AT08000004
AT08000004
    TXC(台晶)
    HC-49S/SMD
    无源晶振 HC-49S/SMD
AT08000004 数据手册
TXC CORPORATION 5F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : HC-49/S SMD NOMINAL FREQ. : 8.000000MHz TXC P/N : AT08000004 REVISION : S1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D TXC CORPORATION 5F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : HC-49/S SMD NOMINAL FREQ. : 8.000000MHz TXC P/N : AT08000004 REVISION : S1 PE/RD QA MFG 2008/7/24 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D TXC CORPORATION Rev Revise page S1 N/A FMT-DOC024 TXC P/N: AT08000004 Revise contents Initial Released REVISION:S1 PAGE: 1 Date Ref.No. Reviser 2008/7/24 N/A Tiantian Xin Issue Date: 03.09'06 VER.D TXC CORPORATION TXC P/N: AT08000004 REVISION:S1 PAGE: 2 CONTENT SPECIFICATIONS PAGE • ELECTRICAL SPECIFICATIONS 3 • DIMENSIONS • SUGGESTED REFLOW PROFILE 4 4 • MARKING 5 • PACKING 6 • RELIABILITY SPECIFICATIONS 7 ATTACHMENT(S) (optional) TESTING DATA FMT-DOC024 • ELECTRICAL CHARACTERISTICS TEST A YES NO • TEMPERATURE CHARACTERISTICS TEST B YES NO Issue Date: 03.09'06 VER.D TXC CORPORATION TXC P/N: AT08000004 REVISION: S1 PAGE: 3 ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25+/-5oC Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25+/-1oC Relative humidity 40%~70% : Measure equipment SAUNDERS 250A/250B CRYSTAL IMPEDANCE METER. Crystal cutting type The crystal is using AT CUT (thickness shear mode). please refer to marking code page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. Nominal Frequency Oscillation Mode Load Capacitance Frequency Tolerance (25 oC) Effective Series Resistance Shunt Capacitance (C0) Motional Capacitance (C1) Drive Level Operation Temperature Range Stability Over Temperature Range Insulation Resistance Attenuation of Spurious Frequency Amplitude Ratio of Holder to Motional (C0/1) Storage Temperature Aging FMT-DOC024 8.000000 MHz Fundamental 20.0 pF +/- 30 ppm 60 Ohms Max. 7.0 pF Max. N/A 10 uW Typ ; 100 uW Max -40 oC ~ +85 oC +/- 50 ppm (related to 25 oC) 500 MOhms Min. at DC 100V N/A N/A -40 oC ~ +85 oC +/- 5.0 ppm/year Issue Date: 03.09'06 VER.D TXC CORPORATION TXC P/N: AT08000004 REVISION: S1 DIMENSIONS UNIT:mm 4.35+/-0.5 11.4+/-0.5 10.6Max. 3.8+/-0.5 H h 0.3+/-0.1 1.0 Max 0.5+/-0.2 0.5+/-0.2 0.8+/-0.2 4.8 Max. 4.5 Max PAGE: 4 4.88 Max CHOOSE TYPE H(SMDHIGH) h(BODY HIGH) S3 3.8+/-0.3 3.3+/-0.3 S2 3.0+/-0.3 2.3+/-0.3 4.5 Max 12.7+/-0.5 Solder Coating Suggested Layout (Sn-Ag-Cu Pb Free Coating) 4 5.5 (x2) 2.0 (x2) SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 oC FMT-DOC024 Issue Date: 03.09'06 VER.D TXC CORPORATION TXC P/N: AT08000004 REVISION: S1 PAGE: 5 MARKING Marking For Pb Free Parts: TXC TXC Logo Pb Free Product G Lot Code (2 digits) Frequency Code Production Line Code Date Code Date Code: MONTH JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC YEAR 2001 2005 2009 2013 2017 A B C D E 2002 2006 2010 2014 2018 N P Q R S 2003 2007 2011 2015 2019 a b c d e 2004 2008 2012 2016 2020 n p q r s *This date code will be cycled every four years. For example : G U g u H V h v J W j w K X k x L Y l y M Z m z Marking TXC G 8.00Mn01 FMT-DOC024 F T f t Pb Free Product Introduction: 49S/SMD 8.000 MHz Made in NGB 2008/JAN 01Lot Issue Date: 03.09'06 VER.D TXC CORPORATION TXC P/N: AT08000004 REVISION: S1 PAGE: 6 (A) Tape and reel configuration:(Unit:mm) ( a)Emboss taping configuration. (per EIA-481-2) 5o max. TYP. S3 S2 H (+/-0.1) 4.2 3.3 0.4+/-0.1 5.5+/-0.1 5o max. H 11.5+/-0.1 2.0+/-0.1 24.0+/-0.3 +0.1 1.5 -0.0 4.0+/-0.1 13.5+/-0.1 1.75+/-0.1 40(10P)+/-0.2 12.0+/-0.2 +0.1 1.5 -0.0 Direction of start NONE NONE 22.0 Max. Products put in 1000 pcs COVER TAPE 160 Min. 160 Min. 230 Min. 390 Min. ( b)Reel configuration. (B) Packing & Label :(Unit:mm) COVER TAPE 120° 24.4+/-0.2 75+/-3 14.0+/-0.2 ● ● ● ● ● ● ● ● ● ● ● ● ● ● 22.0+/-0.4 A 330+/-1 2.3+/-0.2 3.3+/-0.2 3.3+/-0.2 PUT IN 330+/-5 Label A 330+/-5 G 20 A 20 35+/-5 * "G" : Pb-Free Product FMT-DOC024 Issue Date: 03.09'06 VER.D TXC CORPORATION TXC P/N: AT08000004 REVISION: S1 PAGE: 7 RELIABILITY SPECIFICATIONS Test Item No. 1 Drop Test 2 Mechanical Shock 3 Vibration Test Methods REF.DOC 100 cm height, fall freely onto firm wood for 3 times. JIS C6701 Device are shocked to half sine wave ( 1000 G ) three mutually MIL-STD-202 pendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm Sweep time 20 minute Pendicular axes each test time 4 hours MIL-STD-202 (Total test time 12 hours) 4 Solderability Temperature 235 oC +/- 5oC Immersing depth 0.5 mm minimum Immersion time 5 +/- 0.5 seconds Flux Rosin resin methyl alcohol J-STD-002 solvent ( 1 : 4 ) 260 +/- 5 oC Test temperature 5 Resistance To Soldering Heat Test time 10 +/- 1 sec. Emersion Rate 25 ± 6 mm/s Immersed of specimen 1.5mm MIL-STD-202 6 High Temp. Storage + 125 oC +/- 2 oC for 1000 +/- 12 hours 7 Low Temp. Storage MIL-STD-883 - 40 oC +/- 2 oC for 1000 +/- 12 hours Total 1000 cycles of the following temperature cycle 1 cycle 125+/-3 0C 8 Thermal Cycles MIL-STD-883 25 0C -55+/-3 0C 30 min. 30 min. 10 min. o 9 Humidity FMT-DOC024 o Device are left in temperature at +85 C +/-2 C with relative humidity of 85% for 1000 hours. JIS-C-5023 Issue Date: 03.09'06 VER.D
AT08000004 价格&库存
很抱歉,暂时无法提供与“AT08000004”相匹配的价格&库存,您可以联系我们找货
