AM13000001
AM13000001
    TXC(台晶)
    SMD3225_4P
    无源晶振 SMD3225_4P
AM13000001 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2×2.5 NOMINAL FREQ. : 13.000000MHz TXC P/N : AM13000001 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC024 RoHS Compliant Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2×2.5 NOMINAL FREQ. : 13.000000MHz TXC P/N : AM13000001 REVISION : A1 PE/RD QA MFG NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION Rev Revise page A1 N/A FMT-DOC024 TXC P/N: Revise contents Initial released AM13000001 REVISION: A1 PAGE: Date Ref.No. Reviser 20-May-11 N/A Jane Lee Issue Date: 12.15'08 VER.E 1 TXC CORPORATION AM13000001 TXC P/N: REVISION: A1 PAGE: ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity : 40%~70% If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity : 40%~70% Measure equipment Electrical characteristics measured by HP E5100A or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYPE MAX Notes UNITS FL 13.000000 MHz - - Fundamental CL 10 pF 4 Frequency Tolerance - ±10 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 2 Oscillation Mode 3 Load Capacitance 6 Operating Temperature - 7 Aging - 8 Drive Level DL 9 Effective Resistance Rr -40 ~ 85 ±3 ℃ ppm 1st Year μW - 50 - Rr - - 50 Ω 10 Insulation Resistance - 500 - - MΩ 11 Storage Temperature Range - -40 ~ 125 ℃ FMT-DOC024 - at DC 100V - Issue Date: 12.15'08 VER.E 2 TXC CORPORATION AM13000001 TXC P/N: REVISION: ■ DIMENSIONS A1 PAGE: Unit:mm (Unit:mm) 0.70 ± 0.10 3.20 ± 0.10 GND 3 3 4 2.50 ± 0.10 4 1 GND 2 1 2 0.90±0.10 Internal View Connection 1.20±0.10 1.00±0.10 4 3 1.40 0.80 1.40 0.70±0.10 1.20 0.50 1.20 1 2 Bottom View Suggested Layout ■ MARKING   T□□□ TXC Logo Pin 1 Location ■ Frequency Code ex:14.318180 MHz=143 □□□□ Lot Code Date Code Line Code Date Code: MONTH YEAR 2005 2009 2013 JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years Production location:Taiwan (℃) ■ SUGGESTED REFLOW PROFILE 10 sec 260 Total time : 200 sec. Max. Solder melting point :220 ℃ 220 180 150 Time (sec) 120 sec FMT-DOC024 60 sec Issue Date: 12.15'08 VER.E 3 TXC CORPORATION TXC P/N: AM13000001 REVISION: A1 PAGE: ■ STRUCTURE ILLUSTRATION A-A' sectional drawing B-B' sectional drawing NO COMPONENTS C-C' sectional drawing MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) - 2 Base(Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu Color black 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 5 Conductive adhesive Ag Silicon resin 6 Electrode Noble Metal - FMT-DOC024 - Issue Date: 12.15'08 VER.E 4 TXC CORPORATION AM13000001 TXC P/N: REVISION: A1 PAGE: ■ PACKING F G B E H INDEX MARK A DIMENSIONS C Feeding D A B C D E F G H 1.65 3.4 2.7 4 8 4 1.5 1.75 Trailer REMARK : Parts Leader Empty Sealed 160mm(Min) 160mm(Min) (UNIT : mm) 230mm(Min) User direction of feed W W1 2.0 L1 DIMENSIONS FMT-DOC024 L L1 W W1 178 13 11.5 8 L pcs / Reel (UNIT : mm) Standard Reel Quantity is 3,000 pcs per reel Issue Date: 12.15'08 VER.E 5 TXC CORPORATION AM13000001 TXC P/N: REVISION: A1 PAGE: 6 ■ RELIABILITY SPECIFICATIONS 1. Mechanical Endurance Test Item No. 1.1 Drop Test 1.2 Mechanical Shock 1.3 Vibration Test Methods REF.DOC 120 cm height, 5 times on Stainless Plate . JIS C 6701 Device are shocked to half sine wave ( 3000 G ) three mutually perpendicular axes each 3 times. 0.3m sec. duration time Frequency range 10 ~ 2000 Hz~10 Hz Amplitude 1.52 mm/10 G Sweep time 20 minute Perpendicular axes each test time 4 Hrs MIL-STD-202 Method 213 MIL-STD-202 Method 204 (Total test time 12 Hrs) 1.4 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol J-STD-002 solvent ( 1 : 4 ) 1.5 Terminal Strength Mount on PCB board and shear strength 1.8 kg for 60 sec. AEC-Q200-006 1.6 Board Flex Duration Time: 60 sec, Deviation: 3mm AEC-Q200-005 2.Environmental Endurance No. Test Item 2.1 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. REF. DOC MIL-STD 202 Method 210 2.2 High Temp. Storage + 85 ℃ ± 3 ℃ for 1000 Hrs. MIL-STD-202 Method 108 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 Hrs. JIS C 6701 Total 1000 cycles of the following Thermal Shock 1 cycle 85 ± 3℃ 2.4 Thermal Shock -55 ± 3℃ 2.5 Temperature Cycle MIL-STD-202 Method 107 25℃ 5 min. 5 min. 20 sec. max. Total 1000 cycles of the following temperature cycle - 40℃ ± 3 to 85℃ ± 3 , Dwell time :15min. JESD 22 Method JA-104 2.6 High Temp&Humidity + 85℃ ± 3℃ , RH 85% , 1000 Hrs. MIL-STD-202 Method 103 2.7 Moisture Resistance 10 cycles ( +25℃~65℃ , 80%~100% RH) , 24 hrs/cycle MIL-STD 202 Method 106 2.8 Operational Life + 85 ℃ ± 3 ℃ for 1000 Hrs. MIL-STD-202 Method 108 FMT-DOC024 Issue Date: 12.15'08 VER.E
AM13000001 价格&库存
很抱歉,暂时无法提供与“AM13000001”相匹配的价格&库存,您可以联系我们找货
