approval required.
RoHS Compliant
FMT-DOC024
PAGE : 1 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
Rev
Revise page
S1
N/A
FMT-DOC024
Revise contents
Initial released
P/N : 7Z26001013
REVISION : S1
Date
Ref.No.
Reviser
2012/08/28
N/A
Su-Chen Chiang
PAGE : 2 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
P/N : 7Z26001013
REVISION : S1
■ ELECTRICAL SPECIFICATIONS
Item Parameters
1
Condition
Operating Temperature Range
3
Supply Voltage
4
Current Drain
5
Output Level
6
Output Type
7
9
12
13
14
15
16
vs. Temperature
mA
V
Resistance
9
10
11
kΩ
9
10
11
pF
After 2 times reflow
±2.0
ppm
2
Temp: -30 ~ +85 ℃
±0.5
ppm
3,4
±3
ppm
3,4
±0.1
ppm
Temp: -40 ~ -30 ℃
ppm
ppm/℃
Temp: -30 ~ +85℃
±0.1
ppm/℃
Temp: -40 ~ -30℃
±0.35
ppm/℃
±0.6
ppm
+85
2.0
ms
2.0
ms
60
st
±1.0
ppm/year
nd
±1.5
ppm/year
5 year
±2.5
ppm/year
th
±5
ppm/year
-8
dBc
-40
vs. Frequency
Within ± 0.5 ppm
vs. Output Level
To 90% of Vp-p
40
Duty Cycle
50
1 year
2
Aging
year
th
10 year
Harmonics
27
@ 1 Hz offset
-50
dBc/Hz
28
@ 10 Hz offset
-80
dBc/Hz
29
30
Phase Noise
1
Capacitance
±0.1
25
26
1.5
±0.05
22
24
V
Temp: -20 ~ +65℃
Storage Temperature
23
Vcc: 2.8V ±5%
Static Temperature Hysteresis
21
2.80
vs. Supply Voltage
Slope of Frequency Drift over
Temperature
Start-up Time
+85
3.30
-40
1.70
Note
MHz
Load: 10 kΩ // 10 pF ±10%
18
UNITS
vs. Load
17
19
MAX
Clipped Sinewave
Frequency Tolerance
Frequency
Stability
TYP
0.8
Output Load
10
11
MIN
Nominal Frequency
2
8
Electrical Specifications
@ 100 Hz offset
-105
dBc/Hz
@ 1 kHz offset
-130
dBc/Hz
31
@ 10 kHz offset
-148
dBc/Hz
32
@ 1 MHz offset
-150
dBc/Hz
4
5
Note 1 Decoupling capacitor is required in external circuit.
Note 2 Refer to nominal frequency
Note 3 Refer to frequency at 25±2℃
Note 4 Minimum of 1 frequency reading every 2°C over temperature, based on temperature varied at maximum of
2°C per minute.
Note 5 Frequency deviation at 25°C after reciprocal temperature cycle over the operating temperature range
FMT-DOC024
PAGE : 3 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
P/N : 7Z26001013
REVISION : S1
■ TESTING CIRCUIT
External Components
Output
VCC
VCC
C1
10 nF
OUT
TCXO
GND
C2
1000 pF
RL
CL
Name
Function
C1
AC Noise Bypass for VCC
C2
DC Block for Output
RL
Load Resistance
CL
Load Capacitance
GND
Note: Bypass capacitor (C1) and DC blocking capacitor (C2) should be placed.
■ DIMENSIONS
Pin Connection
2.0 ± 0.15
Pin 3
1.6 ± 0.15
Pin 4
Top View
Pin 1
Name
Connection
Pin 1
GND or NC
Pin 2
GND
Pin 3
OUTPUT
Pin 4
VCC
Pin 2
0.79
0.8 Max
Recommended Land Pattern
1.51
Pin 1
1.18
0.40
Bottom View
0.79
0.40
Pin 2
0.44
Pin 4
FMT-DOC024
1.20
1.51
0.44
Pin 3
PAGE : 4 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
P/N : 7Z26001013
REVISION : S1
■ SUGGESTED REFLOW PROFILE
Note : Total Time: 200 sec. Max., Solder Melting Point: 220°C
■ MARKING
TCXO Date Code
TCXO Lot Code
T XXX
Company Name
Frequency Divider Index (optional)
XXXXX
X'tal Lot Code
Pin1 Index
X'tal Date Code
X'tal Frequency Code, ex:38.4 MHz=38
DATE CODE
MONTH
YEAR
JAN
FEB
MAR
APR
MAY
JUN
JUL
AUG
SEP
OCT
NOV
DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
* This date code will be cycled every four years.
Note: If TCXO frequency is X'tal frequency divided by 2, then frequency divider index appears.
If TCXO frequency is the same as X'tal frequency, then no frequency divider index appears.
FMT-DOC024
PAGE : 5 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
P/N : 7Z26001013
REVISION : S1
■ PACKING : (EIA-481-2)
DIMENSIONS
A
B
C
D
E
F
G
H
0.90
2.30
1.90
4.00
8.00
4.00
1.55
1.75
Trailer
Parts
(UNIT : mm)
Leader
Empty Sealed
160mm(Min)
230mm(Min)
160mm(Min)
User direction of feed
DIMENSIONS
L
L1
W
W1
178
13
11.5
8
pcs / Reel (UNIT : mm)
Standard Reel Quantity is 3,000 pcs per reel
■ WEIGHT
0.00854g / piece(TYP), 25 ± 2 g /3 kpcs( regardless of tape weight )
FMT-DOC024
PAGE : 6 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
P/N : 7Z26001013
REVISION : S1
■ STRUCTURE ILLUSTRATION
Crystal Enclosure Seal: Seam Welding
6
4
1
2
5
7
3
8
9
No.
COMPONENTS
1 Cap
2 Base
MATERIALS
Metal(Fe + Co + Ni)
Ceramic
3
Pad
Au
4
5
6
7
8
9
Crystal Blank
Conductive Adhesive
Electrode
Underfill
Bump
IC
SiO2
Ag
Noble Metal
Organic
Au
Si
FMT-DOC024
FINISH/SPECIFICATIONS
Color Black
Tungsten Metalize
+ Ni Plating
+ Au Plating
Silicone Resin
Color Black
PAGE : 7 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
P/N : 7Z26001013
REVISION : S1
■ RELIABILITY SPECIFICATIONS
1. Mechanical Endurance
No.
Test Methods
Test Item
1.1 Drop Test
1.2 Mechanical Shock
1.3 Vibration
1.4 Gross Leak
Criteria
Hegiht : 100 cm height
Direction : X,Y,Z 6 directions
Test cycles : 3 cycles
Fall freely on to concrete floor
Mounting on test fixture (total weight=100 g)
Acceleration : 1000 g
Duration : 0.5 ms
Test cycles : 3 times for all 3 directions
+/- 2.0 ppm
+/- 2.0 ppm
Acceleration : 20 g
Duration : 4 hours/each direction
Frequency range : 10 ~ 2000 Hz
Amplitude : 1.52 mm
+/- 2.0 ppm
Direction : X,Y,Z 3 directions
Sweep speed : 20 minutes/cycle
Standard sample for automatic gross leak detector.
2
Test Pressure : 2 kg/cm
1.5 Fine Leak
Helium bomging 4.5 kgf/cm2 for 2 hours
1.6 Solderability
Preheate temperature : 125℃ ± 5℃
Preheate time : 120 sec
Solding temperature : 245℃ ± 5 ℃
Duration : 5 ± 1 sec
Method : Solder bath method
< 1.5 × 10-5 Pa
m3 / sec
< 1.0 × 10-9 Pa
m3 / sec
90% Coated
[Note] Criteria mean the maximum frequency change after reliability test, frequency shell be measured at 25℃.
FMT-DOC024
PAGE : 8 / 8
TXC CORPORATION
PRODUCT TYPE :
SMD TCXO 2.0 * 1.6
P/N : 7Z26001013
REVISION : S1
2. Environmental Endurance
No.
Test Item
2.1 High Temp. Storage
2.2 Low Temp. Storage
Test Methods
Temperature : +125℃ ± 3℃
Duration : 168 hours
Temperature : -40℃ ± 3℃
Duration : 500 hours
Criteria
+/- 2.0 ppm
+/- 2.0 ppm
Total 100 cycles of the following temperature cycle :
2.3
Thermal Shock
(Air to Air)
Temperature : 85℃ ± 3℃
2.4 High Temp&Humidity Humidity: RH 85%
Aging
Duration
: 500 hours
2.5
Voltage input by specification
+/- 2.0 ppm
+/- 2.0 ppm
+/- 2.0 ppm
[Note] Criteria mean the maximum frequency change after reliability test, frequency shell be measured after
2 hours at 25℃ leaving.
FMT-DOC024
很抱歉,暂时无法提供与“7Z26001013”相匹配的价格&库存,您可以联系我们找货
